I have developed a script to find the objects using VBscript. In this by default paginator used to find the Find option for GREP mode to find footnotes. But while using script i have not used any GREP to find or to change. But the code automatically changes the ^F characters in the indd file. I need to overcome this error by making Find->Text mode as default.
Please help me to achieve this.
Make sure that the Change to field is empty. There may be a space lurking there.
Peter
Hi Peter,
Eventhough the Find option will search TEXT or GREP TAB in a single parse. I'm doing TEXT search but InDesign taken GREP search and delete unwanted texts.
In my code, I only find text as we do in InDesign Application, Find/Change popup window (Edit->Find/Change->TEXT). But while running script, the previous find instance like Edit->Find/Change->GREP used by the operator remains in the Find/Change window itself. I need to change the mode to Edit->Find/Change->TEXT even the previous check is GREP mode and if there is any text in the findwhat textbox before evaluting the below code.
I have pasted the part of the code below for CS3.
script:
myind.FindTextPreferences = idNothingEnum.idNothing
myind.ChangeTextPreferences = idNothingEnum.idNothing
Set myfind = myind.FindTextPreferences
myfind.AppliedParagraphStyle = "footnotes"
myfind.FindWhat = ""
Set TextDocVar1 = mydoc.FindText
For i = 1 To TextDocVar1.Count
TextDocVar1(i).Texts(1).AppliedCharacterStyle = "notes_with_indent"
Next
Is there any default code to overcome the error like we did before and after "myind.FindTextPreferences = idNothingEnum.idNothing" string.
