0 Replies Latest reply on Jun 21, 2011 4:07 PM by steesfoy
    Flash Builder Data problem - mysqli_stmt_bind_param ?
    steesfoy
      Hi All.. hope someone can help.
      I've started a very simple application and experiencing a problem regarding creating a new record in a MySQL database via PHP & Zend.
      Here's the snippet of AS:
                newLine.buy_price = cursor.current.buy;
                newLine.sell_price = cursor.current.sell;
                linesService.createLines(newLine);
                createLineResult.token = linesService.commit();
      Here's the snippet of PHP (all generated by FB):
           public function createLines($item) {
                $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (supplier, sku, product_name, quantity, buy_price, sell_price) VALUES (?, ?, ?, ?, ?, ?)");
                $this->throwExceptionOnError();
                mysqli_stmt_bind_param($stmt, 'iisiii', $item->supplier, $item->sku, $item->product_name, $item->quantity, $item->buy_price, $item->sell_price);
                mysqli_stmt_execute($stmt);
                $autoid = mysqli_stmt_insert_id($stmt);
                mysqli_stmt_free_result($stmt);
                mysqli_close($this->connection);
                return $autoid;
      When I run the createLines() function then commit(), I get the following error popup from my application:
      MySQL Error - 1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'lines (supplier, sku, product_name, quantity, buy_price, sell_price) VALUES (?, ' at line 1
      #0 C:\wamp\www\XOM-debug\services\LinesService.php(119): LinesService->throwExceptionOnError()
      #1 [internal function]: LinesService->createLines(Object(stdClass))
      #2 [internal function]: ReflectionMethod->invokeArgs(Object(LinesService), Array)
      #3 C:\wamp\www\ZendFramework\library\Zend\Server\Reflection\Function\Abstract.php(380): call_user_func_array(Array, Array)
      #4 C:\wamp\www\ZendFramework\library\Zend\Amf\Server.php(359): Zend_Server_Reflection_Function_Abstract->__call('invokeArgs', Array)
      #5 C:\wamp\www\ZendFramework\library\Zend\Amf\Server.php(359): Zend_Server_Reflection_Method->invokeArgs(Object(LinesService), Array)
      #6 C:\wamp\www\ZendFramework\library\Zend\Amf\Server.php(553): Zend_Amf_Server->_dispatch('createLines', Array, 'LinesService')
      #7 C:\wamp\www\ZendFramework\library\Zend\Amf\Server.php(629): Zend_Amf_Server->_handle(Object(Zend_Amf_Request_Http))
      #8 C:\wamp\www\XOM-debug\gateway.php(69): Zend_Amf_Server->handle()
      #9 {main}
      As as I see it, the parameters are not being replaced by the actual values, so MySQL is freaking out as it's getting question marks in the statements. What I don't understand is how this is happening! Everything is auto-generated by FB. I created a new project from scratch and used only drag & drop from the Data/Services panel to generate a form for data entry and got the same error.
      Any ideas!?
      Cheers,
      Steve
