5 Replies Latest reply: Jun 14, 2012 4:08 AM by JayeshViradiya RSS
    Can't open Flash Builder - "See the log file" error.
    elliot_flashtalking
      I have been using Flash Builder 4.5 and for some reason it has stopped opening correctly - I get the following error then it just shuts down.... :
      "An error has occured. See the log file."
      and if i check the log file it refers to then i see the following text:
      !SESSION 2011-06-22 13:53:43.658 -----------------------------------------------
      eclipse.buildId=M20100909-0800
      java.version=1.6.0_16
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86
      !ENTRY org.eclipse.osgi 4 0 2011-06-22 13:53:59.598
      !MESSAGE Application error
      !STACK 1
      org.eclipse.swt.SWTError: No more handles
          at org.eclipse.swt.SWT.error(SWT.java:4109)
          at org.eclipse.swt.SWT.error(SWT.java:3998)
          at org.eclipse.swt.SWT.error(SWT.java:3969)
          at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
          at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)
          at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)
          at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)
          at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)
          at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
          at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)
          at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)
          at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java :159)
          at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265)
          at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86)
          at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782)
          at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
          at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:798)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:108)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
      This is incredably frustrating as you can imagine as it effectively means i cant work anymore, it is clearly some kind of problem with eclipse but i have no idea what.
      I have tried re-installing Flash Builder twice and no luck.
      Can anyone help with this???
      Thanks !!!!
      Elliot.
