1. Re: Text Entry Boxes: How do I align the text
Lilybiri Jun 16, 2011 1:38 PM (in response to cap_newbie)Hello,
No alignment possibilities in a Text Entry Box, sorry. But why not replace it by the TextArea Widget? There you have all the formatting possibilities, and if necessary, can be associated to a variable.
Lilybiri
2. Re: Text Entry Boxes: How do I align the text
cap_newbie Jun 16, 2011 2:02 PM (in response to Lilybiri)Thank you so much for that quick and helpful reply! This looks like it will work perfectly but now I have a new question, how can I make the box nearly transparent? I want the users to still see the certificate background yet clearly see the fields for their name and date. I'm not experienced enough to know how to use the color codes in the widget formatting to set a nearly transparent color.
Thanks again you've helped me immensely already!
3. Re: Text Entry Boxes: How do I align the text
Lilybiri Jun 17, 2011 2:07 AM (in response to cap_newbie)Hello,
There is no alpha setting possible for fill in the TextArea widget, sorry. Do you have a unique color for the certificate background? Put that color into either the Stroke color or the Fill color in the Vertical Toolbox using the color picker (see screenshot, I highlighted the color picker in yellow). Than you can write down its hexadecimal code (or copy it) to use as Fill Color in the TextArea widget. In the screenshot it is #0080FF
Lilybiri
4. Re: Text Entry Boxes: How do I align the text
cap_newbie Jun 20, 2011 9:47 AM (in response to Lilybiri)Thanks again and sorry about the follow-up private message.
