0 Replies Latest reply on Jun 20, 2011 5:04 AM by frederico_35
    Error while installing flash builder 4.5 for php
    frederico_35
      Hello to all.
      Im having a problem while trying to install the flash builder 4.5 for php.... it keeps saying that i have the zend installed in my computer! but i have not... i just have buyed this computer... and it keeps saying that i have the zend installed....
      can someone please help me? I just wanna use this freaking tool!!! =D
      Here is my LOG of installation:
      Visit http://www.adobe.com/go/loganalyzer/ for more information
      START - Installer Session
      RIBS version: 4.0.50.0
      Win OS version: 6.1.0.0 64 bit Type: 1
      ::START TIMER:: [Total Timer]
      CHECK: Single instance running
      CHECK : Credentials
      Load Deployment File
      Create Required Folders
      Assuming uninstall mode
      Lookup for master payload
      Ready to initialize session to start with ...
      ::START TIMER:: [CreatePayloadSession]
      Supported RIBS version range: [0.0.66.0,4.0.50.0]
      ----------------- CreatePayloadSession: machine is x64 ---------------
      ______ Verify Dependency Subscribers ______
      BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
        {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0: 1 (0,1)
        {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0: 1 (0,1)
        {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 1.0.0.0: 1 (0,1)
        {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0: 2 (3,1)
        {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0: 3 (0,1)
        {46DF1D41-88FD-448c-BAC5-6FDA31247378} Adobe Flash Player 10 Plugin 10.0.0.0: 3 (0,1)
        {E5F5A323-E3CA-4710-ABBB-2C0C25516F89} Adobe Player for Embedding 3.2 3.2.0.0: 3 (0,1)
        {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0: 3 (0,1)
        {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0: 3 (0,1)
        {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0: 3 (0,1)
        {067E43CD-3E9C-44BA-89FA-EDE7461BC22B} AIR for Apple iOS support (FB) 2.6.0.0: 4 (0,0)
        {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0: 4 (0,0)
        {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0: 5 (7,0)
      END Operation order for all session payloads: mediaGroup (requires,satisfies)
      Setting property "INSTALLDIR" to: C:\Program Files (x86)\FLASHBUILDER
      Setting property "driverAdobeCode" to: {1B4483F2-849C-4AC3-99B1-473FFC0192DD}
      Setting property "mediaSignature" to: {1B4483F2-849C-4AC3-99B1-473FFC0192DD}
      Found payload actions:
      Deciding what installer mode to use...
      {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 not installed
      {067E43CD-3E9C-44BA-89FA-EDE7461BC22B} AIR for Apple iOS support (FB) 2.6.0.0 not installed
      BEGIN Setting requested payload actions
      Value returned on lookup of payload: {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 is: false
      [    4888] Mon Jun 20 08:30:05 2011  WARN
      DW039: Payload {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 is not installed so should not be there in the deployment file
      [    4888] Mon Jun 20 08:30:05 2011  INFO
      Value returned on lookup of payload: {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0 is: true
      Action string for {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0  is remove
      Selection of payload {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0 is forbidden by the policy. Reason: Free payload
      Value returned on lookup of payload: {067E43CD-3E9C-44BA-89FA-EDE7461BC22B} AIR for Apple iOS support (FB) 2.6.0.0 is: false
      Action string for {067E43CD-3E9C-44BA-89FA-EDE7461BC22B} AIR for Apple iOS support (FB) 2.6.0.0  is none
      Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0 is: true
      Action string for {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0  is none
      Value returned on lookup of payload: {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0 is: true
      Action string for {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0  is none
      Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0 is: true
      Action string for {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0  is none
      Value returned on lookup of payload: {E5F5A323-E3CA-4710-ABBB-2C0C25516F89} Adobe Player for Embedding 3.2 3.2.0.0 is: true
      Action string for {E5F5A323-E3CA-4710-ABBB-2C0C25516F89} Adobe Player for Embedding 3.2 3.2.0.0  is none
      Value returned on lookup of payload: {46DF1D41-88FD-448c-BAC5-6FDA31247378} Adobe Flash Player 10 Plugin 10.0.0.0 is: true
      Action string for {46DF1D41-88FD-448c-BAC5-6FDA31247378} Adobe Flash Player 10 Plugin 10.0.0.0  is none
      Value returned on lookup of payload: {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0 is: true
      Action string for {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0  is none
      Value returned on lookup of payload: {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0 is: true
      Action string for {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0  is none
      Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 1.0.0.0 is: true
