8 Replies Latest reply on Jul 4, 2011 11:32 AM by Dan Thomas
    Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
    Dan Thomas
      I have a flex 4.1 project in which I want to use the latest spark datagrid changes in so am trying to update to 4.5
      Having downloaded and added the sdk, switching the properties of my project and updating my datagrid skin classes to suit the latest changes I'm now getting the following error when trying to run my app:
      Error: Could not find compiled resource bundle 'controls' for locale 'en_US'.
      at mx.resources::ResourceManagerImpl/installCompiledResourceBundle()[E:\dev\4.5.1\frameworks \projects\framework\src\mx\resources\ResourceManagerImpl.as:367]
      at mx.resources::ResourceManagerImpl/installCompiledResourceBundles()[E:\dev\4.5.1\framework s\projects\framework\src\mx\resources\ResourceManagerImpl.as:287]
      at mx.core::FlexModuleFactory/installCompiledResourceBundles()[E:\dev\4.5.1\frameworks\proje cts\framework\src\mx\core\FlexModuleFactory.as:709]
      at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\4.5.1\frameworks\projects\framework\s rc\mx\core\FlexModuleFactory.as:679]
      at mx.core::FlexModuleFactory/docFrameListener()[E:\dev\4.5.1\frameworks\projects\framework\ src\mx\core\FlexModuleFactory.as:131]
      I believe this is whilst trying to load a module as the first thing the app does is load a login module.
      Any suggestions as to what I need to do to sort this out?
      Cheers,
      Dan
        • 1. Re: Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
          Dan Thomas Level 1
          and just in case it's relevant we're using mx modules (as spark weren't available at the start of the project)
          • 2. Re: Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
            Sharma*Jyoti
            Include framework_rb.swc from Adobe\Adobe Flash Builder 4.5\sdks\4.5.0\frameworks\locale\en_US in your project and try. I have not tested it but i think it will work..... Not sure
            • 4. Re: Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
              Dan Thomas Level 1
              Solved!
              Because the app is heavily module based, the main app had no mx components referenced (just all the modules used a mix of spark and mx). Simply adding a UIComponent to the main application forced the compiler to include the relevant bundles and we're back in business.
              • 5. Re: Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
                Dan Thomas Level 1
                Not Solved!
                That fixed it for our login module but the next one that gets loaded caused the same error. Bit more info:
                - We reduced the login module to simply a spark container and it worked.
                - We added elements back in until we got the error which turned out to be an mx:Image.
                - Switching that mx:Image to s:Image made it work again.
                - This wasn't feasilbe to do for all the mx controls used so we tried placing an mx:UIComponent in the main app which made the login module work again
                After logging in to the app the login module is unloaded and a much larger one is loaded, this caused the same issue but we can't figure out why adding UIComponent fixed login module but not the main module.
                Does this make sense to anyone?!?
                • 6. Re: Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
                  Flex harUI Adobe Employee
                  Various components use different bundles, so that's why it matters which
                  components are in the module.  Some bundles will already be installed by the
                  main app, so depending on what bundle the module wants, you can force it to
                  be installed by the main app by including the right component in the main
                  app, but that isn't really the approach you want to take, and I don't see
                  how adding in UIComponent would have made a difference since it is always in
                  every app.
                  Make sure all SWFs (main app and modules) are compiled against the 4.5.1
                  SDK, and all non-Adobe SWCs have been compiled against the 4.5.1 SDK.
                  Mixing versions in a SWF is not supported, and modules and their loaders
                  must be the same version.
                  Then generate link-reports for the loading app and modules and post them.
                  • 7. Re: Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
                    Colin L
                    I'm taking this issue over as DannyT is away this week.
                    I have checked we are compiling all SWC's with 4.5.1 and it appears to be the case although we are using third party compiled SWC's for RobotLegs, Signals and some flash skins which I'm assuming wouldn't be an issue?
                    I've carried out comprehensive testing to narrow the problem down, I found that mx.controls.Image seemed to be causing some of the issues, when replaced with the spark Image the module was loading fine although I now then had an issue with the mx charting components so added a reference to the main app, as you say not the best work around and I'm still getting the same issue:
                    We have other mx components in our modules and these seem to be fine although I haven't checked to see if they are being used throughout the app so they might be referenced in main. I've posted the link report xml below, any help or suggestions would be appreciated as we'd like to be able to use the latest version of the DataGrid.
                    <report>
                      <scripts>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:TextRemoteObject)" mod="1294231234000" size="1531" optimizedsize="836">
                          <def id="com.my.app.remoting:TextRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ITextRemoteObject" />
                          <pre id="com.my.app.remoting:BaseRemoteObject" />
                          <dep id="AS3" />
                          <dep id="mx.rpc:AsyncToken" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ICachableRemoteObject)" mod="1294229901000" size="1206" optimizedsize="316">
                          <def id="com.my.app.remoting.interfaces:ICachableRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_TreeDisclosureClosed_699467254.as" mod="1306854026000" size="623" optimizedsize="370">
                          <def id="_class_embed_css_Assets_swf_1422583548_TreeDisclosureClosed_699467254" />
                          <pre id="mx.core:SpriteAsset" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/QueryBuilderModuleLoader.as" mod="1308837418000" size="3337" optimizedsize="1844">
                          <def id="com.my.app.loader:QueryBuilderModuleLoader" />
                          <pre id="com.my.app.loader:BaseModuleLoader" />
                          <dep id="com.my.app.vo:User" />
                          <dep id="com.my.app.vo:Query" />
                          <dep id="org.osflash.signals:Signal" />
                          <dep id="AS3" />
                          <dep id="com.my.app.module.queryBuilder:IQueryBuilderModule" />
                          <dep id="org.osflash.signals:ISignal" />
                          <dep id="com.my.app.vo:QuerySnippet" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:JournalistRemoteObject)" mod="1292428848000" size="1187" optimizedsize="730">
                          <def id="com.my.app.remoting:JournalistRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IJournalistRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/MYAppPro.mxml" mod="1309189518000" size="7534" optimizedsize="6376">
                          <def id="MYAppPro" />
                          <pre id="flash.events:IEventDispatcher" />
                          <pre id="mx.binding:IBindingClient" />
                          <pre id="com.my.app:MYAppProApp" />
                          <dep id="_MYAppProWatcherSetupUtil" />
                          <dep id="mx.styles:CSSSelector" />
                          <dep id="mx.styles:CSSStyleDeclaration" />
                          <dep id="mx.core:DeferredInstanceFromFunction" />
                          <dep id="com.my.app.context:MYAppProContext" />
                          <dep id="flash.display:DisplayObjectContainer" />
                          <dep id="mx.core:mx_internal" />
                          <dep id="MYAppPro__embed__font_MyriadPro_bold_normal_1315605509" />
                          <dep id="mx.binding:IWatcherSetupUtil2" />
                          <dep id="mx.binding:BindingManager" />
                          <dep id="com.my.app.view:MainView" />
                          <dep id="mx.styles:CSSCondition" />
                          <dep id="mx.core:IFlexModuleFactory" />
                          <dep id="AS3" />
                          <dep id="mx.binding:Binding" />
                          <dep id="_MYAppPro_FlexInit" />
                          <dep id="_MYAppPro_Styles" />
                          <dep id="flash.utils:getDefinitionByName" />
                          <dep id="mx.events:PropertyChangeEvent" />
                          <dep id="MYAppPro__embed__font_MyriadPro_medium_normal_1029366919" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.events:ModuleEvent)" mod="1306872054062" size="1244" optimizedsize="729">
                          <def id="mx.events:ModuleEvent" />
                          <pre id="flash.events:ProgressEvent" />
                          <dep id="flash.events:Event" />
                          <dep id="mx.modules:IModuleInfo" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:DashboardRemoteObject)" mod="1308837429000" size="2518" optimizedsize="1400">
                          <def id="com.my.app.remoting:DashboardRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IDashboardRemoteObject" />
                          <dep id="com.my.app.vo:Dashboard" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders:Reflector)" mod="1272837850000" size="2141" optimizedsize="1490">
                          <def id="org.swiftsuspenders:Reflector" />
                          <pre id="Object" />
                          <dep id="org.swiftsuspenders:getConstructor" />
                          <dep id="flash.utils:describeType" />
                          <dep id="flash.utils:getQualifiedClassName" />
                          <dep id="AS3" />
                          <dep id="XML" />
                          <dep id="flash.system:ApplicationDomain" />
                          <dep id="Error" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:DPIClassification)" mod="1306872039593" size="480" optimizedsize="256">
