3 Replies Latest reply on Jun 22, 2011 1:39 PM by the_wine_snob
    Parts won't render, and
      The beginning of my video won't render, as you can see here. It's over eight minutes long and everything else rendered.
      I tried exporting just to see, and that part got cut, obviously. Any ideas as to what I can do?
      And at the end of my video, when it was done, all of a sudden 40 seconds of black footage was added... Why?
        • 1. Re: Parts won't render, and
          the_wine_snob Level 9
          It appears that you have set In & Out Points on your Sequence (notice the difference in the color of the Timeline Ruler at that point). Remove the Sequence In Point (in your case, and at about 00;00;08;00) and things should behave properly.
          • 2. Re: Parts won't render, and
            cmw88 Level 1
            Thank you.
            Now I've encountered another problem.
            I want to export this and put it up on Youtube, and I see you're generally recommending H.264, and one of the youtube presets.
            Now I've tried both the HD Widescreen settings, and the other Youtube settings and I still get some black bars on the sides. Why is that?
            I've scaled the footage where needed, and everything is perfect, but when I export it, it's just not right. Are there any settings I should take a second look at, any settings I may not have correctly, etc?
            • 3. Re: Parts won't render, and
              Black bars are a sign that there is a mis-match between the Project's/Sequence's Frame Size, and the Assets' Frame Size, or that the Project is set up to a different Aspect Ratio, than your chosen Export settings.
              What is your Sequence Preset?
              What are the specs. of those Assets?
              I seldom do anything on YouTube, so am not to one to ask for recs. there, but also please furnish the YouTube settings that you have chosen, as they will help others, who know YouTube.
