1 Reply Latest reply on Jun 21, 2011 6:50 AM by kglad
    Understanding this piece of code
    azzic7
      Hi all,
      I have got some code, but don't quite understand all the lines, any chance of helping me out?
      Code
      onClipEvent (load) {
      var grav:Number = 0;
      var speed:Number = 5;
      var jumpHeight:Number = 13;
      //initalise variables to be used to move and jump
      onClipEvent (enterFrame) {
      grav++;
      _y += grav;
      while (_root.ground.hitTest(_x, _y, true)) {
      _y--;
      grav = 0;
      // don't quite understand what this does
      if (Key.isDown(Key.RIGHT)) {
      _x += speed; //move to the right
      } else if (Key.isDown(Key.LEFT)) {
      _x -= speed; //move to the left
      if (Key.isDown(Key.UP) && _root.ground.hitTest(_x, _y+3, true)) {  // what does y+3 do?
      grav = -jumpHeight;
      _y -= 4;  // if y-=4 is removed it makes no effect
        • 1. Re: Understanding this piece of code
          Code
          grav++;
          _y += grav; // with above line accerlates this movieclip towards stage bottom
          while (_root.ground.hitTest(_x, _y, true)) {  // if this movieclip "hits" _root.ground
          _y--; // move up.  this repeats until this movieclip no longer "hits" _root.ground
          grav = 0;
          // in total this stops your movieclip's acceleration towards stage-bottom and prevents it from being below ground
          //this hittest checks if this movieclip is within 3px above the ground.  ie, almost hitting
          grav = -jumpHeight;
          // if you don't see the effect of the below, it's because other code continues moving this movieclip up
