3 Replies Latest reply on Jun 20, 2011 10:16 AM by andres margalef
    AdvancedDataGrid changing dataprovider bug infinite loop
    andres margalef
      Make the second column width like this image and then click on addRow1:
      <code>
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      <fx:Declarations>
      <s:ArrayCollection id="dp">
      <fx:Object descripcion="descripcion1" />
      <fx:Object descripcion="descripcion2" />
      <fx:Object descripcion="descripcion3" />
      <fx:Object descripcion="descripcion4" />
      </s:ArrayCollection>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      protected function btnAceptar_clickHandler(event:MouseEvent):void {
      var aux:ArrayCollection = new ArrayCollection(dp.toArray());
      var obj:Object = new Object();
      obj.descripcion = "descripcion" + dp.length;
      aux.addItem(obj);
      dp = aux;
      protected function button1_clickHandler(event:MouseEvent):void {
      dp.addItem(obj);
      </fx:Script>
      <s:layout>
      <s:VerticalLayout />
      </s:layout>
      <s:Panel>
      <mx:AdvancedDataGrid id="grilla" dataProvider="{dp}" width="100%" height="100%"
      horizontalScrollPolicy="auto"
      <mx:columns>
      <mx:AdvancedDataGridColumn dataField="descripcion" />
      </mx:columns>
      </mx:AdvancedDataGrid>
      </s:Panel>
      <s:Button label="addRow1" click="btnAceptar_clickHandler(event)" />
      <s:Button label="addRow1" click="button1_clickHandler(event)" />
      </s:Application>
      </code>
        • 2. Re: AdvancedDataGrid changing dataprovider bug infinite loop
          Flex harUI Adobe Employee
          I might be able to help if you simplify your test case some more.  Assign a
          fixed with to the ADG so we know exactly what width is causing a problem,
          and fix the steps or labels on the buttons so we understand what to do.
          • 3. Re: AdvancedDataGrid changing dataprovider bug infinite loop
            andres margalef Level 1
            When the width property is not used, it fails. I can't simplify more than this sorry.
            Steps:
            • click on Fail button
            <s:Application
                 width="300" height="300"
                 <fx:Declarations>
                           <fx:Object description1="description" description2="description"/>
                 </fx:Declarations>
                 <fx:Script>
                      <![CDATA[
                           protected function fail_clickHandler(event:MouseEvent):void {
                                obj.descripcion = "description";
                                aux.addItem(obj);
                                dp = aux;
                 </fx:Script>
                 <s:layout>
                 </s:layout>
                 <mx:AdvancedDataGrid id="grid" dataProvider="{dp}" height="160" horizontalScrollPolicy="auto">
                      <mx:columns>
                           <mx:AdvancedDataGridColumn dataField="description1" width="200"/>
                           <mx:AdvancedDataGridColumn dataField="description2" width="5"/>
                      </mx:columns>
                 <s:Button id="fail" label="FAIL" click="fail_clickHandler(event)" />
            </s:Application>
