0 Replies Latest reply on Aug 16, 2006 10:59 AM by retaks
    Clean Up xhtml problem
    retaks
      I am having a problem cleaning up xhtml or applying source formatting. Each time I do this to the template I get a message "xhtml syntax fixed" Then I do it again and the same message. Because its doing this to the template it does it on all the documents also. Is there any log I can check to see what its changing each time so I can manually go in and fix this. Any other ideas/suggestions? Id rather not have to go through all the code looking for an xhtml syntax error that won't change.
