• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFMX 6.1 and Cross-Site Scripting via URL
Guest
Jun 04, 2007 Jun 04, 2007
I hav been trying to block a vulnerability on our site that was reported by our scanning software.
The example they gave was:
http:www.ourSite.com//index.cfm?fuseaction=shoppingCart.landingPage&block=>'><script>alert(11799913.8357)</script>&CFID=11381673&CFTOKEN=a619bacd140fcfd4
So that the '<scrript>alert(11799913.8357)</script>' part of the url triggers the Alert popup, which - I guess means that the site is vulnerable for something more nasty to be injected.
I have code to deal with url variables beling cleaned up in the application.cfm file, but nothing seems to block this bugger. Anyone else been down this path??
TOPICS
Advanced techniques
Views
844
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
> scanning software.
> down this path??
What version of CF are you on? The latest version has a cross scripting
blocking feature in the administrator.
Votes
Translate
Translate
Report
Report
LEGEND ,
htmlcodeformat() or htmleditformat()
Votes
Translate
Translate
Report
Report
Guest
version is 6.1 as in my post title.
htmlcodeformat() or htmleditformat() will not work, event happens before chance to throw code at it... try it in your site url and see.
Votes
Translate
Translate
Report
Report
LEGEND ,
have you tried the cf_inputfilter custom tag?
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_17502
http://download.macromedia.com/pub/security/coldfusion/all_versions/inputfilter.zip
HTH
Tim Carley
www.recfusion.com
info@NOSPAMINGrecfusion.com
Votes
Translate
Translate
Report
Report
Guest
CF_inputfilter no good for this, that is for forms inputs and links, not for something injected into browser url by hand. I think I need to find some javascript that blocks url-injected scripts. I'm gonna play with this bit next, looks close to what I need...
http://userjs.org/scripts/browser/enhancements/safe-alert
Thanks for the suggestion tho.
Votes
Translate
Translate
Report
Report
LEGEND ,
<cf_inputFilter
scopes = "[FORM][,COOKIE][,URL]"
chars = "list_of_chars"
tags = "ALL|list_of_tags">
it works for URLs, but, do whatever you need to get there.
Tim Carley
www.recfusion.com
Votes
Translate
Translate
Report
Report
Guest
thanks for the info, I will try it. So far thos this seems to trigger the alert box BEFORE any chance to manipulate url vars. I'll post back my results.
Votes
Translate
Translate
Report
Report
Guest
I tried cf_inputfilter, did not work for this,
<cf_inputFilter scopes = "URL" tags = "ALL">
also i tried the javascript bit at http://userjs.org/scripts/browser/enhancements/safe-alert, no luck with either.
Votes
Translate
Translate
Report
Report
Advocate ,
Jun 05, 2007 Jun 05, 2007
How are you using the variable "block"? It seems like, you should be able to put some code in the application.cfc / application.cfm file that filters the values of the variables passed via URL. I'm not that familiar with cf_inputfilter, but it seems like as long as you are using it (or a similar UDF - check cftips.com?) before the variable "block" is placed in the HTML code it should filter it out for you.
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
>thanks for the info, I will try it. So far thos this seems to trigger the alert box >BEFORE any chance to manipulate url vars. I'll post back my results
That's not actually possible, since the alert() is a javascript function (i.e. runs on the browser) and your code is server side (i.e. runs first). What's more likely is that your adding your filtering code too late in the application process flow.
Take a look in your HTML code for your compiled page and see where your alert() box is being inserted. It seems probable that your variable may be called from an include or an application file before it gets to your template (especially probable if you are using fusebox).
Trackdown where your variable is being used and then put your filter BEFORE that in the CF code.
Votes
Translate
Translate
Report
Report
Resources
Documentation