                          <def id="mx.core:DPIClassification" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.resources:IResourceManager)" mod="1306872057390" size="3482" optimizedsize="1039">
                          <def id="mx.resources:IResourceManager" />
                          <pre id="Object" />
                          <dep id="flash.system:SecurityDomain" />
                          <dep id="AS3" />
                          <dep id="mx.resources:IResourceBundle" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders:getConstructor)" mod="1272837850000" size="577" optimizedsize="339">
                          <def id="org.swiftsuspenders:getConstructor" />
                          <dep id="String" />
                          <dep id="AS3" />
                          <dep id="Number" />
                          <dep id="Class" />
                          <dep id="XML" />
                          <dep id="XMLList" />
                          <dep id="Object" />
                          <dep id="flash.utils:Proxy" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/LoginModuleLoader.as" mod="1291226946000" size="903" optimizedsize="583">
                          <def id="com.my.app.loader:LoginModuleLoader" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/DashboardModuleLoader.as" mod="1309186845000" size="3451" optimizedsize="1923">
                          <def id="com.my.app.loader:DashboardModuleLoader" />
                          <dep id="com.my.app.vo:DashboardSnippet" />
                          <dep id="AS3" />
                          <dep id="com.my.app.module.dashboard:IDashboardModule" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:EmbeddedFontRegistry)" mod="1306872041202" size="5403" optimizedsize="3296">
                          <def id="mx.core:EmbeddedFontRegistry" />
                          <pre id="mx.core:IEmbeddedFontRegistry" />
                          <pre id="Object" />
                          <dep id="mx.core:EmbeddedFont" />
                          <dep id="flash.text:FontStyle" />
                          <dep id="trace" />
                          <dep id="mx.resources:ResourceManager" />
                          <dep id="Error" />
                          <dep id="mx.resources:IResourceManager" />
                          <dep id="mx.managers:ISystemManager" />
                          <dep id="flash.text.engine:FontDescription" />
                          <dep id="flash.text:TextFormat" />
                          <dep id="AS3" />
                          <dep id="flash.text:TextField" />
                          <dep id="flash.system:Capabilities" />
                          <dep id="mx.core:Singleton" />
                          <dep id="flash.utils:Dictionary" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_CloseButtonUp_904206584.as" mod="1306854026000" size="601" optimizedsize="363">
                          <def id="_class_embed_css_Assets_swf_1422583548_CloseButtonUp_904206584" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/SharedResources.properties" mod="1306854100000" size="638" optimizedsize="603">
                          <def id="en_US$SharedResources_properties" />
                          <pre id="mx.resources:ResourceBundle" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/skins/PopupSkin.mxml" mod="1308837418000" size="4789" optimizedsize="3018">
                          <def id="com.my.app.skins:PopupSkin" />
                          <pre id="mx.core:IStateClient2" />
                          <pre id="spark.components.supportClasses:Skin" />
                          <dep id="spark.primitives:Rect" />
                          <dep id="spark.layouts:VerticalLayout" />
                          <dep id="mx.states:SetProperty" />
                          <dep id="AS3" />
                          <dep id="mx.graphics:SolidColor" />
                          <dep id="mx.states:State" />
                          <dep id="spark.components:Group" />
                          <dep id="spark.components:SkinnableContainer" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:ContextEvent)" mod="1269791984000" size="933" optimizedsize="480">
                          <def id="org.robotlegs.base:ContextEvent" />
                          <pre id="flash.events:Event" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:QuerySnippet)" mod="1294750696000" size="723" optimizedsize="315">
                          <def id="com.my.app.vo:QuerySnippet" />
                          <pre id="com.my.app.vo:RevertableVO" />
                          <dep id="Date" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IRSSPodRemoteObject)" mod="1294221810000" size="1230" optimizedsize="371">
                          <def id="com.my.app.remoting.interfaces:IRSSPodRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="com.my.app.vo:RSSPod" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionpoints:MethodInjectionPoint)" mod="1273448582000" size="2862" optimizedsize="1766">
                          <def id="org.swiftsuspenders.injectionpoints:MethodInjectionPoint" />
                          <pre id="org.swiftsuspenders.injectionpoints:InjectionPoint" />
                          <dep id="org.swiftsuspenders:InjectionConfig" />
                          <dep id="org.swiftsuspenders:InjectorError" />
                          <dep id="AS3" />
                          <dep id="XML" />
                          <dep id="Error" />
                          <dep id="org.swiftsuspenders:Injector" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/loader/TimeLineLoaderWrapper.as" mod="1294835157000" size="2360" optimizedsize="1421">
                          <def id="com.my.app.component.loader:TimeLineLoaderWrapper" />
                          <pre id="mx.core:UIComponent" />
                          <pre id="com.my.app.component.loader:ILoaderController" />
                          <dep id="AS3" />
                          <dep id="mx.core:FlexGlobals" />
                          <dep id="mx.events:ModuleEvent" />
                          <dep id="Math" />
                          <dep id="TimeLineLoader" />
                          <dep id="flash.display:MovieClip" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragCopy_1279468729.as" mod="1306854026000" size="638" optimizedsize="375">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragCopy_1279468729" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/framework_rb.swc$locale/en_US/logging.properties" mod="1306854100000" size="735" optimizedsize="704">
                          <def id="en_US$logging_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.action:FeedbackAsyncAction)" mod="1294328487000" size="955" optimizedsize="396">
                          <def id="com.my.app.action:FeedbackAsyncAction" />
                          <pre id="com.my.app.action:AsyncAction" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionresults:InjectClassResult)" mod="1272837850000" size="871" optimizedsize="450">
                          <def id="org.swiftsuspenders.injectionresults:InjectClassResult" />
                          <pre id="org.swiftsuspenders.injectionresults:InjectionResult" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/framework_rb.swc$locale/en_US/modules.properties" mod="1306854100000" size="310" optimizedsize="284">
                          <def id="en_US$modules_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/skins/RoundedCornerTextInputSkin.mxml" mod="1308839963000" size="8920" optimizedsize="5730">
                          <def id="com.my.app.skins:RoundedCornerTextInputSkin" />
                          <pre id="spark.skins:SparkSkin" />
                          <dep id="spark.components:TextInput" />
                          <dep id="_com_my_app_skins_RoundedCornerTextInputSkinWatcherSetupUtil" />
                          <dep id="Number" />
                          <dep id="AS3" />
                          <dep id="spark.components:RichEditableText" />
                          <dep id="mx.graphics:SolidColorStroke" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.mvcs:Context)" mod="1273448146000" size="3618" optimizedsize="1909">
                          <def id="org.robotlegs.mvcs:Context" />
                          <pre id="org.robotlegs.core:IContext" />
                          <pre id="org.robotlegs.base:ContextBase" />
                          <dep id="flash.events:IEventDispatcher" />
                          <dep id="org.robotlegs.base:EventMap" />
                          <dep id="org.robotlegs.core:IReflector" />
                          <dep id="org.robotlegs.base:CommandMap" />
                          <dep id="org.robotlegs.core:IInjector" />
                          <dep id="org.robotlegs.core:ICommandMap" />
                          <dep id="org.robotlegs.core:IMediatorMap" />
                          <dep id="AS3" />
                          <dep id="org.robotlegs.base:ViewMap" />
                          <dep id="org.robotlegs.core:IEventMap" />
                          <dep id="org.robotlegs.base:ContextEvent" />
                          <dep id="org.robotlegs.base:MediatorMap" />
                          <dep id="org.robotlegs.adapters:SwiftSuspendersInjector" />
                          <dep id="org.robotlegs.core:IViewMap" />
                          <dep id="org.robotlegs.adapters:SwiftSuspendersReflector" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/dashboardTitleAlert/DashboardTitleAlert.as" mod="1295255816000" size="2526" optimizedsize="1401">
                          <def id="com.my.app.component.dashboardTitleAlert:DashboardTitleAlert" />
                          <pre id="com.my.app.component.dashboardTitleAlert:DashboardTitleAlertMarkup" />
                          <dep id="flash.events:MouseEvent" />
                          <dep id="AS3" />
                          <dep id="mx.utils:StringUtil" />
                          <dep id="com.my.app.manager:ModalPopupManager" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:SourceRemoteObject)" mod="1292434523000" size="1141" optimizedsize="707">
                          <def id="com.my.app.remoting:SourceRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ISourceRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:CustomerFileRemoteObject)" mod="1294750696000" size="1543" optimizedsize="892">
                          <def id="com.my.app.remoting:CustomerFileRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ICustomerFileRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionpoints:PostConstructInjectionPoint)" mod="1272837850000" size="1648" optimizedsize="894">
