7 Replies Latest reply on Jun 20, 2011 3:52 PM by RGB2CMYK2
    Audio problem
    RGB2CMYK2 Level 1
      I am using PrEl 9. Everything's fine but the audio has a bit problem after I imported it. In the first clip, the first sentence " The standard tool..." sounds like "The st-standard tool...". It happened to the second clip too but not for the 3rd and the 4th clip.
      May I know the reason why? Thanks!
        • 1. Re: Audio problem
          the_wine_snob Level 9
          Can you give us the complete details of the Source Files with the problem, your Project's Preset, and also exactly how you ingested the Clips into PrE?
          • 2. Re: Audio problem
            RGB2CMYK2 Level 1
            The attached screenshot is my project setting. I set it to something else at the beginning. After I "Get Media" from my desktop and dragged the movie clip to the timeline stage, the software autometically fixed my setting to match the video setting.
            Then when I started playing the video by clicking "space" key, that problem just happened.  But if I right clicked and chosed "Edit original", the original clip doesn't have that "st-standard" sound like an echo.
            • 3. Re: Audio problem
              Is the Audio in those Clips 48KHz 16-bit, or something else?
              When you used Get Media, did you wait for Conforming to complete 100%?
              In your Project's Timeline, are there any red lines above the Clips?
              If so, I would Render the Timeline, which will Render both Audio & Video on the Timeline.
              Also, what is the speed of the HDD, where these Clips are located?
              • 4. Re: Audio problem
                RGB2CMYK2 Level 1
                Here's the audio info:
                Yes I waited until it's completed and there's no red lind above those clips. It's still there even after rendering.
                Those clips are located in my hard drive.
                • 5. Re: Audio problem
                  OK, that is DD 5.1 SS, which will be AC3.
                  Did you set up your Project as AVCHD w/ 5.1 Audio?
                  • 6. Re: Audio problem
                    Is that HDD a 7200 RPM (or higher), or is it 5400 RPM?
                    • 7. Re: Audio problem
                      RGB2CMYK2 Level 1
                      The HDD is 7200RPM. And no I didn't set it as "AVCHD w/ 5.1 channel". Does it matter? Coz when I dragged the video clip on the timeline, it asked me if I want to fix the setting to match the video setting. I clicked "yes".
                      And I tried to start the new project with "AVCHD w/ 5.1 channel", the problem still there.
