0 Replies Latest reply on Jun 20, 2011 11:22 AM by ryan028
    MPE GPU renders interlacing artifacts
    ryan028
      I got a 60D and a Sony DV for shooting videos of some events.
      And I shot the videos using the 60D with 720p50 setting, and the DV was on 1080i50.
      What I tried to do is to produce a DVD that will have "smooth" motion instead of the 25 fps feel.
      So I drag these two file to a 50i sequence, then export it as H264 1080p25 for an hi-def internet copy.
      But I have found that the video includes interlacing artifacts in the 60d shot.
      These are the exported results that I re-import the exported video into Premiere to capture the same frame:
      And so I tried to put the videos into a AVCHD 1080p50
      which works out very well.
      Here's the problem, when I turn the MPE to software only mode...
      It does not have the problem which happened when MPE GPU Accel. enabled.
      I remembered that the problem wasn't there on CS5,
      I can mix different framerate sources in CS5 with GPU enabled but not in CS5.5 now.
      I also told a friend which have the same kind of video as mine,
      the problem is happening on his computer too.
      I wonder if this is a bug of CS5.5 MPE? or it is only happening to me and my friend?