                          <def id="org.swiftsuspenders.injectionpoints:PostConstructInjectionPoint" />
                          <dep id="AS3" />
                          <dep id="XML" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/flash_assets.swc(TimeLineLoader)" mod="1294834686125" size="433" optimizedsize="285">
                          <def id="TimeLineLoader" />
                          <pre id="flash.display:MovieClip" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:RSLListLoader)" mod="1306872040218" size="2217" optimizedsize="1111">
                          <def id="mx.core:RSLListLoader" />
                          <pre id="Object" />
                          <dep id="mx.core:RSLItem" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_containers_FormItem_Required_1292455008.as" mod="1306854026000" size="659" optimizedsize="382">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_containers_FormItem_Required_1292455008" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_cursorStretch_1000132270.as" mod="1306854026000" size="604" optimizedsize="364">
                          <def id="_class_embed_css_Assets_swf_1422583548_cursorStretch_1000132270" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/dashboardTitleAlert/DashboardTitleAlertMarkup.mxml" mod="1308837414000" size="5656" optimizedsize="3011">
                          <def id="com.my.app.component.dashboardTitleAlert:DashboardTitleAlertMarkup" />
                          <pre id="spark.components:Group" />
                          <dep id="com.my.app.skins:RoundedCornerTextInputSkin" />
                          <dep id="spark.components:Button" />
                          <dep id="com.my.app.skins:PopupSkin" />
                          <dep id="spark.components:Label" />
                          <dep id="AS3" />
                          <dep id="com.my.app.skins:SilverButtonSkin" />
                          <dep id="spark.components:HGroup" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/as3-signals.swc(org.osflash.signals:Slot)" mod="1291821251505" size="1267" optimizedsize="611">
                          <def id="org.osflash.signals:Slot" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.utils:NameUtil)" mod="1306872046765" size="1669" optimizedsize="1094">
                          <def id="mx.utils:NameUtil" />
                          <pre id="Object" />
                          <dep id="mx.core:IRepeaterClient" />
                          <dep id="SecurityError" />
                          <dep id="AS3" />
                          <dep id="flash.display:DisplayObject" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:CacheVO)" mod="1292345880000" size="457" optimizedsize="239">
                          <def id="com.my.app.vo:CacheVO" />
                          <pre id="Object" />
                          <dep id="mx.utils:UIDUtil" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/view/MainView.as" mod="1309190212000" size="5727" optimizedsize="3612">
                          <def id="com.my.app.view:MainView" />
                          <pre id="com.my.app.view:MainViewMarkup" />
                          <dep id="com.my.app.loader:HelpTextModuleLoader" />
                          <dep id="flash.printing:PrintJobOptions" />
                          <dep id="flash.printing:PrintJobOrientation" />
                          <dep id="flash.geom:Rectangle" />
                          <dep id="Math" />
                          <dep id="mx.charts.chartClasses:ChartLabel" />
                          <dep id="com.my.app.enum:MenuTypes" />
                          <dep id="flash.printing:PrintJob" />
                          <dep id="AS3" />
                          <dep id="com.my.app.component.printPopUp:PrintPopUp" />
                          <dep id="com.my.app:IMYAppPropApp" />
                          <dep id="com.my.app.enum:TextServiceNames" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.resources:LocaleSorter)" mod="1306872057312" size="9921" optimizedsize="6854">
                          <def id="mx.resources:LocaleSorter" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/spark_rb.swc$locale/en_US/components.properties" mod="1306853870000" size="4153" optimizedsize="4083">
                          <def id="en_US$components_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.remoting:QueryPodDelegate)" mod="1294681144000" size="1591" optimizedsize="852">
                          <def id="com.my.app.delegate.remoting:QueryPodDelegate" />
                          <pre id="com.my.app.delegate.interfaces:IQueryPodDelegate" />
                          <pre id="com.my.app.delegate.remoting:BaseDelegate" />
                          <dep id="com.my.app.vo:DashboardPod" />
                          <dep id="AS3" />
                          <dep id="com.my.app.remoting.interfaces:IQueryPodRemoteObject" />
                          <dep id="com.my.app.vo:QueryPod" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:CompetitorsQueryResult)" mod="1295458204000" size="619" optimizedsize="267">
                          <def id="com.my.app.vo:CompetitorsQueryResult" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="com.my.app.vo:Competitor" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionpoints:ConstructorInjectionPoint)" mod="1272837850000" size="3351" optimizedsize="2412">
                          <def id="org.swiftsuspenders.injectionpoints:ConstructorInjectionPoint" />
                          <pre id="org.swiftsuspenders.injectionpoints:MethodInjectionPoint" />
                          <dep id="AS3" />
                          <dep id="trace" />
                          <dep id="XML" />
                          <dep id="Error" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/AdminModuleLoader.as" mod="1291226946000" size="901" optimizedsize="583">
                          <def id="com.my.app.loader:AdminModuleLoader" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/view/MainViewMarkup.mxml" mod="1308837418000" size="9261" optimizedsize="6130">
                          <def id="com.my.app.view:MainViewMarkup" />
                          <dep id="com.my.app.component.loader:TimeLineLoaderWrapper" />
                          <dep id="com.my.app.loader:LoginModuleLoader" />
                          <dep id="com.my.app.loader:DashboardModuleLoader" />
                          <dep id="spark.components:VGroup" />
                          <dep id="com.my.app.loader:HeaderModuleLoader" />
                          <dep id="AS3" />
                          <dep id="com.my.app.loader:AdminModuleLoader" />
                          <dep id="com.my.app.loader:QueryBuilderModuleLoader" />
                          <dep id="com.my.app.component.loader:ILoaderController" />
                          <dep id="_com_my_app_view_MainViewMarkupWatcherSetupUtil" />
                          <dep id="com.my.app.loader:FeedbackModuleLoader" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders:InjectionConfig)" mod="1272837850000" size="1296" optimizedsize="632">
                          <def id="org.swiftsuspenders:InjectionConfig" />
                          <pre id="Object" />
                          <dep id="org.swiftsuspenders.injectionresults:InjectionResult" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ITextRemoteObject)" mod="1292345880000" size="419" optimizedsize="160">
                          <def id="com.my.app.remoting.interfaces:ITextRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ICachableRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:MediaSummaryPod)" mod="1308837429000" size="711" optimizedsize="345">
                          <def id="com.my.app.vo:MediaSummaryPod" />
                          <dep id="Date" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionpoints:NoParamsConstructorInjectionPoint)" mod="1272837850000" size="770" optimizedsize="321">
                          <def id="org.swiftsuspenders.injectionpoints:NoParamsConstructorInjectionPoint" />
                          <dep id="AS3" />
                        </script>
                        <script name="_MYAppPro_FlexInit-generated.as" mod="1309190215865" size="13205" optimizedsize="11952">
                          <def id="_MYAppPro_FlexInit" />
                          <pre id="Object" />
                          <dep id="mx.messaging.messages:MessagePerformanceInfo" />
                          <dep id="com.my.app.vo:TextMessage" />
                          <dep id="com.my.app.vo:Category" />
                          <dep id="en_US$components_properties" />
                          <dep id="en_US$formatters_properties" />
                          <dep id="en_US$logging_properties" />
                          <dep id="mx.messaging.messages:AsyncMessageExt" />
                          <dep id="mx.utils:ObjectProxy" />
                          <dep id="en_US$sparkEffects_properties" />
                          <dep id="en_US$SharedResources_properties" />
                          <dep id="mx.managers:SystemManagerGlobals" />
                          <dep id="en_US$collections_properties" />
                          <dep id="com.my.app.vo:CustomerSnippet" />
                          <dep id="mx.messaging.messages:AcknowledgeMessage" />
                          <dep id="en_US$modules_properties" />
                          <dep id="com.my.app.vo:MediaType" />
                          <dep id="en_US$core_properties" />
                          <dep id="flash.net:registerClassAlias" />
                          <dep id="mx.effects:EffectManager" />
                          <dep id="flash.net:getClassByAlias" />
                          <dep id="mx.messaging.messages:RemotingMessage" />
                          <dep id="com.my.app.vo:Journalist" />
                          <dep id="com.my.app.vo:TextPod" />
                          <dep id="mx.messaging.config:ConfigMap" />
                          <dep id="mx.messaging.messages:ErrorMessage" />
                          <dep id="en_US$rpc_properties" />
                          <dep id="mx.messaging.messages:CommandMessageExt" />
                          <dep id="mx.collections:ArrayList" />
                          <dep id="com.my.app.vo:QueryResultElement" />
                          <dep id="com.my.app.vo:MediaOutlet" />
                          <dep id="mx.managers.systemClasses:ChildManager" />
                          <dep id="mx.messaging.messages:CommandMessage" />
                          <dep id="en_US$containers_properties" />
                          <dep id="mx.core:TextFieldFactory" />
