5 Replies Latest reply on Jun 24, 2011 11:43 PM by Alex_Birchler
    First plugin
    Alex_Birchler
      Hi
      I am trying to create my first
      plugin have the main project that play a video that I have
      in
      local following the OSMF plugin dev guide tutorial, I want to call a simple plugin, just to know
      if I can load
      it plugin has a variable and I want to call it from the main project, but I cant load that
      plugin Gives me and error.
      the plugin
      is at the same position of the video that I am loading, so I think must load
      it now, following that tutorial, I am trying to load a plugin compiled like
      swf anybody help me?
      I copy here the code of the main project.I repeat,
      is working good, and play the video, if I am not loading the
      plugin
        • 1. Re: First plugin
          Alex_Birchler Level 1
          still no answer?
          I am a noob and sorry for that, but I want to learn
          I explain what I can do now:
          I import a projet like StrobeMediaPlayer 1.5 full and I can modify a lot of things and get some variables that I need
          I can also create a simple player, and I can load a plugin containing some buttons to play, stop, pause and so, but is in swc
          I learned to create a simple swc from flash (that file containing the buttons)
          but:
          If I want to load a simple swf like plugin in my simple player, I cant, and I dont know why
          I want just to read a variable from the plug in and send a variable to the plugin, but I cant
          Is there any example or anyone that can help me?
          I am loading with
             var resource:URLResource = new URLResource("sample.swf");
             // Load the plug-in SWF.
             factory.loadPlugin(resource);
            private function onPluginLoad(event:MediaFactoryEvent):void
             trace("Plugin loaded");
             initPlayer();
            private function onPluginLoadError(event:MediaFactoryEvent):void
             trace("Plugin not loaded");
          when I run the project, initplayer() doesnt work
          what I am doing wrong?
          maybe the problem is in the swf?
          is better swc?
          thanx a lot
          • 2. Re: First plugin
            Silviu Vergoti Adobe Employee
            Please use the Plugin developer's guide that you can find in the OSMF documentation - it will help you a lot.
            Also, please check the plugin examples that were provided.
            To pass values to and from a plugin you will could use metadata.
            • 3. Re: First plugin
              Hi Silviu
              thanks for the answer
              As I wrote I am reading and following a lots of tutorials, and I am learning a lot
              but I cant send or receive any data using metadata.
              Of course, I am doing things wrong
              As I wrote I am noob and still learning.
              Can You write here any sinple example of how to send or receive any data between player and the plugin?
              Thanks a lot
              • 4. Re: First plugin
                You might set resource-level metadata, like this:
                                var metadata:Metadata  = new Metadata();
                                metadata.addValue("key", "value");
                                resource.addMetadataValue("namespace.org",metadata);
                and read it from the plugin with getMetadataValue("namespace.org");
                Does this help?
                • 5. Re: First plugin
                  Thanx a lot
                  I was trying with that but I wrote in wrong way
                  Thanx a lot
                  You save my day
