I have a PHP project in Flash Builder for PHP 4.5 which does not recognise any of the PHP in-built functions. I have tested this on a brand new project and still the functions I type are not recognised. So I can't basically auto-complete them or look at what the function definition is.
Usually the built-in function are listed under "PHP Language Library" > "Core API". But in my PHP projects they don't show at all. Any thoughts?
I raised this problem with Zend (Which is where I bought the product from) Support and this is what they had to say:
Unfortunately, Zend not supporting the Flash Builder for PHP.
You can use the Adobe online forums to find solutions for your technical issues:
http://forums.adobe.com/community/flash_builder/
and this:
Please use the Adobe Forums to report your problem. If the problem is related to Zend part of the product (it definitely looks like this), we will help you to solve this problem - through Adobe Forums. If you browse Adobe Forums, you may have noticed that our staff is quite responsive. Just post your issue there and you will see that routing your request through the correct channel will ensure the fastest resolution.
So I am hoping Zend/Adobe Engineers are here to help me with the problem I have. Thanks
Hello there,
In order to understand your environment please attach some more details such as your environment parameters (OS, arch) as well as your project configuration files (.project and .build path located under your project root).
I will make sure Zend Support Representatives will go back to you.
Roy
Hi Roy,
Here is the contents of the project .buildpath
<?xml version="1.0" encoding="UTF-8"?> <buildpath> <buildpathentry kind="con" path="com.zend.php.phpunit.CONTAINER"/> <buildpathentry kind="con" path="org.eclipse.php.core.LANGUAGE"/> <buildpathentry kind="src" path=""/> </buildpath>
and .project
<?xml version="1.0" encoding="UTF-8"?> <projectDescription> <name>NAV-Contacts-PHP</name> <comment></comment> <projects> </projects> <buildSpec> <buildCommand> <name>org.eclipse.wst.validation.validationbuilder</name> <arguments> </arguments> </buildCommand> <buildCommand> <name>org.eclipse.dltk.core.scriptbuilder</name> <arguments> </arguments> </buildCommand> </buildSpec> <natures> <nature>org.eclipse.php.core.PHPNature</nature> <nature>org.zend.php.framework.ZendFrameworkNature</nature> </natures> </projectDescription>
The OS is MacOS X 10.6.7
Thanks, according to this your project is set correctly and it should recognize the PHP language features as well as ZF types.
One thing that should be verified is that ZS has permissions to write your workspace directory (in specific the .metadata directory where the model is written to). Developers usually experience this when the workspace is not writeable.
Hope this helps,
Roy
Sent from my mobile
Hi Roy,
The permissions on the .metadata folder look fine to me:
ls -lan ~/Documents/Adobe\ Flash\ Builder\ 4.5/.metadata/ total 2416 drwxrwxr-x 8 501 501 272 9 Jun 17:44 . drwxrwxr-x 10 501 501 340 16 Jun 11:10 .. -rw-r--r-- 1 501 501 1025903 9 Jun 17:44 .bak_0.log -rw-r--r-- 1 501 501 0 29 May 18:23 .lock -rw-r--r-- 1 501 501 203362 18 Jun 13:44 .log drwxr-xr-x 4 501 501 136 29 May 18:25 .mylyn drwxr-xr-x 65 501 501 2210 16 Jun 11:59 .plugins -rw-r--r-- 1 501 501 34 18 Jun 13:35 version.ini
