1 Reply Latest reply on Jun 23, 2011 1:42 AM by fryckoort
    Latency (sync VideoElement with MovieClip)
    fryckoort Level 1
      I have a MovieClip witch contain several visuals elements, movieclip
      timeline must be sync with VideoElement.
      To do that, I start movieclip timeline when BUFFERING mediaplayer state
      is false, each 10 ms, I check if visual timeline needed to be resync
      whith mediaPlayer.currentTime (if time difference is equal or greater
      than 20 ms)
      The problem is : on Windows there is a latency witch affect the user
      experience, on mac it works like a charm.
      I use FLash CS5 and Flex SDK 4.5 + Flash Player 10.2
      This is my code (sample) :
      _videoElement = new VideoElement( null, new HTTPStreamingNetLoader());
      _parallelElement = new ParallelElement();
      _parallelElement.addChild(_videoElement);
      _mediaPlayer = new MediaPlayer(_parallelElement);
      _mediaPlayer.currentTimeUpdateInterval = 10;
      _mediaPlayer.addEventListener(TimeEvent.CURRENT_TIME_CHANGE,
      currentTimeChangeHandler);
      _mediaPlayer.addEventListener(BufferEvent.BUFFERING_CHANGE,
      bufferingChangeHandler);
      _mediaPlayer.play();
      function bufferingChangeHandler(event:BufferEvent):void
      if(!event.buffering)
             timeline.play();
      else
             timeline.pause();
      function currentTimeChangeHandler(event:TimeEvent):void
             //check if timeline need to be sync
             var timelineInterval:Number = timeline.currentTime -
      _mediaPlayer.currentTime;
             if (Math.abs(timelineInterval) > 0.2 )
                     timeline.currentTime = _mediaPlayer.currentTime;
      Timeline is ALWAYS sync. But visually we can see timeline in advance of
      the video, probably because of latency or less depending on the system.
      *** Sometimes I got 150 ms, sometimes 50ms. ***
      on Mac is always less than 30 ms
      If i use HTTPStreamingNetLoader NetStream.appendBytes() is used no ? so latency should be better ?
      What can I do to have a latency close to 0 in any environment ?
      Thanks !!