      Action string for {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 1.0.0.0  is none
      Value returned on lookup of payload: {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0 is: true
      Action string for {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0  is none
      Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 is: true
      Action string for {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0  is none
      END Setting requested payload actions
      INSTALLDIR passed path basic path validation: C:\Program Files (x86)\FLASHBUILDER
      [    4888] Mon Jun 20 08:30:06 2011  INFO
      BEGIN InstallOperationsQueue Unordered operations
        {067E43CD-3E9C-44BA-89FA-EDE7461BC22B} AIR for Apple iOS support (FB) 2.6.0.0:  with operation none
        {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0:  with operation remove
        {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0:  with operation remove
        {46DF1D41-88FD-448c-BAC5-6FDA31247378} Adobe Flash Player 10 Plugin 10.0.0.0:  with operation remove
        {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0:  with operation remove
        {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 1.0.0.0:  with operation remove
        {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0:  with operation none
        {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0:  with operation remove
        {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0:  with operation remove
        {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0:  with operation remove
        {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0:  with operation remove
        {E5F5A323-E3CA-4710-ABBB-2C0C25516F89} Adobe Player for Embedding 3.2 3.2.0.0:  with operation remove
        {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0:  with operation remove
      END InstallOperationsQueue Unordered operations
      BEGIN InstallOperationsQueue Ordered operations
      END InstallOperationsQueue Ordered operations
      Payloads passed preflight validation.
      Call PreSession Custom Hook
      Calling the custom action code for pre-remove for payload {1B4483F2-849C-4AC3-99B1-473FFC0192DD}
      ::START TIMER:: [Payload Operation :{1B4483F2-849C-4AC3-99B1-473FFC0192DD}]
      [    3776] Mon Jun 20 08:30:06 2011  INFO
      Installer Operation: PayloadUninstaller
      Session {1B4483F2-849C-4AC3-99B1-473FFC0192DD} modify request for AdobeCode: {1B4483F2-849C-4AC3-99B1-473FFC0192DD}
      Effective AdobeCode for: {1B4483F2-849C-4AC3-99B1-473FFC0192DD} is {1B4483F2-849C-4AC3-99B1-473FFC0192DD}
      Uninstalling payload
      Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{1B4483F2-849C-4AC3-99B1-473FFC0192DD}.db
      [    3776] Mon Jun 20 08:30:07 2011  INFO
      Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{1B4483F2-849C-4AC3-99B1-473FFC0192DD}.db
      Physical payload uninstall result:0
      [    4888] Mon Jun 20 08:30:07 2011  INFO
      *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
      :: END TIMER :: [Payload Operation :{1B4483F2-849C-4AC3-99B1-473FFC0192DD}] took 1004.34 milliseconds (1.00434 seconds) DTR = 2732.15 KBPS (2.66812 MBPS)
      Updating driver data - Action: Add driver entry
      Updating driver data successful. Driver entry was added. ARP estimated size 0KB
      User specified overrideFile:
      The csu inventory was not updated for payload {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0, value of local var is -1
      Calling the custom action code for post-remove for payload {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0
      Calling the custom action code for pre-remove for payload {6F3A624B-1B72-4081-96E8-23261F389C5C}
      ::START TIMER:: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}]
      [    6088] Mon Jun 20 08:30:07 2011  INFO
      Session {1B4483F2-849C-4AC3-99B1-473FFC0192DD} modify request for AdobeCode: {6F3A624B-1B72-4081-96E8-23261F389C5C}
      Effective AdobeCode for: {6F3A624B-1B72-4081-96E8-23261F389C5C} is {6F3A624B-1B72-4081-96E8-23261F389C5C}
      Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6F3A624B-1B72-4081-96E8-23261F389C5C}.db
      Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6F3A624B-1B72-4081-96E8-23261F389C5C}.db
      [    4888] Mon Jun 20 08:30:08 2011  INFO
      :: END TIMER :: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}] took 1006.47 milliseconds (1.00647 seconds) DTR = 5250.03 KBPS (5.12699 MBPS)
      [    4888] Mon Jun 20 08:30:09 2011  INFO
      Successfully updated the csu inventory for {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0 return values 0:0
      Calling the custom action code for post-remove for payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0
      Calling the custom action code for pre-remove for payload {7EABC54B-02C3-4DA1-9EB4-974CE7414066}
      ::START TIMER:: [Payload Operation :{7EABC54B-02C3-4DA1-9EB4-974CE7414066}]
      [    1064] Mon Jun 20 08:30:09 2011  INFO
      Installer Operation: ModifyThirdPartyPayloadOperation
      Modify Thirdparty payload
      Payload doesn't support physical action or it is already installed.  Treating as success.
