3 Replies Latest reply on Jun 16, 2011 9:40 AM by ssebuser
    netStream client handler
    ssebuser
      I want to add an handler for onMetaData on my netStream Client.
      The onMetaData function is never called, but I know that the .flv file I'm playing contains metadata...
      public class CustomNetStream extends NetStream
           public function CustomNetStream(connection:NetConnection)
              super(connection);
              client = new NetClient();
              NetClient(client).addHandler(NetStreamCodes.ON_META_DATA, onMetaData);
              addEventListener(NetStatusEvent.NET_STATUS, onNetStreamStatus);
           public function onMetaData(value:Object):void
                 NetClient(client).removeHandler(NetStreamCodes.ON_META_DATA, onMetaData);
                 trace("Got metadata.");
          private function onNetStreamStatus(event:NetStatusEvent):void
             trace("onNetStreamStatus() - event.info.code=" + event.info.code);
        • 1. Re: netStream client handler
          Mykola3296 Level 2
          Hello!
          Do you need to handle metadata in NetStream descendant?
          If not I would have used a different approach.
          LightWeightedVideoElement has a property "client" that is being set to NetClient upon element load.
          So you may want to load an element and use that property instead of subclassing netstream.
          Regards!
          • 2. Re: netStream client handler
            ssebuser Level 1
            I'm creating a dynamic OSMF plugin and I need to create a custom NetStream class.
            • 3. Re: netStream client handler
              ssebuser Level 1
              I found a way, when I receive NetStream.Play.Start I add the handler and then it works perfectly...
                 if ( event.info.code == NetStreamEvent.PLAY_START )
                      var netStreamLoadTrait:NetStreamLoadTrait = loadTrait as NetStreamLoadTrait;
                      (netStreamLoadTrait.netStream.client as NetClient).addHandler(NetStreamCodes.ON_META_DATA, onMetaData);
