5 Replies Latest reply on Jun 22, 2011 7:43 AM by P.o.l.a.c.o
    End to End Communication with RTMFP problem
    P.o.l.a.c.o
      Hi!
      I have created a test app following this tutorial video
      http://tv.adobe.com/watch/adc-presents/control-the-desktop-with-your-mobile-device/
      On Friday it was working properly, suddenly it has just stoped working.
      The problem is that when I start 2 browsers (on the same pc) with the app the group neighbours does not seem to see each other since no notifications are received.
      Can anyone give it a try?
      What could be going on? I have tried disabling firewalls and antivirus with no luck.
      I'm using Flash Builder 4.5.
      This is all the code of the test web app:
         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" applicationComplete="connect()">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import flash.utils.getTimer;
      private var connection:NetConnection;
      private var group:NetGroup;
      private var isConnected:Boolean = false;
      private var netStream:NetStream;
      private var groupspec:GroupSpecifier = null;
      private function connect():void{
      connection = new NetConnection();
      connection.addEventListener(NetStatusEvent.NET_STATUS, netStatus);
      connection.connect("rtmfp:");
      private function netStatus(event:NetStatusEvent):void{
      var infoCode:String = event.info.code;
      log(infoCode);
      switch(infoCode){
      case "NetConnection.Connect.Success":
      setupGroup();
      break;
      case "NetGroup.Connect.Success":
      break;
      case "NetGroup.SendTo.Notify":
      break;
      private function setupGroup():void{
      groupspec = new GroupSpecifier("localConnectionsTest");
      groupspec.routingEnabled = true;
      groupspec.ipMulticastMemberUpdatesEnabled = true;
      groupspec.addIPMulticastAddress("224.255.0.0",35353);
      groupspec.multicastEnabled = true;
      group = new NetGroup(connection, groupspec.groupspecWithAuthorizations());
      group.addEventListener(NetStatusEvent.NET_STATUS, netStatus);
      private function log(str:String):void{
      txt.appendText( str + "\n");
      protected function sendMessage(event:MouseEvent):void
      log("NeighborCount " + group.neighborCount);
      group.sendToAllNeighbors("Hello! " + getTimer());
      </fx:Script>
      <s:layout>
      <s:VerticalLayout />
      </s:layout>
      <s:TextArea id="txt" width="500" height="400"/>
      <s:Button label="Send" fontSize="25" click="sendMessage(event)"/>
      </s:Application>