      Third party payload completed.  Testing return code: 0
      [    4888] Mon Jun 20 08:30:10 2011  INFO
      *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
      :: END TIMER :: [Payload Operation :{7EABC54B-02C3-4DA1-9EB4-974CE7414066}] took 1014.44 milliseconds (1.01444 seconds)
      The csu inventory was not updated for payload {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0, value of local var is -1
      Calling the custom action code for post-remove for payload {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0
      Calling the custom action code for pre-remove for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923}
      ::START TIMER:: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}]
      [    4696] Mon Jun 20 08:30:10 2011  INFO
      Session {1B4483F2-849C-4AC3-99B1-473FFC0192DD} modify request for AdobeCode: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
      Effective AdobeCode for: {BD0D6363-E961-410F-8BF4-ECD8795F3923} is {BD0D6363-E961-410F-8BF4-ECD8795F3923}
      Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BD0D6363-E961-410F-8BF4-ECD8795F3923}.db
      Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BD0D6363-E961-410F-8BF4-ECD8795F3923}.db
      [    4888] Mon Jun 20 08:30:11 2011  INFO
      :: END TIMER :: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}] took 1009.85 milliseconds (1.00985 seconds) DTR = 6947.54 KBPS (6.78471 MBPS)
      Successfully updated the csu inventory for {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0 return values 0:0
      Calling the custom action code for post-remove for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0
      Calling the custom action code for pre-remove for payload {E5F5A323-E3CA-4710-ABBB-2C0C25516F89}
      ::START TIMER:: [Payload Operation :{E5F5A323-E3CA-4710-ABBB-2C0C25516F89}]
      [    2788] Mon Jun 20 08:30:11 2011  INFO
      Session {1B4483F2-849C-4AC3-99B1-473FFC0192DD} modify request for AdobeCode: {E5F5A323-E3CA-4710-ABBB-2C0C25516F89}
      Effective AdobeCode for: {E5F5A323-E3CA-4710-ABBB-2C0C25516F89} is {E5F5A323-E3CA-4710-ABBB-2C0C25516F89}
      Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{E5F5A323-E3CA-4710-ABBB-2C0C25516F89}.db
      Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{E5F5A323-E3CA-4710-ABBB-2C0C25516F89}.db
      [    4888] Mon Jun 20 08:30:12 2011  INFO
      :: END TIMER :: [Payload Operation :{E5F5A323-E3CA-4710-ABBB-2C0C25516F89}] took 1019.34 milliseconds (1.01934 seconds) DTR = 18765.1 KBPS (18.3253 MBPS)
      Successfully updated the csu inventory for {E5F5A323-E3CA-4710-ABBB-2C0C25516F89} Adobe Player for Embedding 3.2 3.2.0.0 return values 0:0
      Calling the custom action code for post-remove for payload {E5F5A323-E3CA-4710-ABBB-2C0C25516F89} Adobe Player for Embedding 3.2 3.2.0.0
      Calling the custom action code for pre-remove for payload {46DF1D41-88FD-448c-BAC5-6FDA31247378}
      ::START TIMER:: [Payload Operation :{46DF1D41-88FD-448c-BAC5-6FDA31247378}]
      [    4788] Mon Jun 20 08:30:12 2011  INFO
      [    4888] Mon Jun 20 08:30:13 2011  INFO
      :: END TIMER :: [Payload Operation :{46DF1D41-88FD-448c-BAC5-6FDA31247378}] took 1006.47 milliseconds (1.00647 seconds)
      The csu inventory was not updated for payload {46DF1D41-88FD-448c-BAC5-6FDA31247378} Adobe Flash Player 10 Plugin 10.0.0.0, value of local var is -1
      Calling the custom action code for post-remove for payload {46DF1D41-88FD-448c-BAC5-6FDA31247378} Adobe Flash Player 10 Plugin 10.0.0.0
      Calling the custom action code for pre-remove for payload {551D0A52-5E4A-4898-9FFF-FEAA5E89585A}
      ::START TIMER:: [Payload Operation :{551D0A52-5E4A-4898-9FFF-FEAA5E89585A}]
      [     664] Mon Jun 20 08:30:13 2011  INFO
      [    4888] Mon Jun 20 08:30:14 2011  INFO
      :: END TIMER :: [Payload Operation :{551D0A52-5E4A-4898-9FFF-FEAA5E89585A}] took 1009.34 milliseconds (1.00934 seconds)
      The csu inventory was not updated for payload {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0, value of local var is -1
      Calling the custom action code for post-remove for payload {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0
      Calling the custom action code for pre-remove for payload {ED28819E-310F-4F17-925C-C69B0A1C1F7F}
      ::START TIMER:: [Payload Operation :{ED28819E-310F-4F17-925C-C69B0A1C1F7F}]
