I am using Find operation of FileUtility service to count the number of files present under a given folder.
I can not find the correct Regular Expression to match all files.
The Adobe documentation mentions that * character is default which matches all files/folder within the Directory. However, If I leave * unchanged, I'm getting an error "Incorrect Regular Expression syntax".
I have tried different combinations, nothing seems worked.
Can anyone assist me on this?
Nith
Solved! Go to Solution.
Views
Total Likes
You can use the following syntax to get the list of all files:-
\w*\.\w*
Yow can alslo go through the following material for details on Regular Expressions:
http://help.adobe.com/en_US/livecycle/9.0/workbenchHelp/help.htm?content=000582.html
Views
Total Likes
\w*\.\w*
Views
Total Likes
I din't guess that I have to escape DOT(.) character which is important to consider the file extension.
Your RE is correct, and It works perfectly!
Nith
Views
Total Likes
