6 Replies Latest reply on Jun 26, 2011 1:48 PM by artshocx
    xdcam footage in Ppro CS5
    Rossiter
      I've been sent some NTSC XDCAM footage for use in a multi-national programme.
      Ppro allows me to import it.
      The first couple of seconds plays, then the screen becomes so covered in green artifacts it's impossible to see anything.
      It's not just a small area of green - it's almost the whole screen.
      Ppro doesn't like it... I tried to export a section to show what I see, but it shut down.
      I've already bought Calibrated XD for other footage, following on from help here. But the programme isn't helping with this footage.
      Can anyone suggest how to use the footage?
      In case it helps, I get this info from MediaInfo: Thanks very much
      General
      Complete name                    : J:\PUK_Naylor\Supplied Footage\NSG_files\file1_1.mov
      Format                           : MPEG-4
      Format_Commercial_IfAny          : XDCAM EX 35
      Format profile                   : QuickTime
      Codec ID                         : qt
      File size                        : 1.76 GiB
      Duration                         : 6mn 58s
      Overall bit rate                 : 36.1 Mbps
      Encoded date                     : UTC 2011-06-09 12:42:53
      Tagged date                      : UTC 2011-06-09 12:44:41
      Writing library                  : Apple QuickTime
      ©TSC                             : 2997
      ©TSZ                             : 100
      Video
      Format                           : MPEG Video
      Format version                   : Version 2
      Format profile                   : Main@High
      Format settings, BVOP            : Yes
      Format settings, Matrix          : Default
      Codec ID                         : xdvb
      Codec ID/Hint                    : XDCAM
      Duration                         : 6mn 58s
      Bit rate mode                    : Variable
      Bit rate                         : 35.0 Mbps
      Width                            : 1 888 pixels
      Original width                   : 1 920 pixels
      Height                           : 1 062 pixels
      Original height                  : 1 080 pixels
      Display aspect ratio             : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 29.970 fps
      Standard                         : Component
      Color space                      : YUV
      Chroma subsampling               : 4:2:0
      Bit depth                        : 8 bits
      Scan type                        : Interlaced
      Scan order                       : Top Field First
      Compression mode                 : Lossy
      Bits/(Pixel*Frame)               : 0.582
      Stream size                      : 1.68 GiB (96%)
      Title                            : Apple ƒrƒfƒIEƒƒfƒBƒAƒnƒ“ƒhƒ‰ / Apple ƒGƒCƒŠƒAƒXEƒf[ƒ^ƒnƒ“ƒhƒ‰
      Language                         : English
      Audio
      Format                           : PCM
      Format settings, Endianness      : Little
      Format settings, Sign            : Signed
      Codec ID                         : sowt
      Duration                         : 6mn 58s
      Bit rate mode                    : Constant
      Bit rate                         : 1 536 Kbps
      Channel(s)                       : 2 channels
      Sampling rate                    : 48.0 KHz
      Bit depth                        : 16 bits
      Stream size                      : 76.6 MiB (4%)
      Title                            : Apple ƒTƒEƒ“ƒhEƒƒfƒBƒAƒnƒ“ƒhƒ‰ / Apple ƒGƒCƒŠƒAƒXEƒf[ƒ^ƒnƒ“ƒhƒ‰
      Language                         : English
      Menu
      Title                            : Time Code ƒƒfƒBƒAƒnƒ“ƒhƒ‰ / Apple ƒGƒCƒŠƒAƒXEƒf[ƒ^ƒnƒ“ƒhƒ‰
      Language                         : English
      Encoded date                     : UTC 2011-06-09 12:44:41
        • 1. Re: xdcam footage in Ppro CS5
          Eric Addison User Group Manager
          Can you give a little more info - what camera was this shot with? Was the original footage transcoded to Quicktime files? I noticed that the file name is \file1_1.mov. As someone who shoots with XDCAM EX cameras, I'm pretty sure those cameras don't create .mov files, unless something has changed in one of the newer models. If you transcoded the footage, it could be a codec issue. PPro works best with the native files created by the camera,
          See if you can import the entire, orginal BPAV folder created by the camera into PPro, and see if that gives you better results.
          • 2. Re: xdcam footage in Ppro CS5
            Rossiter Level 1
            Eric, I can't obtain the original files, nor any further info about them -
            it was shot in Japan on behalf of my client, and it's taken long enough to
            get this far!
            After a lot of Googling last night, I downloaded a programme called "Super"
            (by eRightSoft) which has just successfully converted the first clip to an
            mp4 with no green artifacts.
            I need to experiment more with the settings (for instance, as the original
            footage is NTSC and I need PAL in the end, I'm not sure at what point to do
            this conversion - with "Super" or with Media Encoder)
            So, changing the topic, do you have any advice on the best way to deal with
            NTSC footage on a PAL timeline - where would the conversion best take place?
            Many thanks, Linda
            • 3. Re: xdcam footage in Ppro CS5
              Many thanks, Linda
              Sorry for the delay in responding - things are busy!
              I've always felt that the best place to do the conversion is NOT in the NLE. Edit your video in whatever format you shot it in, then take it to a professional post house that does that sort of conversion. I think you'll get much better results that way.
              If you don't want to do that (or budget doesn't allow it), then I'd edit NTSC and then export out a PAL file...run some quick tests so you can see how things will look first.
              Others on the forum may have better advice - this isn't something I've done that much (or recently), so there may be other options out there.
              Good luck!
              • 4. Re: xdcam footage in Ppro CS5
                artshocx
                this sounds like the same thing that happened to me with XDCAM footage earlier this year only in After Effects. did you ever figure it out? because it's happening to me again too. thanks.
                • 5. Re: xdcam footage in Ppro CS5
                  Rossiter Level 1
                  Hi, yes I converted the footage using a free programme I found called  "Super"
                  (by eRightSoft) - Google it.
                  I had to experiment with the output settings for a while, but eventually I
                  found that an mp4 file at original size worked well enough for me.
                  Thanks, Linda
                  • 6. Re: xdcam footage in Ppro CS5
                    artshocx Level 1
                    thanks Linda, i am just converting the footage to ProRes directly out of the Final Cut Pro timeline which is convenient enough. i guess i was just hoping that maybe Adobe had found a fix LOL – sigh… i remember the same thing was happening in Adobe Media Encoder and they had suggested a fix for that, deleting the ImporterFastMPEG decoder, but this doesn't seem to work for the After Effects issue, or it didn't for me so… really the only thing inconvenient about it other than the time to encode, is that the file sizes are so much bigger otherwise, no big deal really. thanks.
