This content has been marked as final.
Show 2 replies
1. Re: Templates and editable regions- I'm a beginnner
Newsgroup_User Aug 15, 2006 1:02 PM (in response to two8616)two8616 wrote:
> I have created a nav bar in Fireworks and then made it into a template in
> Dreamweaver. Now I am adding content to the website but I cannot insert an
> editable region. I'm not sure if it's something I did wrong in fireworks or if
> I'm doing something wrong in dreamweaver. Do I need to add extra slices in
> Fireworks or something? I just cannot get dreamweaver to select the area I
> want for an editable region. I have no experience using any code. I have done
> everything graphically thus far. If you can offer any advice or tutorials,
> that would be great. Thanks
You need to learn some basic code in order to be able to do this. At
least enough to get a sense of what kinds of "containers" your editable
content will need, e.g., paragraphs <p></p>, divs, tables and their
cells, etc.
For a quick lesson, do this (relatively) simple tutorial:
http://www.projectseven.com/tutorials/css/css_td/index.htm
Bonnie
in California
8 ^ ) -
2. Re: Templates and editable regions- I'm a beginnner
Newsgroup_User Aug 15, 2006 4:19 PM (in response to two8616)"two8616" <webforumsuser@macromedia.com> wrote:
To insert an editable region, you have to edit the original template. You can
only insert an editable region in code derived from a template if you put it
inside an editable region (in which case the original editable region
disappears), and it only has a meaning if you are saving the new file as a
derived template.
Clancy
