0 Replies Latest reply on Nov 8, 2006 1:31 AM by Marcanti
    Textfield redraw bug caused by text overflow
      Situation: I have a runtime created movieclip with a dynamic textfield contained in it. Some fonts types cause overflow in the textfield (part of the text is drawed outside the textfield area) causing a redraw bug when dragging the movieclip. The overlow occurs on the left / right side of the textfield but only for certain characters (because they are wider then usual).
      If you have a textfield with the text "f" using the New Timer Roman font, an overflow will occur on the right side of the textfield, causing the above redraw bug. For other fonts the bug also happen on the left side.
      The problem is solved by recreating the movieclip, but I am dragging the movieclip so I will apreciate if someone have a better solution...
