7 Replies Latest reply on Jun 27, 2011 8:12 AM by fingersmagoo
    List Selected Index not correct
    fingersmagoo
      Hello
      I have a List with a custom ItemRenderer.  When I fire the lstMessages_changeHandler(event:IndexChangeEvent):void event the selectedItem is always teh first one in the list.  Once it is fired, it will not fire again.  It seems like a simple thing to get the selected item...but I am at a loss.
      Thank you in advance,
      Paul
      ////View Code
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark" title="The Wall" creationComplete="init()">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import com.facebook.graph.Facebook;
      import com.facebook.graph.FacebookMobile;
      import com.trinet.bl.BusinessLogic;
      import mx.binding.utils.BindingUtils;
      import mx.collections.*;
      import mx.managers.CursorManager;
      import spark.events.IndexChangeEvent;
      import mx.events.FlexEvent;
      import mx.events.ItemClickEvent;
      private static var bl:BusinessLogic = BusinessLogic.getInstance();
      [Bindable]
      public var messages:ArrayCollection;
      protected function init():void
      bl.wallView=this;
      bl.getWallPosts();
      protected function btnAdd_clickHandler(event:MouseEvent):void
      CursorManager.setBusyCursor();
      bl.addWallPost();
      CursorManager.removeBusyCursor();
      protected function lstMessages_changeHandler(event:IndexChangeEvent):void
      //var action:Object = lstMessages.selectedItem;
      //navigator.pushView(WallPostDetail, lstMessages.getChildAt(event.newIndex));
      trace (event.newIndex);
      </fx:Script>
      <s:Label id="lblMessage" left="10" right="10" top="10" text="Enter Message"/>
      <s:Button id="btnAdd" right="12" top="39" label="Add" click="btnAdd_clickHandler(event)"/>
      <s:TextArea id="txtMessage" left="10" right="96" top="34"/>
      <s:List id="lstMessages" left="10" right="10" top="116" bottom="6"
      change="lstMessages_changeHandler(event)" dataProvider="{messages}" fontSize="20"
      itemRenderer="renderer.WallItemRenderer" labelField="message"></s:List>
      </s:View>
      ////ItemRenderer Code
      <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark">
      <fx:Script>
      <![CDATA[
      import mx.core.FlexGlobals;
      import spark.components.List;
      [Bindable]
      public var myBGColor:int = 0xFFFFFF;
      private var mydata:Object;
      override public function set itemIndex(value:int):void
      if ((value%2) == 0)
      myBGColor= 0xFFFFFF;
      if ((value%2) == 1)
      myBGColor= 0xCCFF66;
      override public function set data(value:Object):void
      mydata=value;
      lblMessage.text = value.message;
      var comments:Array = value.comments.comment_list;
      lblComments.text=lblComments.text+value.comments.count;
      lblLikes.text=lblLikes.text+value.likes.count;
      </fx:Script>
      <s:Rect id="myRect" left="0" right="0" top="0" bottom="0" alpha="1.0">
      <s:stroke>
      <s:SolidColorStroke color="0xA8C6EE" weight="1"/>
      </s:stroke>
      <s:fill>
      <s:SolidColor color="{myBGColor}"/>
      </s:fill>
      </s:Rect>
      <s:Label id="lblMessage" left="5" top="5" bottom="21" width="458" fontSize="15" text="Label"
      textAlign="left" verticalAlign="top"/>
      <s:Label id="lblComments" left="10" bottom="1" height="12" fontSize="12" text="Comments: "/>
      <s:Label id="lblLikes" left="111" bottom="1" fontSize="12" text="Likes: "/>
      </s:ItemRenderer>
        • 1. Re: List Selected Index not correct
          Shongrunden Adobe Employee
          I can't compile this example, can you please post a complete, compilable sample application so I can investigate further?
          • 2. Re: List Selected Index not correct
            fingersmagoo Level 1
            Hello,
            Is there a way to send you the app via zip file?
            Paul
            • 3. Re: List Selected Index not correct
              OK, I slimmed it down.  It does not register the correct selected index and it will not allow you to click more than once.
              ListDebugHomeView
              xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView" creationComplete="init()">
              <fx:Script>
              <![CDATA[
              [Bindable]
              protected function lstPosts_changeHandler(event:IndexChangeEvent):void
              messages = new ArrayCollection();
              messages.addItem("test1");
              messages.addItem("test2");
              messages.addItem("test3");
              messages.addItem("test4");
              messages.addItem("test5");
              messages.addItem("test6");
              messages.addItem("test7");
              messages.addItem("test8");
              messages.addItem("test9");
              messages.addItem("test10");
              </fx:Script>
              <fx:Declarations>
              </fx:Declarations>
              <s:List id="lstPosts" left="10" right="10" top="10" bottom="10"
              change="lstPosts_changeHandler(event)"
              dataProvider="{messages}" itemRenderer="views.WallItemRenderer"></s:List>
              </s:View>
              WallItemRenderer
              <fx:Script>
              <![CDATA[
              [Bindable]
              if ((value%2) == 0)
              if ((value%2) == 1)
              lblMessage.text = value.toString();
              </fx:Script>
              <s:stroke>
              </s:stroke>
              <s:fill>
              </s:fill>
              </s:Rect>
              </s:ItemRenderer>
              • 4. Re: List Selected Index not correct
                rstanvir
                this event will be fired only when there is a change in the selected index of the list.
                perhaps your message collection (which is the data provider of the list) has length 1.
                • 5. Re: List Selected Index not correct
                  rstanvir Level 1
                  in itemrenderer also override the get method of itemIndex and data.
                  hope this will resolve the problem.
                  • 6. Re: List Selected Index not correct
                    Cool, I added a var for index and set it during the set data function.  Then just retyurned in it in the override public function get itemIndex():int.
                    Works great now.  Did not know this needed to be done.
                    Paul
                    • 7. Re: List Selected Index not correct
                      rstanvir Level 1
                      when u override something it becomes ur foremost duty to handle every side of it.
                      u were overriding the set method so the base class had no chance to store the itemIndex;
                      again u were not overriding the get method, this time the base class had to handle the get method but alas!! from where it would get the value cz u already robbed the set method from it.
