0 Replies Latest reply on Jun 20, 2011 12:43 AM by Wesley Chin
    Rotating labels
    Wesley Chin
      Hi everyone,
      I want to rotate my label but it does not want to work. I have embedded the font too.  Please help.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/halo"
      width="780" height="550" contextMenu="{cm}" creationComplete="Init()"
      layout="absolute">
      <s:layout>
      <s:BasicLayout />
      </s:layout>
      <fx:Style>
      @namespace s "library://ns.adobe.com/flex/spark";
      @namespace mx "library://ns.adobe.com/flex/halo";
      @font-face {
      src: url("../stats/assets/MyriadWebPro.ttf");
      fontFamily: myMyriad;
      embedAsCFF: true;
      Chart {
      fontFamily: Myriad;
      fontLookup: embeddedCFF;
      fontSize: 34;
      </fx:Style>
      <mx:Script>
      <![CDATA[
      public var fontClass:Class;
      import mx.charts.ChartItem;
      import mx.charts.HitData;
      import mx.charts.chartClasses.ChartBase;
      import mx.charts.chartClasses.Series;
      import mx.charts.events.ChartItemEvent;
      import mx.charts.series.PieSeries;
      import mx.charts.series.items.ColumnSeriesItem;
      import mx.controls.Alert;
      import mx.effects.Move;
      import mx.printing.FlexPrintJob;
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      private var csi:ColumnSeriesItem;
      [Bindable]
      public var pieSeriesArr:Array = new Array;
      [Bindable]
      public var datesOpenClosed:String = "Closed";
      [Bindable]
      public var Header:String = "";
      [Bindable]
      public var companyName:String = "";
      [Bindable]
      public var chart1Provider:Array = new Array;
      [Bindable]
      public var chart3Provider:Array = new Array;
      [Bindable]
      public var chart4Provider:Array = new Array;
      [Bindable]
      public var Chart1VMax:int;
      [Bindable]
      public var Chart3VMax:int;
      [Bindable]
      public var Chart4VMax:int;
      [Bindable]
      private var cm:ContextMenu;
      private var mv:Move;
      [Embed(systemFont="Tahoma",
                          fontName="regularFont",
                          mimeType="application/x-font")]
      private var font1:Class;
      private function Init():void
      statsService.getProjectStats.send("", "");
      cm = new ContextMenu;
      cm.hideBuiltInItems();
      private function applyDates():void
      var fromDate:String = txtFromDate.text;
      var toDate:String = txtToDate.text;
      statsService.getProjectStats.send(fromDate, toDate);
      private function getProjectStatsResult(event:ResultEvent):void
      var result:Array = event.result as Array;
      Header = result[0];
      companyName = result[1];
      chart1Provider = result[2];
      chart3Provider = result[3];
      chart4Provider = result[4];
      Chart1VMax = checkMax(chart1Provider);
      Chart3VMax = checkMax(chart3Provider);
      Chart4VMax = checkMax(chart4Provider);
      private function checkMax(arr:Array):int
      var biggest:int = 0;
      for (var i:String in arr)
      if (arr[i].yval > biggest)
      biggest = arr[i].yval;
      var top:int = biggest * 0.3;
      if (top < 1)
      top = 1;
      var vAxisMax:int = biggest + top;
      return vAxisMax;
      private function showHideDates():void
      if (datesOpenClosed == "Closed")
      mv = new Move(dateRangeWindow);
      mv.yFrom = dateRangeWindow.y;
      mv.yTo = -57;
      mv.duration = 500;
      mv.end();
      mv.play();
      lbDateRange.label = "Close";
      datesOpenClosed = "Open";
      else
      mv.yTo = -160;
      mv.duration = 500;
      mv.end();
      mv.play();
      lbDateRange.label = "Change Date Range";
      datesOpenClosed = "Closed";
      private function faultHandler(event:FaultEvent):void
      Alert.show("A error has occured: '" + event.fault.faultDetail + "'. \r\nPlease reload this page and try again");
      private function showPercentage(item:Object, field:String, index:Number, percentValue:Number):String
      var percentage:Number = Math.round(percentValue);
      return percentage.toString() + "%";
      private function doProjPrint():void
      // Create a FlexPrintJob instance.
      var printJob:FlexPrintJob = new FlexPrintJob();
      // Start the print job.
      if (printJob.start())
      // Create a MyPrintView control as a child of the current view.
      var formPrintView:projStatsPrint = new projStatsPrint();
      addChild(formPrintView);
      // Populate the print control's contact label with the text from the form's name, phone, and e-mail controls.
      formPrintView.Heading.text = "Project Statistics";
      // Set the print control's data grid data provider to be the displayed data grid's data provider.
      formPrintView.ProjChart1.dataProvider = provinceChart1.dataProvider;
      if (txtFromDate.text == "" && txtToDate.text == "")
      formPrintView.lblFromDate.text = "Last Month";
      formPrintView.lblToDate.text = "Last Month";
      else
      formPrintView.lblFromDate.text = txtFromDate.text;
      formPrintView.lblToDate.text = txtToDate.text;
      formPrintView.ProjChart2.dataProvider = btypeChart1.dataProvider;
      formPrintView.ProjChart3.dataProvider = btypeChart2.dataProvider;
      formPrintView.Header = Header;
      formPrintView.companyName = companyName;
      formPrintView.lblChart2.text = lblChart2.text;
      formPrintView.lblChart3.text = lblChart3.text;
      // Add the SimplePrintview control to the print job.
