Hello,
I am having issues with a project originally authored in FB4, and migrated into the new FB4.5.1 framework. I migrated it according to the protocols, but still get an error. While running the project, there is a point when a user clicks on an image and then a handler should take them to a new view. Now, when they click, the following runtime error message appears -
TypeError: Error #1009: Cannot access a property or method of a null object reference. at spark.components::Scroller/focusInHandler()
If I click on "continue" (I am running Flash player debug), the application appears to work properly. Any idea what this error message might be, and how I might fix some of the code to address it? Thank you.
Hi!
I found a solution for my case, hope it fits you.
I'm using a TextArea in a host component that is being used as a PopUp. Changing this host component to a BorderContainer solved the problem.
Hope it helps.
Best regards,
Jorge
Thank you for the reply, Jorge.
I'm not using any pop-ups, but o will double check host components. Thanks for the thought.
Best
Bob
Sent from my Verizon Wireless 4GLTE smartphone