                          <dep id="com.my.app.vo:CompetitorsQueryResult" />
                          <dep id="en_US$layout_properties" />
                          <dep id="mx.messaging.messages:AcknowledgeMessageExt" />
                          <dep id="AS3" />
                          <dep id="en_US$messaging_properties" />
                          <dep id="en_US$osmf_properties" />
                          <dep id="mx.styles:StyleManagerImpl" />
                          <dep id="en_US$textLayout_properties" />
                          <dep id="com.my.app.vo:UserSnippet" />
                          <dep id="en_US$skins_properties" />
                          <dep id="trace" />
                          <dep id="com.my.app.vo:Source" />
                          <dep id="Error" />
                          <dep id="en_US$charts_properties" />
                          <dep id="en_US$styles_properties" />
                          <dep id="mx.collections:ArrayCollection" />
                          <dep id="com.my.app.vo:MediaSummaryItem" />
                          <dep id="en_US$effects_properties" />
                          <dep id="com.my.app.vo:CustomerFile" />
                          <dep id="com.my.app.vo:MediaSummaryPod" />
                          <dep id="mx.styles:IStyleManager2" />
                          <dep id="com.my.app.vo:Customer" />
                          <dep id="mx.messaging.messages:AsyncMessage" />
                        </script>
                        <script name="MYAppPro__embed__font_MyriadPro_bold_normal_1315605509.as" mod="1291226943000" size="442" optimizedsize="224">
                          <def id="MYAppPro__embed__font_MyriadPro_bold_normal_1315605509" />
                          <pre id="mx.core:FontAsset" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/BaseModuleLoader.as" mod="1309175195000" size="3243" optimizedsize="1970">
                          <def id="com.my.app.loader:BaseModuleLoader" />
                          <pre id="mx.modules:ModuleLoader" />
                          <dep id="org.robotlegs.utilities.modular.core:IModule" />
                          <dep id="AS3" />
                          <dep id="mx.events:FlexEvent" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/skins/LinkButtonSkin.mxml" mod="1308837418000" size="5134" optimizedsize="3986">
                          <def id="com.my.app.skins:LinkButtonSkin" />
                          <dep id="mx.states:AddItems" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:QueryRemoteObject)" mod="1297076409000" size="2734" optimizedsize="1455">
                          <def id="com.my.app.remoting:QueryRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IQueryRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:RSLData)" mod="1306872040468" size="1658" optimizedsize="839">
                          <def id="mx.core:RSLData" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:MediaOutletRemoteObject)" mod="1292429834000" size="1193" optimizedsize="733">
                          <def id="com.my.app.remoting:MediaOutletRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IMediaOutletRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:DashboardPodRemoteObject)" mod="1295255883000" size="1770" optimizedsize="996">
                          <def id="com.my.app.remoting:DashboardPodRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IDashboardPodRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IEmbeddedFontRegistry)" mod="1306872039202" size="1261" optimizedsize="440">
                          <def id="mx.core:IEmbeddedFontRegistry" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/textLayout_rb.swc$locale/en_US/textLayout.properties" mod="1306853916000" size="1656" optimizedsize="1609">
                          <def id="en_US$textLayout_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:ICommandMap)" mod="1271434072000" size="1242" optimizedsize="376">
                          <def id="org.robotlegs.core:ICommandMap" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.resources:ResourceManagerImpl)" mod="1306872057374" size="12831" optimizedsize="6861">
                          <def id="mx.resources:ResourceManagerImpl" />
                          <pre id="mx.resources:IResourceManager" />
                          <pre id="flash.events:EventDispatcher" />
                          <pre id="Object" />
                          <dep id="mx.resources:LocaleSorter" />
                          <dep id="mx.resources:IResourceModule" />
                          <dep id="trace" />
                          <dep id="mx.resources:ResourceBundle" />
                          <dep id="Error" />
                          <dep id="mx.modules:ModuleManager" />
                          <dep id="AS3" />
                          <dep id="mx.events:ResourceEvent" />
                          <dep id="flash.utils:Timer" />
                          <dep id="flash.events:FocusEvent" />
                          <dep id="flash.events:TimerEvent" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/osmf_rb.swc$locale/en_US/osmf.properties" mod="1306854146000" size="3751" optimizedsize="3676">
                          <def id="en_US$osmf_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IMediaTypeRemoteObject)" mod="1308837429000" size="868" optimizedsize="291">
                          <def id="com.my.app.remoting.interfaces:IMediaTypeRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.adapters:SwiftSuspendersInjector)" mod="1273448758000" size="1624" optimizedsize="1129">
                          <def id="org.robotlegs.adapters:SwiftSuspendersInjector" />
                          <pre id="org.robotlegs.core:IInjector" />
                          <pre id="org.swiftsuspenders:Injector" />
                          <dep id="AS3" />
                          <dep id="XML" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.managers:SystemManager)" mod="1306872044452" size="36322" optimizedsize="20571">
                          <def id="mx.managers:SystemManager" />
                          <pre id="mx.core:IFlexModuleFactory" />
                          <pre id="mx.managers:ISystemManager" />
                          <pre id="mx.core:IChildList" />
                          <pre id="mx.core:IFlexDisplayObject" />
                          <dep id="Math" />
                          <dep id="flash.display:LoaderInfo" />
                          <dep id="mx.core:IUIComponent" />
                          <dep id="mx.events:SandboxMouseEvent" />
                          <dep id="mx.managers:SystemRawChildrenList" />
                          <dep id="flash.display:Graphics" />
                          <dep id="flash.display:StageAlign" />
                          <dep id="flash.display:Sprite" />
                          <dep id="mx.utils:LoaderUtil" />
                          <dep id="mx.preloaders:Preloader" />
                          <dep id="mx.events:RSLEvent" />
                          <dep id="flash.display:Loader" />
                          <dep id="flash.geom:Point" />
                          <dep id="mx.managers:SystemChildrenList" />
                          <dep id="flash.text:Font" />
                          <dep id="flash.display:Stage" />
                          <dep id="flash.ui:Keyboard" />
                          <dep id="mx.events:DynamicEvent" />
                          <dep id="ArgumentError" />
                          <dep id="mx.core:IRawChildrenContainer" />
                          <dep id="QName" />
                          <dep id="flash.events:KeyboardEvent" />
                          <dep id="mx.core:FlexSprite" />
                          <dep id="flash.display:StageQuality" />
                          <dep id="mx.core:RSLData" />
                          <dep id="mx.events:Request" />
                          <dep id="AS3" />
                          <dep id="__AS3__.vec:Vector" />
                          <dep id="mx.utils:DensityUtil" />
                          <dep id="flash.display:StageScaleMode" />
                          <dep id="mx.core:IInvalidating" />
                          <dep id="Error" />
                          <dep id="mx.managers:ISystemManagerChildManager" />
                        </script>
                        <script name="_class_embed_css_assets_CalendarIcon_png__1170248551_1839914564.as" mod="1306854026000" size="550" optimizedsize="314">
                          <def id="_class_embed_css_assets_CalendarIcon_png__1170248551_1839914564" />
                          <pre id="mx.core:BitmapAsset" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.managers:SystemRawChildrenList)" mod="1306872045187" size="2326" optimizedsize="1198">
                          <def id="mx.managers:SystemRawChildrenList" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="mx.managers:SystemManager" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/effects.properties" mod="1306854100000" size="401" optimizedsize="374">
                          <def id="en_US$effects_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548___brokenImage_184772295.as" mod="1306854026000" size="601" optimizedsize="363">
                          <def id="_class_embed_css_Assets_swf_1422583548___brokenImage_184772295" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:ResourceModuleRSLItem)" mod="1306872039609" size="2015" optimizedsize="1281">
                          <def id="mx.core:ResourceModuleRSLItem" />
                          <pre id="mx.core:RSLItem" />
                          <dep id="AS3" />
                          <dep id="flash.events:IOErrorEvent" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/styles.properties" mod="1306854100000" size="301" optimizedsize="275">
                          <def id="en_US$styles_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:QueryPodRemoteObject)" mod="1294680416000" size="1859" optimizedsize="1033">
                          <def id="com.my.app.remoting:QueryPodRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IQueryPodRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IInvalidating)" mod="1306872040202" size="692" optimizedsize="250">
                          <def id="mx.core:IInvalidating" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.manager:AsyncManager)" mod="1297671711000" size="2404" optimizedsize="1361">
                          <def id="com.my.app.manager:AsyncManager" />
                          <pre id="Object" />
                          <dep id="mx.rpc:Fault" />
                          <dep id="AS3" />