      // For comparison, try setting the second parameter to "none".
      printJob.addObject(formPrintView);
      // Send the job to the printer.
      printJob.send();
      // Remove the print-specific control to free memory.
      removeChild(formPrintView);
      private function selectItemHandler(e:ChartItemEvent):void
      var hitData:HitData = e.hitData;
      csi = ColumnSeriesItem(hitData.chartItem);
      var province:String = csi.item.province;
      statsService.getProvStats.send(province);
      private function getProvStatsResult(event:ResultEvent):void
      chart3Provider = result[0];
      chart4Provider = result[1];
      pieSeriesArr = reloadPieSeries();
      btypeChart1.series = pieSeriesArr;
      private function reloadPieSeries():Array
      var series:PieSeries = new PieSeries();
      var seriesArr:Array = new Array;
      series.displayName = "Series 1";
      series.field = "count";
      series.nameField = "btype";
      series.labelFunction = showPercentage;
      series.setStyle("labelPosition", "insideWithCallout");
      series.setStyle("showDataEffect", "slideRight");
      series.setStyle("hideDataEffect", "slideLeft");
      seriesArr.push(series);
      return seriesArr;
      </mx:Script>
      <mx:RemoteObject id="statsService" source="com.webleads.stats.StatsDAO" destination="statsService" showBusyCursor="true" fault="faultHandler(event)">
      <mx:method name="getProjectStats" result="getProjectStatsResult(event)" />
      <mx:method name="getProvStats" result="getProvStatsResult(event)" />
      </mx:RemoteObject>
      <mx:SeriesSlide id="slideUp" direction="up" duration="1000" />
      <mx:SeriesSlide id="slideDown" direction="down" duration="1000" />
      <mx:SeriesSlide id="slideRight" direction="right" duration="1000" />
      <mx:SeriesSlide id="slideLeft" direction="left" duration="1000" />
      <mx:Style source="styles.css" />
      <mx:Canvas width="100%" height="100%" backgroundColor="#ECECEC" label="Projects" contextMenu="{cm}" xmlns:mx="http://www.adobe.com/2006/mxml">
      <mx:VBox width="760" left="10" top="35" bottom="10">
      <mx:Canvas width="100%">
      <mx:Legend height="25" horizontalCenter="0" dataProvider="{provinceChart1}" />
      </mx:Canvas>
      <mx:HBox width="100%" height="50%">
      <mx:ColumnChart id="provinceChart1" width="100%" height="100%" paddingLeft="5" paddingRight="5" dataProvider="{chart1Provider}" itemClick="selectItemHandler(event)" showDataTips="true">
      <mx:horizontalAxis>
      <mx:CategoryAxis id="province" dataProvider="{chart1Provider}" categoryField="province" />
      </mx:horizontalAxis>
      <mx:horizontalAxisRenderers>
      <mx:AxisRenderer labelRotation="45"  axis="{province}" />
      </mx:horizontalAxisRenderers>
      <mx:series>
      <mx:ColumnSeries id="chart1Series1" selectable="true" yField="countTotal" xField="province" displayName="Projects published by Databuild {Header}" showDataEffect="slideUp" hideDataEffect="slideDown" />
      <mx:ColumnSeries id="chart1Series2" selectable="true" yField="countClient" xField="province" displayName="Projects for {companyName}" showDataEffect="slideUp" hideDataEffect="slideDown" />
      </mx:series>
      </mx:ColumnChart>
      </mx:HBox>
      <mx:Canvas width="100%" height="50%">
      <mx:Label id="lblChart2" width="45%" textAlign="left" styleName="boldLabel" text="Projects published {Header}" />
      <mx:Spacer width="10%" />
      <mx:Label id="lblChart3" width="45%" right="0" textAlign="left" styleName="boldLabel" text="Projects for {companyName}" />
      <mx:PieChart id="btypeChart1" width="314" height="214" left="0" top="20" dataProvider="{chart3Provider}" showDataTips="true">
      <mx:series>
      <mx:PieSeries labelFunction="showPercentage" displayName="Series 1" field="count" nameField="btype" labelPosition="insideWithCallout" showDataEffect="slideRight" hideDataEffect="slideLeft" />
      </mx:series>
      </mx:PieChart>
      <mx:Legend width="10%" top="0" bottom="0" horizontalCenter="-20" dataProvider="{btypeChart1}" />
      <mx:PieChart id="btypeChart2" width="342" height="214" right="0" top="20" dataProvider="{chart4Provider}" showDataTips="true">
      <mx:series>
      </mx:series>
      </mx:PieChart>
      </mx:Canvas>
      </mx:VBox>
      <mx:Canvas id="dateRangeWindow" y="-160" width="283" height="184" backgroundColor="#D5D5D5" borderStyle="solid" cornerRadius="16" horizontalCenter="0">
      <mx:DateField id="txtFromDate" x="79" y="90" width="115" formatString="YYYY-MM" />
      <mx:DateField id="txtToDate" x="79" y="120" width="115" formatString="YYYY-MM" />
      <mx:Label x="6" y="92" width="65" textAlign="right" text="From Date" />
      <mx:Label x="6" y="122" width="65" textAlign="right" text="To Date" />
      <mx:Button x="212" y="120" label="Apply" click="applyDates()" />
      <mx:LinkButton id="lbDateRange" y="160" horizontalCenter="0" textAlign="center" label="Change Date Range" click="showHideDates()" />
      <mx:Label x="84" y="62" styleName="boldLabel" text="Change Date Range" />
      </mx:Canvas>
      <mx:Image x="754" y="10" width="16" height="16" source="@Embed('/assets/printer.png')" click="doProjPrint()" buttonMode="true" />
      </mx:Canvas>
      </mx:Application>
