5 Replies Latest reply on Jun 20, 2011 12:51 PM by Harbs.
    Subtracting 5mm from pagewidth CS4
    TᴀW Adobe Community Professional & MVP
      Hi there.
      I've got the page width of a document:
      app.activeDocument.documentPreferences.pageWidth
      I would like to subtract 5mm from it.
      How do I do that?
      I can't set the ruler units, because this script is running in a ScripUI dialog box that's running while the user is able to work in InDesign (using #targetengine)
      Now, app.activeDocument.documentPreferences.pageWidth - "5mm" doesn't work.
      So it looks like I have to use a UnitValue object.
      But
      x = UnitValue (5, "mm")
      app.activeDocument.documentPreferences.pageWidth - x
      doesn't work either.
      So it looks like I need to convert the pageWidth into a UnitValue also.
      But how do I know what units are being used?
      The only option I can see is to go through all the possible MeasureUnits enumerations and compare.
      But is there a simpler way of doing all this?
      Many thanks,
      Ariel
        • 1. Re: Subtracting 5mm from pagewidth CS4
          Peter Kahrel Adobe Community Professional & MVP
          app.scriptPreferences.MeasurementUnits = MeasurementUnits.millimeters
          app.activeDocument.documentPreferences.pageWidth -= 5;
          Peter
          • 2. Re: Subtracting 5mm from pagewidth CS4
            Harbs. Level 6
            That .MeasurementUnits should have been .measurementUnits...
            Be very careful not to mess up existing scripts with this!!!
            I'd always wrap these changes in a try/catch/finally:
            try{
              var scriptUnits = app.scriptPreferences.measurementUnits;
              app.scriptPreferences.measurementUnits = MeasurementUnits.millimeters
            }catch(err){}
            finally{
              app.scriptPreferences.measurementUnits = scriptUnits;
            • 3. Re: Subtracting 5mm from pagewidth CS4
              And so it should have been indeed.
              As to your other comment, I don't see the harm to other scripts in setting the measurement units: the units are set just for the script you're running. But, bother, does it maybe set the units for the session? Anyway, every script should set its own measurements.
              Peter
              • 4. Re: Subtracting 5mm from pagewidth CS4
                Thanks very much guys. I didn't know about scriptPreferences. Looks like
                that should do the trick!
                • 5. Re: Subtracting 5mm from pagewidth CS4
                  Harbs. Level 6
                  scriptPreferences.measurementUnits didn't exist prior to version 7 (I think). Legacy scripts all use viewPreferences.verticalMeasurementUnits and viewPreferences.horizontalMeasurementUnits. With scriptPreferences set to a different measurement unit, things will start to break in weird and unexpected ways.
                  I don't know about you, but I have not updated all my scripts to take this into account...
                  I'd always make sure that the value is returned to AutoEnum.AUTO_VALUE at all costs...
                  Harbs
