4 Replies Latest reply on Jun 19, 2011 3:28 AM by Starlover_jacob
    Debug error no such variable
    Starlover_jacob
      Hello,
      I have a problem debugging my air project in flex builder 3
      I have 2 variables:
          var test:String="hello";
          var test2:String="world";
      with a break point before the second
      a watch expression on the first(test)
      when i debug, it stops at test2 (as it should because of the break point)
      I now look at the expressions window and see my first variable (test)
      It doesn't show that its value is hello.
      It shows: <errors during evaluation> and when i click the + it wil show: No such variable: test.
      How do i fix my debugger??
      I cleaned the bin-debug directory of my project
      and run a clean project (menu project - clean) but nothing helps.
      Please help me out!! Without debugging im lost!
        • 1. Re: Debug error no such variable
          Flex harUI Adobe Employee
          These are local variables in a function?
          • 2. Re: Debug error no such variable
            Starlover_jacob Level 1
            Yes they are, and i call that function by clicking a button.
            It gets even stranger. When i watch variables i created earlyer (lets say a month ago...) they do show in the expression window.. and the value inside that variable is correct. (no errors during evaluation)
            Hope you can get me closer to a solution.
            Greets, J.
            • 3. Re: Debug error no such variable
              Post a 20-line test case that reproduces the problem.
              • 4. Re: Debug error no such variable
                i could give you a new project with a small test case of 20 lines, but code is code.. it would probably work at your computer.
                I did create a small test case, and it debugs fine.. it looks like there are some debug files  for my perticular project that needs to be re-build.
                I did clean the bin-debug file of my project, restart flex builder and did a clean project, but this didn't solve the problem.
                Is there or are there more things i need to do to properly reset the debugger?
                Early on my project, i did clean the bin-debug folder because i put some new images inside my project and when i debug it did not show that newly created images. After emptying the bin-debug folder and debug the project again.. it would display my images. So that problem was solved.
                I also noticed that lately i need to use project - clean a lot after i changed something in my project that directly has to do with the view (what the user will see on his screen) like reposition a button or something like that.
                I use sdk version: flex_sdk_3.4.0.6955
                Automatic update on flex is off
                version of flex builder: 3.0(build 3.0.194161)
