5 Replies Latest reply on Jun 24, 2011 4:16 AM by kc@dafolo.dk
    Convert interactive form with digitally signed XML to PDF/a
    kc@dafolo.dk Level 1
      Hi all,
      I wonder if it should be possible to convert a form that contains digitally signed XML into a PDF/a?
      I have tried the ConvertToPDFA service in LC ES 2.5, but it does not seem to work as I expect. During the conversion I wonder why 3 things happen:
      1. The PDF/a shows as a PDF/a in Reader - however in the PDFAConversionResult the "isPDFa" node is set to false.
      2. In my resulting PDF/a I get all my pages twice. Meaning if my original form was 1 page I get 2 pages in my resulting PDF/a, the last page without data in the fields.
      3. The resulting PDF/a does not show as containing digitally signed data - however the input Form does show up as the data being digitally signed.
      Is this a bug or does any one of you have an idea of how I should approach this challenge?
      Thanks in advance
      Sincerely
      Kim Christensen
      Dafolo A/S
      Denmark
        • 1. Re: Convert interactive form with digitally signed XML to PDF/a
          kjaeggin Level 2
          Hi Kim,
          If you could send me your collateral (.LCA), I can start investigating the issues
          you are having in this scenraio. If it is too large, you can use this service to send it to me: https://sendnow.acrobat.com
          Regards,
          Kevin
          kjaeggin@adobe.com
          • 2. Re: Convert interactive form with digitally signed XML to PDF/a
            Hi Kevin,
            Thanks for your quick reply - you can most certainly get my LCA.
            I have a zip file containing  all you really need, will upload it just after finishing this post.
            I also have been investigating the matter further and have found out what was the issue with this one:
            The issue here seemed to be the form - I had used a simple test form that contained three text fields with the same name. This was not allowed. When I changed the form I got rid of this issue.
            In the zip file you can find the following:
            - 1 lca file containin the process and a couple of xdp files
            - 1 signed xml file
            - 1 Interactive Form (Reader Extended)
            During my further work with the issue I found some strange issues, which you might also encounter when you take a look at the LCA
            1) The PDF/a that I get as output from the process contains the content of the form twice (once without data)
            2) The PDF/a shows up in Reader/Acrobat as a PDF/a, but under “conformance” it states that the status of the PDF is not verified.
            3) The ConvertToPDFA service has issues in Workbench when you choose the “PDFAConversion Options” – if you for instance set “Archive_Always” as your choice for Signatures. Following that choice you save my process, deploy it, click on somewhere else on the canvas and back at “Create PDF/a from Interactive Form”, then Signatures is back to “Archive_as_needed”.
            Also I would like to hear what options I have when I need to convert an interactive PDF containing signed XML into a PDF/a? Do I have any chance of preserving an indication that the form data was digitally signed.
            Thanks in advance
            Cheers
            Kim Christensen
            Dafolo A/S
            Denmark
            • 3. Re: Convert interactive form with digitally signed XML to PDF/a
              kjaeggin Level 2
              Thanks Kim.
              Received and looking into it.
              • 4. Re: Convert interactive form with digitally signed XML to PDF/a
                kjaeggin Level 2
                Kim,
                On your queries:
                1) I was able to obtain valid PDF/A output using your process , but I have a LiveCycle Patch applied (QF 2.94) in my environment. I suggest contacting enterprise support to see about obtaining this patch. The isPDFA field in the result is set to 'true' when I run it.
                A snippent from the validation result.
                <com.adobe.livecycle.docconverter.client.PDFAValidationResult>
                  <isPDFA>true</isPDFA>
                  <jobLog serialization="custom">
                2)  The validation results from docConverter wll be written to the app server log file. They are also contained within the PDFAValidationResult variable. When the doc is opened in Acrobat, you can have preFlight also confirm conformance in Acrobat, and run a report. I can reproduce the 2 pages (one with data, and one without) . Not sure if this is a bug yet, but you should raise this with Adobe Enterprise Support to investigate it further.
                3) The result PDF shows as PDF/a in Acrobat, yes. And is valid. I don't believe the result from docConverter is saved in the result PDF. If you verify conformance in Acrobat, it will come back with a verification succeeded status.
                4) The signatures option 'Archive_Always' does not stick when chosen in toPDFA operation in workbench 9.5, This is a bug and should be brought to the attention of Adobe Support. entrsupp@adobe.com
                Regards,
                KJ
                • 5. Re: Convert interactive form with digitally signed XML to PDF/a
                  Hi again Kevin,
                  Thank you very much for your investigation of the issue. I have contacted Enterprise Support and I am now awaiting their response for the issue.
                  Once again thank you for helping out - I really appreciate it
                  Cheers
                  Kim Christensen
                  Dafolo A/S
                  Denmark