                          <dep id="com.my.app.action:AsyncAction" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.modules:IModuleInfo)" mod="1306872055374" size="1626" optimizedsize="534">
                          <def id="mx.modules:IModuleInfo" />
                          <pre id="Object" />
                          <dep id="flash.utils:ByteArray" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/HeaderModuleLoader.as" mod="1308837418000" size="4145" optimizedsize="2113">
                          <def id="com.my.app.loader:HeaderModuleLoader" />
                          <dep id="com.my.app.module.header:IHeaderModule" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.model:ApplicationModel)" mod="1297160952000" size="529" optimizedsize="271">
                          <def id="com.my.app.model:ApplicationModel" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragReject_207783805.as" mod="1306854026000" size="641" optimizedsize="376">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragReject_207783805" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:Query)" mod="1295374588000" size="1105" optimizedsize="609">
                          <def id="com.my.app.vo:Query" />
                          <pre id="com.my.app.vo:CacheVO" />
                          <dep id="Date" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:CategoryRemoteObject)" mod="1294221810000" size="1161" optimizedsize="734">
                          <def id="com.my.app.remoting:CategoryRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ICategoryRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:MediatorBase)" mod="1269791984000" size="1944" optimizedsize="1038">
                          <def id="org.robotlegs.base:MediatorBase" />
                          <pre id="org.robotlegs.core:IMediator" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Error" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:DashboardPod)" mod="1295255883000" size="1046" optimizedsize="531">
                          <def id="com.my.app.vo:DashboardPod" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.enum:MenuTypes)" mod="1294410482000" size="498" optimizedsize="255">
                          <def id="com.my.app.enum:MenuTypes" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/mediator/MainViewMediator.as" mod="1309180556000" size="8603" optimizedsize="5066">
                          <def id="com.my.app.mediator:MainViewMediator" />
                          <pre id="org.robotlegs.mvcs:Mediator" />
                          <dep id="com.my.app.remoting.interfaces:IUserRemoteObject" />
                          <dep id="com.my.app.component.asyncPasswordEnter:AsyncPasswordEnter" />
                          <dep id="com.my.app.component.asyncRetry:AsyncRetry" />
                          <dep id="com.my.app.domain.auth:IAuth" />
                          <dep id="com.my.app.enum:NavigationViews" />
                          <dep id="AS3" />
                          <dep id="com.my.app.manager:NavigationManager" />
                          <dep id="com.my.app.model:ApplicationModel" />
                          <dep id="com.my.app.manager:AsyncManager" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.remoting:UserDelegate)" mod="1292231868000" size="1092" optimizedsize="605">
                          <def id="com.my.app.delegate.remoting:UserDelegate" />
                          <pre id="com.my.app.delegate.interfaces:IUserDelegate" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:ViewMap)" mod="1269791984000" size="2749" optimizedsize="1552">
                          <def id="org.robotlegs.base:ViewMap" />
                          <pre id="org.robotlegs.core:IViewMap" />
                          <pre id="org.robotlegs.base:ViewMapBase" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.manager:NavigationManager)" mod="1295279651000" size="2655" optimizedsize="1547">
                          <def id="com.my.app.manager:NavigationManager" />
                          <pre id="Object" />
                          <dep id="mx.events:BrowserChangeEvent" />
                          <dep id="mx.managers:BrowserManager" />
                          <dep id="mx.utils:URLUtil" />
                          <dep id="mx.managers:IBrowserManager" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:mx_internal)" mod="1306872039530" size="184" optimizedsize="109">
                          <def id="mx.core:mx_internal" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_CloseButtonDisabled_452580263.as" mod="1306854026000" size="620" optimizedsize="369">
                          <def id="_class_embed_css_Assets_swf_1422583548_CloseButtonDisabled_452580263" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:EmbeddedFont)" mod="1306872041265" size="1212" optimizedsize="625">
                          <def id="mx.core:EmbeddedFont" />
                          <pre id="Object" />
                          <dep id="mx.core:EmbeddedFontRegistry" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionpoints:InjectionPoint)" mod="1272837850000" size="870" optimizedsize="358">
                          <def id="org.swiftsuspenders.injectionpoints:InjectionPoint" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="XML" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.util:TokenUtil)" mod="1292231870000" size="1458" optimizedsize="844">
                          <def id="com.my.app.util:TokenUtil" />
                          <pre id="Object" />
                          <dep id="flash.utils:setTimeout" />
                          <dep id="mx.rpc.events:FaultEvent" />
                          <dep id="mx.rpc.events:ResultEvent" />
                          <dep id="AS3" />
                          <dep id="mx.rpc:IResponder" />
                          <dep id="mx.managers:CursorManager" />
                          <dep id="mx.messaging.messages:IMessage" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app:IMYAppPropApp)" mod="1295365151000" size="870" optimizedsize="286">
                          <def id="com.my.app:IMYAppPropApp" />
                          <pre id="Object" />
                          <dep id="mx.core:UIComponent" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:ViewMapBase)" mod="1269791984000" size="1628" optimizedsize="707">
                          <def id="org.robotlegs.base:ViewMapBase" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.events:RSLEvent)" mod="1306872054171" size="1357" optimizedsize="835">
                          <def id="mx.events:RSLEvent" />
                          <dep id="flash.net:URLRequest" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:Source)" mod="1308837429000" size="516" optimizedsize="218">
                          <def id="com.my.app.vo:Source" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.manager:ModalPopupManager)" mod="1295365151000" size="987" optimizedsize="489">
                          <def id="com.my.app.manager:ModalPopupManager" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/collections.properties" mod="1306854100000" size="1321" optimizedsize="1278">
                          <def id="en_US$collections_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_BoxDividerSkin_2002662361.as" mod="1306854026000" size="635" optimizedsize="374">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_BoxDividerSkin_2002662361" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:Category)" mod="1308837429000" size="631" optimizedsize="267">
                          <def id="com.my.app.vo:Category" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:MediaOutlet)" mod="1294221811000" size="519" optimizedsize="211">
                          <def id="com.my.app.vo:MediaOutlet" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IFlexModule)" mod="1306872041234" size="479" optimizedsize="188">
                          <def id="mx.core:IFlexModule" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:MediatorMap)" mod="1269791984000" size="4863" optimizedsize="2798">
                          <def id="org.robotlegs.base:MediatorMap" />
                          <pre id="org.robotlegs.core:IMediatorMap" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="org.robotlegs.base:ContextError" />
                          <dep id="org.robotlegs.core:IMediator" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.managers:ISystemManager)" mod="1306872044515" size="3304" optimizedsize="1012">
                          <def id="mx.managers:ISystemManager" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:CompetitorRemoteObject)" mod="1295365150000" size="1191" optimizedsize="753">
                          <def id="com.my.app.remoting:CompetitorRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ICompetitorRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.config:AppConfig)" mod="1295458204000" size="2079" optimizedsize="815">
                          <def id="com.my.app.config:AppConfig" />
                          <pre id="com.my.app.config:IAppConfig" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/modalCover/ModalCover.as" mod="1292231872000" size="1663" optimizedsize="950">
                          <def id="com.my.app.component.modalCover:ModalCover" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.events:FlexEvent)" mod="1306872053921" size="3715" optimizedsize="2479">
                          <def id="mx.events:FlexEvent" />
                          <dep id="AS3" />
                        </script>
                        <script name="_MYAppPro_Styles.as" mod="1309190215380" size="51724" optimizedsize="49421">
                          <def id="_MYAppPro_Styles" />
                          <pre id="Object" />
                          <dep id="mx.skins.halo:PopUpIcon" />
                          <dep id="mx.skins.halo:DataGridColumnResizeSkin" />
                          <dep id="mx.skins.spark:StepperIncrButtonSkin" />
                          <dep id="spark.skins.spark:ButtonBarSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_TreeFolderOpen_675819095" />
                          <dep id="spark.skins.spark:DropDownListSkin" />
                          <dep id="mx.skins.halo:LinkSeparator" />
                          <dep id="mx.skins.spark:ComboBoxSkin" />
                          <dep id="mx.skins.spark:MenuCheckDisabled" />
                          <dep id="mx.skins.spark:DateChooserRollOverIndicatorSkin" />
                          <dep id="spark.skins.spark:FormHeadingSkin" />
                          <dep id="mx.skins.halo:BrokenImageBorderSkin" />
                          <dep id="spark.skins.spark:ToggleButtonSkin" />
                          <dep id="spark.skins.spark:CheckBoxSkin" />
