3 Replies Latest reply on Jun 20, 2011 10:34 AM by Flex harUI
    passing parameters from html to flex application
    InfoCon_Brian Level 1
      I am using flex Builder 3. using ActionScript 3
      I am trying to pass html parameters via the flashVars outline in
      the help:
      http://livedocs.adobe.com/flex/3/html/help.html?content=passingarguments_3.html
      Problem:
      Application.application.parameters equals null
      root is equal to null (I know discontinued in AS3)
      loaderInfo is equal to null.
      I am looking at values via the debugger at a break point in
      creationComplete and initialize.
      I have modify the html wrapper to for each case outline in the help.
      Any ideas as to what I am doing wrong?
      code:
       private function init():void
             for (var i:String in Application.application.parameters) {
                ta1.text += i + ":" + Application.application.parameters[i] + "\n";
      Brian
        • 1. Re: passing parameters from html to flex application
          Flex harUI Adobe Employee
          I usually see folks pass in flashvars via a modified html wrapper.  If you
          want folks to pass in params on the URL, use BrowserManager
          • 2. Re: passing parameters from html to flex application
            Well, it not what I want to do, it is a I have to pass parameters via the url
            because of the project design.
            I tried the BrowserManager, All I got was null's.
            So, I know I am doing something wrong, but
            I don't know what.
            The Design is:
            Given a url with various parameters in the url.
            1) take the url parse the url
            2) organize the data so, that the data can be passed into
                 a flex application.
            3) The flex application will take the data and store
                 the data in an object.
            I am trying to get step 2 and 3 to work, but all I am
            getting is null's.  I suspect the problem is in the html wrapper.
            • 3. Re: passing parameters from html to flex application
              Make sure:
              1) your project settings include "browser integration"
              2) You followed an example and called BrowserManager.init();
              3) The parameters are passed with a hash (#) not question mark (?)
                  my.site.com/myFlexWrapper.html#param1=foo&param2=bar
              If you can't use hash, I think you have to use your own wrapper and add a
              function that will get the outer URL and use ExternalInterface to call it.
