2 Replies Latest reply on Oct 31, 2006 6:36 AM by Rodrigo Alarcon
    Integrating PDF Forms and Coldfusion
    Rodrigo Alarcon
      Hello, i've been able to integrate Coldfusion and Adobe Acrobat Dynamic form, so people can fill the information and submit it via e-mail with an attached XML file created by Adobe Acrobat form/reader; i've been able to read the information, upload to a database and other stuff... how ever.. i discovered that the automatic XML generated by Adobe Acrobat or Form is in UFT-8 Enconding and when i read for example... spanish characters i'm getting weird signs... is there any way i can change this behavior at the forms so they are automatically generated in iso-8859-1 enconding.?
      Here is a sample XML:
      <?xml version="1.0" encoding="UTF-8"?>
      - <form1>
      If you filled in a form:
      This file contains data that was entered into a form.
      It is not the form itself.
      If you receive this data file:
      Please follow the directions below to process this data file using
      Adobe Acrobat Professional 7
      **To view the completed form:
      1) Save this data file to your computer.
      2) Open a blank copy of the original PDF form that the form filler
      completed in order to generate this data file.
      3) In Acrobat, choose Advanced > Forms > Import Data to Current Form
      and browse for this data file.
      4) You will see the form with the data in it.
      5) To save a copy of the form with the data in it, choose File > Save As
      and save the file.
      **To create a spreadsheet from one or more form data files you have received:
      1) Save the data files to a place on your computer, giving each file a
      unique name and making sure not to delete the '.xml' file extension.
      2) In Acrobat, choose File > Form Data > Create Spreadsheet from Data Files.
      3) Click the 'Add Files' button to chose the data files.
      4) After the data files are added, click the 'Create Spreadsheet' button
      to create a Spreadsheet that contains data from selected data files.
      - <encuesta1>
      - <personal>
      <txt_apellido>my name</txt_apellido>
