0 Replies Latest reply on Jun 16, 2011 1:54 AM by vishalkumar86
    problem with tabnavigator index change effect
    vishalkumar86 Level 1
      Hello All,
           I am using
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" verticalAlign="middle" horizontalAlign="center">
      <mx:TabNavigator id="tabNav" height="600" width="600" change="onTabChange(event)">
      <mx:VBox horizontalAlign="center" verticalAlign="middle" height="100%" width="100%" label="Tab 1">
      <mx:Label text="Tab 1" fontSize="30" />
      </mx:VBox>
      <mx:VBox horizontalAlign="center" verticalAlign="middle" height="100%" width="100%" label="Tab 2">
      <mx:Label text="Tab 2" fontSize="30" />
      </mx:VBox>
      <mx:VBox horizontalAlign="center" verticalAlign="middle" height="100%" width="100%" label="Tab 3">
      <mx:Label text="Tab 3" fontSize="30" />
      </mx:VBox>
      <mx:VBox horizontalAlign="center" verticalAlign="middle" height="100%" width="100%" label="Tab 4">
      <mx:Label text="Tab 4" fontSize="30" />
      </mx:VBox>
      </mx:TabNavigator>
      <mx:Script>
      <![CDATA[
      import mx.effects.Move;
      import mx.events.IndexChangedEvent;
      import mx.events.EffectEvent;
      public function onTabChange(event:IndexChangedEvent):void
      var oldTab:DisplayObject = tabNav.getChildAt(event.oldIndex);
      var newTab:DisplayObject = tabNav.getChildAt(event.newIndex);
      var moveEffect:Move = new Move();
      moveEffect.target = oldTab;
      var moveEffect2:Move = new Move();
      moveEffect2.target = newTab;
      if(event.oldIndex > event.newIndex)
      //Moving old Tab out to the right, new tab in from the left
      oldTab.x = 0;
      moveEffect.xTo = oldTab.width + 100;
      moveEffect.yFrom = oldTab.y;
      moveEffect.yTo = oldTab.y;
      newTab.x = -oldTab.width;
      moveEffect2.xTo = 0;
      moveEffect2.yFrom = oldTab.y;
      moveEffect2.yTo = oldTab.y;
      else
      //Moving old Tab out to the left, new tab in from the right
      oldTab.x = 0;
      moveEffect.xTo = -oldTab.width;
      newTab.x = oldTab.width + 100;
      oldTab.visible = true;
      newTab.visible = true;
      moveEffect2.play();
      moveEffect.addEventListener(EffectEvent.EFFECT_END,tabOffScreen);
      moveEffect.play();
      private function tabOffScreen(event:EffectEvent):void
      event.target.removeEventListener(EffectEvent.EFFECT_END,tabOffScreen);
      event.target.target.visible = false;
      </mx:Script>
      </mx:Application>
      to run the slide effect in flash builder 4.5 with sdk 4.5. When the effect plays, the selected child behaves abnormal whereas when it runs with sdk 3.6 in flash builder 4.5, everything goes well.
      Any help will be apppreciated.
      -Thanks and regards
      Vishal Kumar