                          <dep id="mx.skins.spark:DateChooserPrevYearSkin" />
                          <dep id="mx.skins.spark:DateChooserTodayIndicatorSkin" />
                          <dep id="spark.skins.spark:TextInputSkin" />
                          <dep id="mx.skins.spark:ContainerBorderSkin" />
                          <dep id="mx.skins.spark:DataGridSortArrow" />
                          <dep id="mx.skins.spark:StepperDecrButtonSkin" />
                          <dep id="spark.components.supportClasses:ListItemDragProxy" />
                          <dep id="spark.skins.spark:ErrorSkin" />
                          <dep id="mx.skins.spark:MenuCheck" />
                          <dep id="spark.skins.spark.mediaClasses.normal:VolumeBarSkin" />
                          <dep id="mx.skins.spark:SliderThumbSkin" />
                          <dep id="mx.skins.spark:ScrollBarUpButtonSkin" />
                          <dep id="spark.skins.spark:TitleWindowSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragReject_207783805" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_CloseButtonDisabled_452580263" />
                          <dep id="mx.skins.spark:EditableComboBoxSkin" />
                          <dep id="mx.skins.spark:MenuArrow" />
                          <dep id="spark.skins.spark:TextAreaSkin" />
                          <dep id="spark.skins.spark.mediaClasses.normal:ScrubBarSkin" />
                          <dep id="_class_embed_css_assets_RequiredIndicator_png_673835973_1128945379" />
                          <dep id="spark.skins.spark:FocusSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_TreeDisclosureClosed_699467254" />
                          <dep id="mx.skins.spark:DateChooserPrevMonthSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_CloseButtonDown_2141261167" />
                          <dep id="mx.skins.spark:PanelBorderSkin" />
                          <dep id="mx.skins.spark:SliderTrackSkin" />
                          <dep id="mx.skins.spark:ButtonBarFirstButtonSkin" />
                          <dep id="mx.skins.halo:DataGridColumnDropIndicator" />
                          <dep id="mx.skins.halo:PopUpMenuIcon" />
                          <dep id="spark.skins.spark:BorderContainerSkin" />
                          <dep id="mx.skins.halo:DefaultDragImage" />
                          <dep id="spark.skins.spark:VScrollBarSkin" />
                          <dep id="AS3" />
                          <dep id="spark.skins.spark:DataGridSkin" />
                          <dep id="mx.skins.spark:TextInputBorderSkin" />
                          <dep id="mx.skins.spark:DateChooserNextYearSkin" />
                          <dep id="mx.skins.spark:MenuRadio" />
                          <dep id="mx.skins.halo:HaloFocusRect" />
                          <dep id="mx.skins.spark:RadioButtonSkin" />
                          <dep id="mx.skins.spark:DataGridHeaderBackgroundSkin" />
                          <dep id="mx.skins.halo:ListDropIndicator" />
                          <dep id="spark.skins.spark.mediaClasses.normal:MuteButtonSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_BusyCursor_961289295" />
                          <dep id="spark.skins.spark:ButtonSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_TreeNodeIcon_1957893340" />
                          <dep id="mx.skins.spark:SliderTrackHighlightSkin" />
                          <dep id="spark.skins.spark:VSliderSkin" />
                          <dep id="spark.skins.spark:NumericStepperSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_TreeDisclosureOpen_1114790232" />
                          <dep id="mx.skins.spark:ButtonBarMiddleButtonSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_BoxDividerSkin_2002662361" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_CloseButtonUp_904206584" />
                          <dep id="mx.skins.spark:TabSkin" />
                          <dep id="spark.skins.spark:SpinnerSkin" />
                          <dep id="mx.skins.spark:ColorPickerSkin" />
                          <dep id="mx.skins.spark:BorderSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_TreeFolderClosed_1909547451" />
                          <dep id="spark.skins.spark:ApplicationSkin" />
                          <dep id="mx.skins.spark:ButtonBarLastButtonSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragCopy_1279468729" />
                          <dep id="mx.skins.spark:MenuArrowDisabled" />
                          <dep id="_class_embed_css_assets_CalendarIcon_png__1170248551_1839914564" />
                          <dep id="mx.utils:ObjectUtil" />
                          <dep id="mx.skins.spark:ProgressMaskSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragLink_1279730734" />
                          <dep id="spark.skins.spark:ComboBoxSkin" />
                          <dep id="mx.skins.spark:ScrollBarDownButtonSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_CloseButtonOver_1977091201" />
                          <dep id="mx.skins.spark:CheckBoxSkin" />
                          <dep id="spark.skins.spark:ListDropIndicator" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_cursorStretch_1000132270" />
                          <dep id="spark.skins.spark:ListSkin" />
                          <dep id="spark.skins.spark:HSliderSkin" />
                          <dep id="mx.skins.halo:BusyCursor" />
                          <dep id="mx.skins.halo:DataGridHeaderSeparator" />
                          <dep id="_class_embed_css_assets_ErrorIndicator_png_2106318728_139432308" />
                          <dep id="spark.skins.spark:SkinnableContainerSkin" />
                          <dep id="spark.skins.spark:SkinnableDataContainerSkin" />
                          <dep id="mx.skins.spark:AccordionHeaderSkin" />
                          <dep id="spark.skins.spark:DefaultButtonSkin" />
                          <dep id="mx.skins.spark:MenuItemSkin" />
                          <dep id="spark.skins.spark:ImageSkin" />
                          <dep id="spark.skins.spark:PanelSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_HBoxDivider_1447722948" />
                          <dep id="mx.skins.spark:MenuSeparatorSkin" />
                          <dep id="spark.skins.spark:ScrollerSkin" />
                          <dep id="mx.skins.spark:DataGridHeaderSeparatorSkin" />
                          <dep id="mx.skins.spark:ScrollBarTrackSkin" />
                          <dep id="mx.skins.spark:ProgressBarTrackSkin" />
                          <dep id="mx.skins.spark:ProgressIndeterminateSkin" />
                          <dep id="mx.skins.halo:HaloBorder" />
                          <dep id="mx.skins.spark:PopUpButtonSkin" />
                          <dep id="spark.skins.spark:RadioButtonSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548___brokenImage_184772295" />
                          <dep id="mx.skins.spark:LinkButtonSkin" />
                          <dep id="spark.skins.spark:FormSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_containers_FormItem_Required_1292455008" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragMove_1279756309" />
                          <dep id="mx.skins.spark:MenuRadioDisabled" />
                          <dep id="spark.skins.spark:VideoPlayerSkin" />
                          <dep id="mx.skins.spark:DefaultButtonSkin" />
                          <dep id="mx.skins.spark:DateChooserNextMonthSkin" />
                          <dep id="spark.skins.spark:TabBarSkin" />
                          <dep id="mx.skins.spark:DateChooserSelectionIndicatorSkin" />
                          <dep id="mx.core:UITextField" />
                          <dep id="spark.skins.spark:FormItemSkin" />
                          <dep id="mx.skins.spark:ProgressBarSkin" />
                          <dep id="mx.skins.spark:ButtonSkin" />
                          <dep id="mx.skins.halo:ToolTipBorder" />
                          <dep id="mx.skins.spark:ScrollBarThumbSkin" />
                          <dep id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_VBoxDivider_1547151866" />
                          <dep id="spark.skins.spark:HScrollBarSkin" />
                          <dep id="spark.skins.spark:SkinnablePopUpContainerSkin" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IFlexModuleFactory)" mod="1306872039405" size="1991" optimizedsize="627">
                          <def id="mx.core:IFlexModuleFactory" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:ContextBase)" mod="1272123539000" size="1506" optimizedsize="729">
                          <def id="org.robotlegs.base:ContextBase" />
                          <pre id="Object" />
                          <dep id="flash.events:EventDispatcher" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.remoting:CachableDelegate)" mod="1292404678000" size="3790" optimizedsize="2001">
                          <def id="com.my.app.delegate.remoting:CachableDelegate" />
                          <pre id="Object" />
                          <dep id="flash.net:SharedObject" />
                          <dep id="AS3" />
                          <dep id="mx.rpc:Responder" />
                          <dep id="com.my.app.vo:CacheVO" />
                          <dep id="com.my.app.util:TokenUtil" />
                          <dep id="com.my.app.remoting.interfaces:ICachableRemoteObject" />
                          <dep id="Error" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_TreeFolderOpen_675819095.as" mod="1306854026000" size="604" optimizedsize="364">
                          <def id="_class_embed_css_Assets_swf_1422583548_TreeFolderOpen_675819095" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragLink_1279730734.as" mod="1306854026000" size="638" optimizedsize="375">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragLink_1279730734" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/loader/ILoaderController.as" mod="1294834258000" size="916" optimizedsize="289">
                          <def id="com.my.app.component.loader:ILoaderController" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:TextPod)" mod="1294221810000" size="586" optimizedsize="272">
                          <def id="com.my.app.vo:TextPod" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/module/helpText/IHelpTextModule.as" mod="1294397648000" size="1324" optimizedsize="456">
                          <def id="com.my.app.module.helpText:IHelpTextModule" />
                          <pre id="org.robotlegs.utilities.modular.core:IModule" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:TextMessage)" mod="1294221810000" size="573" optimizedsize="253">