      [    5256] Mon Jun 20 08:30:14 2011  INFO
      Session {1B4483F2-849C-4AC3-99B1-473FFC0192DD} modify request for AdobeCode: {ED28819E-310F-4F17-925C-C69B0A1C1F7F}
      Effective AdobeCode for: {ED28819E-310F-4F17-925C-C69B0A1C1F7F} is {ED28819E-310F-4F17-925C-C69B0A1C1F7F}
      Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{ED28819E-310F-4F17-925C-C69B0A1C1F7F}.db
      [    5256] Mon Jun 20 08:30:15 2011  INFO
      Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{ED28819E-310F-4F17-925C-C69B0A1C1F7F}.db
      [    4888] Mon Jun 20 08:30:15 2011  INFO
      :: END TIMER :: [Payload Operation :{ED28819E-310F-4F17-925C-C69B0A1C1F7F}] took 1014.14 milliseconds (1.01414 seconds) DTR = 15709.9 KBPS (15.3417 MBPS)
      [    4888] Mon Jun 20 08:30:16 2011  INFO
      Successfully updated the csu inventory for {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0 return values 0:0
      Calling the custom action code for post-remove for payload {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0
      Calling the custom action code for pre-remove for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
      ::START TIMER:: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}]
      [     304] Mon Jun 20 08:30:16 2011  INFO
      [    4888] Mon Jun 20 08:30:17 2011  INFO
      :: END TIMER :: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}] took 1012.73 milliseconds (1.01273 seconds)
      The csu inventory was not updated for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 1.0.0.0, value of local var is -1
      Calling the custom action code for post-remove for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 1.0.0.0
      Calling the custom action code for pre-remove for payload {B6D38690-755E-4F40-A35A-23F8BC2B86AC}
      ::START TIMER:: [Payload Operation :{B6D38690-755E-4F40-A35A-23F8BC2B86AC}]
      [    3496] Mon Jun 20 08:30:17 2011  INFO
      [    4888] Mon Jun 20 08:30:18 2011  INFO
      :: END TIMER :: [Payload Operation :{B6D38690-755E-4F40-A35A-23F8BC2B86AC}] took 1004.29 milliseconds (1.00429 seconds)
      The csu inventory was not updated for payload {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0, value of local var is -1
      Calling the custom action code for post-remove for payload {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0
      Calling the custom action code for pre-remove for payload {08D2E121-7F6A-43EB-97FD-629B44903403}
      ::START TIMER:: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}]
      [    2844] Mon Jun 20 08:30:18 2011  INFO
      [    4888] Mon Jun 20 08:30:19 2011  INFO
      :: END TIMER :: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}] took 1019.87 milliseconds (1.01987 seconds)
      The csu inventory was not updated for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0, value of local var is -1
      Calling the custom action code for post-remove for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0
      No operation.  We're done:
      Updating driver data - Action: Remove driver entry
      Updating driver data successful. Driver entry was removed. ARP estimated size 0KB
      [    4888] Mon Jun 20 08:30:21 2011  INFO
      Total components installed: 0
      Total components repaired: 0
      Successfully removed 11 components:
      - Microsoft_VC90_CRT_x86
      - Adobe Flash Builder
      - Adobe Flash Player 10 Plugin
      - Adobe Flash Player 10 ActiveX
      - Microsoft_VC90_MFC_x86
      - AdobeTypeSupport CS5
      - AdobeHelp
      - Microsoft_VC90_MFCLOC_x86
      - AdobeCMaps CS5
      - Adobe Player for Embedding 3.2
      - Suite Shared Configuration CS5.5
      Restarting your computer is recommended:
      In order to complete the installation, please restart the computer
      Call PostSession Custom Hook
      :: END TIMER :: [Total Timer] took 16246.8 milliseconds (16.2468 seconds) DTR = 3085.89 KBPS (3.01357 MBPS)
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 0 error(s), 1 warning(s)
      WARNING: DW039: Payload {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 is not installed so should not be there in the deployment file
      Please search the above error/warning string(s) to find when the error occurred.
      These errors resulted in installer Exit Code mentioned below.
      Exit Code: 0 - No error.
      END - Installer Session
