2 Replies Latest reply on Jun 20, 2011 11:18 PM by John Hawkinson
    How to select "next object below"?
    Kan7
      Hi all,
      I have selected group objects then How to select "next object below" frames using javascript in indesign cs3?
        • 1. Re: How to select "next object below"?
          milligramme Level 3
          Hi
          I interpreted you request as this figure below.
          It works for me IDCS3 OSX 10.6.7
          groupobject ( pageitem A-E)
            ├pageitem A
            ├pageitem B
            ├pageitem C
            ├pageitem D
            ├pageitem E
          1. Current selection is B and run script.
          2. C is selected
          3. And then, current selection is E and run script.
          4. A is selected
          // select a pageitem in group object
          if (app.selection.length === 0) {exit();};
          if (app.selection[0].parent.constructor.name !== 'Group') {exit()};
          var current_sel = app.selection[0];
          var current_id = current_sel.id;
          var parent_group = current_sel.parent;
          for (var i=0, iL=parent_group.pageItems.length; i < iL ; i++) {
               if (parent_group.pageItems[i].id === current_id) {// current object
                    // select next object
                    if (i+1 < iL) {
                         parent_group.pageItems[i+1].select();
                    else { // if selected last object, select first object
                         parent_group.pageItems[0].select();
          thank you
          mg.
          • 2. Re: How to select "next object below"?
            John Hawkinson Level 5
                      if (i+1 < iL) {
            Instead, just use the modulo (remainder) operator, % sign.:
            parent_grouppageItems[(i+1)%iL].select()