                          <def id="com.my.app.vo:TextMessage" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_CloseButtonOver_1977091201.as" mod="1306854026000" size="611" optimizedsize="366">
                          <def id="_class_embed_css_Assets_swf_1422583548_CloseButtonOver_1977091201" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IRawChildrenContainer)" mod="1306872039046" size="443" optimizedsize="178">
                          <def id="mx.core:IRawChildrenContainer" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="mx.core:IChildList" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:RSSPod)" mod="1294221811000" size="626" optimizedsize="306">
                          <def id="com.my.app.vo:RSSPod" />
                          <dep id="AS3" />
                        </script>
                        <script name="MYAppPro__embed__font_MyriadPro_medium_normal_1029366919.as" mod="1291226944000" size="448" optimizedsize="226">
                          <def id="MYAppPro__embed__font_MyriadPro_medium_normal_1029366919" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:RSLItem)" mod="1306872039109" size="2632" optimizedsize="1678">
                          <def id="mx.core:RSLItem" />
                          <pre id="Object" />
                          <dep id="trace" />
                          <dep id="flash.events:SecurityErrorEvent" />
                          <dep id="flash.events:ProgressEvent" />
                          <dep id="AS3" />
                          <dep id="flash.system:LoaderContext" />
                          <dep id="flash.events:ErrorEvent" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:UserRemoteObject)" mod="1297671711000" size="2723" optimizedsize="1431">
                          <def id="com.my.app.remoting:UserRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IUserRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.domain.auth:Auth)" mod="1297076410000" size="3327" optimizedsize="1928">
                          <def id="com.my.app.domain.auth:Auth" />
                          <pre id="com.my.app.domain.auth:IAuth" />
                          <pre id="Object" />
                          <dep id="com.my.app.config:IAppConfig" />
                          <dep id="com.my.app.delegate.interfaces:IUserDelegate" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:CrossDomainRSLItem)" mod="1306872039187" size="4129" optimizedsize="2675">
                          <def id="mx.core:CrossDomainRSLItem" />
                          <dep id="flash.system:Security" />
                          <dep id="trace" />
                          <dep id="flash.net:URLLoaderDataFormat" />
                          <dep id="AS3" />
                          <dep id="mx.utils:SHA256" />
                          <dep id="flash.net:URLLoader" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:User)" mod="1308837429000" size="712" optimizedsize="362">
                          <def id="com.my.app.vo:User" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/core.properties" mod="1306854100000" size="1606" optimizedsize="1565">
                          <def id="en_US$core_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.adapters:SwiftSuspendersReflector)" mod="1269791984000" size="529" optimizedsize="289">
                          <def id="org.robotlegs.adapters:SwiftSuspendersReflector" />
                          <pre id="org.swiftsuspenders:Reflector" />
                          <pre id="org.robotlegs.core:IReflector" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:FlexShape)" mod="1306872039484" size="760" optimizedsize="490">
                          <def id="mx.core:FlexShape" />
                          <pre id="flash.display:Shape" />
                          <dep id="AS3" />
                          <dep id="Error" />
                          <dep id="mx.utils:NameUtil" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/printPopUp/PrintPopUp.as" mod="1299068658000" size="1847" optimizedsize="1095">
                          <def id="com.my.app.component.printPopUp:PrintPopUp" />
                          <pre id="com.my.app.component.printPopUp:PrintPopUpMarkup" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.events:ResourceEvent)" mod="1306872053890" size="976" optimizedsize="571">
                          <def id="mx.events:ResourceEvent" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionresults:InjectionResult)" mod="1272837850000" size="845" optimizedsize="362">
                          <def id="org.swiftsuspenders.injectionresults:InjectionResult" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.resources:IResourceBundle)" mod="1306872057390" size="636" optimizedsize="221">
                          <def id="mx.resources:IResourceBundle" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:BaseRemoteObject)" mod="1297671711000" size="1157" optimizedsize="643">
                          <def id="com.my.app.remoting:BaseRemoteObject" />
                          <pre id="mx.rpc.remoting:RemoteObject" />
                          <dep id="AS3" />
                          <dep id="mx.messaging.channels:AMFChannel" />
                          <dep id="mx.messaging:ChannelSet" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/MYAppProApp.as" mod="1308837419000" size="5257" optimizedsize="3821">
                          <def id="com.my.app:MYAppProApp" />
                          <pre id="spark.components:Application" />
                          <pre id="com.my.app:IMYAppPropApp" />
                          <dep id="flash.ui:ContextMenuItem" />
                          <dep id="com.my.app.component.modalCover:ModalCover" />
                          <dep id="AS3" />
                          <dep id="com.my.app.component.dashboardTitleAlert:DashboardTitleAlert" />
                          <dep id="com.jac.mouse:MouseWheelEnabler" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.events:SandboxMouseEvent)" mod="1306872053984" size="1596" optimizedsize="973">
                          <def id="mx.events:SandboxMouseEvent" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IQueryPodRemoteObject)" mod="1294680437000" size="1468" optimizedsize="418">
                          <def id="com.my.app.remoting.interfaces:IQueryPodRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:TextPodRemoteObject)" mod="1294221810000" size="1668" optimizedsize="950">
                          <def id="com.my.app.remoting:TextPodRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ITextPodRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionresults:InjectOtherRuleResult)" mod="1272837850000" size="773" optimizedsize="361">
                          <def id="org.swiftsuspenders.injectionresults:InjectOtherRuleResult" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.mvcs:Mediator)" mod="1271434088000" size="2014" optimizedsize="1066">
                          <def id="org.robotlegs.mvcs:Mediator" />
                          <pre id="org.robotlegs.base:MediatorBase" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/spark_rb.swc$locale/en_US/sparkEffects.properties" mod="1306853870000" size="1035" optimizedsize="1002">
                          <def id="en_US$sparkEffects_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.remoting:DashboardDelegate)" mod="1308837430000" size="2728" optimizedsize="1366">
                          <def id="com.my.app.delegate.remoting:DashboardDelegate" />
                          <pre id="com.my.app.delegate.interfaces:IDashboardDelegate" />
                          <dep id="AS3" />
                          <dep id="mx.rpc:AsyncToken" />
                          <dep id="com.my.app.remoting.interfaces:IDashboardRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:IDashboardPodRemoteObject" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.utils:SHA256)" mod="1306872046952" size="3460" optimizedsize="2330">
                          <def id="mx.utils:SHA256" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/asyncRetry/AsyncRetryMarkup.mxml" mod="1308837414000" size="7155" optimizedsize="4427">
                          <def id="com.my.app.component.asyncRetry:AsyncRetryMarkup" />
                          <dep id="mx.core:UIComponentDescriptor" />
                          <dep id="com.my.app.skins:LinkButtonSkin" />
                          <dep id="AS3" />
                          <dep id="mx.containers:HBox" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:IContext)" mod="1269791984000" size="458" optimizedsize="199">
                          <def id="org.robotlegs.core:IContext" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/skins/SilverButtonSkin.mxml" mod="1308837418000" size="5249" optimizedsize="3292">
                          <def id="com.my.app.skins:SilverButtonSkin" />
                          <dep id="mx.graphics:GradientEntry" />
                          <dep id="AS3" />
                          <dep id="mx.graphics:LinearGradient" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.resources:IResourceModule)" mod="1306872057374" size="451" optimizedsize="178">
                          <def id="mx.resources:IResourceModule" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/formatters.properties" mod="1306854100000" size="797" optimizedsize="755">
                          <def id="en_US$formatters_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.resources:ResourceBundle)" mod="1306872057343" size="1650" optimizedsize="852">
                          <def id="mx.resources:ResourceBundle" />
                          <pre id="mx.resources:IResourceBundle" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="mx.core:mx_internal" />
                          <dep id="Error" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/rpc_rb.swc$locale/en_US/messaging.properties" mod="1306853942000" size="5888" optimizedsize="5789">
                          <def id="en_US$messaging_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.utils:StringUtil)" mod="1306872047155" size="2664" optimizedsize="1456">
                          <def id="mx.utils:StringUtil" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="RegExp" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:RuntimeDPIProvider)" mod="1306872039296" size="806" optimizedsize="430">
                          <def id="mx.core:RuntimeDPIProvider" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="mx.core:DPIClassification" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/printPopUp/PrintPopUpMarkup.mxml" mod="1308837414000" size="3805" optimizedsize="2211">
                          <def id="com.my.app.component.printPopUp:PrintPopUpMarkup" />
