1 Reply Latest reply on Jun 16, 2011 8:44 AM by Peter Kahrel
    Footnotes and columns using ID CS2
    Kel Dugal
      Hello all,
      I've been utilizing this script from Peter Kahrel and I was just wondering if the core code for this would work in InDesign CS2 given the fact that there are diiference with some of the features between CS3 (later) and CS2.
      Sonny
        • 1. Re: Footnotes and columns using ID CS2
          Peter Kahrel Adobe Community Professional & MVP
          I've not used CS2 for so long that I don't know, but i guess it won't work. It also depends on what you consider "core code". Two things that may cause problems are that in CS2, footnotes are very fragile, and that the search method changed considerably -- though searching would probably not be part of the core code. Fix the search part and try it out.
          Peter