                          <pre id="flash.events:IEventDispatcher" />
                          <dep id="mx.core:IFlexModuleFactory" />
                          <dep id="mx.core:DeferredInstanceFromFunction" />
                          <dep id="AS3" />
                          <dep id="mx.events:PropertyChangeEvent" />
                          <dep id="mx.binding:BindingManager" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.interfaces:ICachableDelegate)" mod="1292345879000" size="676" optimizedsize="263">
                          <def id="com.my.app.delegate.interfaces:ICachableDelegate" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.remoting:BaseDelegate)" mod="1292345880000" size="462" optimizedsize="212">
                          <def id="com.my.app.delegate.remoting:BaseDelegate" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_BusyCursor_961289295.as" mod="1306854026000" size="641" optimizedsize="376">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_BusyCursor_961289295" />
                          <pre id="mx.core:SpriteAsset" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.utils:DensityUtil)" mod="1306872046999" size="989" optimizedsize="564">
                          <def id="mx.utils:DensityUtil" />
                          <pre id="Object" />
                          <dep id="mx.core:RuntimeDPIProvider" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/HelpTextModuleLoader.as" mod="1294395170000" size="1891" optimizedsize="1169">
                          <def id="com.my.app.loader:HelpTextModuleLoader" />
                          <pre id="com.my.app.loader:BaseModuleLoader" />
                          <dep id="AS3" />
                          <dep id="com.my.app.module.helpText:IHelpTextModule" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IFlexDisplayObject)" mod="1306872041312" size="5953" optimizedsize="1339">
                          <def id="mx.core:IFlexDisplayObject" />
                          <pre id="flash.display:IBitmapDrawable" />
                          <pre id="Object" />
                          <dep id="flash.accessibility:AccessibilityProperties" />
                          <dep id="AS3" />
                          <dep id="flash.display:DisplayObjectContainer" />
                          <dep id="flash.geom:Transform" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/charts_rb.swc$locale/en_US/charts.properties" mod="1306853994000" size="353" optimizedsize="323">
                          <def id="en_US$charts_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:MediaTypeRemoteObject)" mod="1308837429000" size="1333" optimizedsize="803">
                          <def id="com.my.app.remoting:MediaTypeRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IMediaTypeRemoteObject" />
                          <pre id="com.my.app.remoting:BaseRemoteObject" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/as3-signals.swc(org.osflash.signals:ISignal)" mod="1291821251428" size="1040" optimizedsize="289">
                          <def id="org.osflash.signals:ISignal" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/spark_rb.swc$locale/en_US/layout.properties" mod="1306853870000" size="646" optimizedsize="615">
                          <def id="en_US$layout_properties" />
                          <pre id="mx.resources:ResourceBundle" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_TreeDisclosureOpen_1114790232.as" mod="1306854026000" size="620" optimizedsize="369">
                          <def id="_class_embed_css_Assets_swf_1422583548_TreeDisclosureOpen_1114790232" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.utilities.modular.core:IModule)" mod="1288804392244" size="831" optimizedsize="257">
                          <def id="org.robotlegs.utilities.modular.core:IModule" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.interfaces:IQueryPodDelegate)" mod="1294681159000" size="1337" optimizedsize="391">
                          <def id="com.my.app.delegate.interfaces:IQueryPodDelegate" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:Competitor)" mod="1295374588000" size="628" optimizedsize="294">
                          <def id="com.my.app.vo:Competitor" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_com_my_app_view_MainViewMarkupWatcherSetupUtil.as" mod="1309189519652" size="1016" optimizedsize="561">
                          <def id="_com_my_app_view_MainViewMarkupWatcherSetupUtil" />
                          <pre id="Object" />
                          <pre id="mx.binding:IWatcherSetupUtil2" />
                          <dep id="mx.binding:PropertyWatcher" />
                          <dep id="AS3" />
                          <dep id="com.my.app.view:MainViewMarkup" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:RevertableVO)" mod="1292434523000" size="1353" optimizedsize="786">
                          <def id="com.my.app.vo:RevertableVO" />
                          <pre id="Object" />
                          <dep id="flash.utils:describeType" />
                          <dep id="org.osflash.signals:Signal" />
                          <dep id="AS3" />
                          <dep id="org.osflash.signals:ISignal" />
                          <dep id="XMLList" />
                          <dep id="flash.utils:Dictionary" />
                          <dep id="Error" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:UserSnippet)" mod="1294221810000" size="553" optimizedsize="243">
                          <def id="com.my.app.vo:UserSnippet" />
                          <pre id="com.my.app.vo:RevertableVO" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_VBoxDivider_1547151866.as" mod="1306854026000" size="647" optimizedsize="378">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_VBoxDivider_1547151866" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/asyncRetry/AsyncRetry.as" mod="1297076373000" size="2516" optimizedsize="1614">
                          <def id="com.my.app.component.asyncRetry:AsyncRetry" />
                          <pre id="com.my.app.component.asyncRetry:AsyncRetryMarkup" />
                          <dep id="com.my.app.action:FeedbackAsyncAction" />
                          <dep id="AS3" />
                          <dep id="com.my.app.action:SaveUserAsyncAction" />
                          <dep id="mx.core:FlexGlobals" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IQueryRemoteObject)" mod="1297076409000" size="1728" optimizedsize="531">
                          <def id="com.my.app.remoting.interfaces:IQueryRemoteObject" />
                          <pre id="Object" />
                          <dep id="com.my.app.vo:Query" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_TreeNodeIcon_1957893340.as" mod="1306854026000" size="601" optimizedsize="363">
                          <def id="_class_embed_css_Assets_swf_1422583548_TreeNodeIcon_1957893340" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:QueryPod)" mod="1295279246000" size="729" optimizedsize="371">
                          <def id="com.my.app.vo:QueryPod" />
                          <dep id="Date" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_assets_RequiredIndicator_png_673835973_1128945379.as" mod="1306853820000" size="560" optimizedsize="317">
                          <def id="_class_embed_css_assets_RequiredIndicator_png_673835973_1128945379" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_HBoxDivider_1447722948.as" mod="1306854026000" size="647" optimizedsize="378">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_HBoxDivider_1447722948" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:ContextError)" mod="1272123539000" size="1371" optimizedsize="987">
                          <def id="org.robotlegs.base:ContextError" />
                          <pre id="Error" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/skins.properties" mod="1306854100000" size="286" optimizedsize="260">
                          <def id="en_US$skins_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.action:AsyncAction)" mod="1297671711000" size="3827" optimizedsize="1923">
                          <def id="com.my.app.action:AsyncAction" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="com.my.app.vo:RevertableVO" />
                          <dep id="Error" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ICustomerRemoteObject)" mod="1292416824000" size="1097" optimizedsize="359">
                          <def id="com.my.app.remoting.interfaces:ICustomerRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_TreeFolderClosed_1909547451.as" mod="1306854026000" size="614" optimizedsize="367">
                          <def id="_class_embed_css_Assets_swf_1422583548_TreeFolderClosed_1909547451" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:IReflector)" mod="1269791984000" size="819" optimizedsize="311">
                          <def id="org.robotlegs.core:IReflector" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="flash.system:ApplicationDomain" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ICustomerFileRemoteObject)" mod="1294750696000" size="1102" optimizedsize="336">
                          <def id="com.my.app.remoting.interfaces:ICustomerFileRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IJournalistRemoteObject)" mod="1292425551000" size="705" optimizedsize="268">
                          <def id="com.my.app.remoting.interfaces:IJournalistRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.graphics:RectangularDropShadow)" mod="1306872050187" size="6752" optimizedsize="3389">
                          <def id="mx.graphics:RectangularDropShadow" />
                          <pre id="Object" />
                          <dep id="mx.core:FlexShape" />
                          <dep id="flash.display:BitmapData" />
                          <dep id="AS3" />
                          <dep id="flash.geom:Matrix" />
                          <dep id="Math" />
                          <dep id="flash.filters:DropShadowFilter" />
                          <dep id="mx.utils:GraphicsUtil" />
                          <dep id="flash.display:Shape" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ITextPodRemoteObject)" mod="1294221810000" size="1256" optimizedsize="378">
                          <def id="com.my.app.remoting.interfaces:ITextPodRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.utils:GraphicsUtil)" mod="1306872047062" size="2556" optimizedsize="1443">
                          <def id="mx.utils:GraphicsUtil" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.jac.mouse:MouseWheelEnabler)" mod="1297076410000" size="7694" optimizedsize="6545">
                          <def id="com.jac.mouse:MouseWheelEnabler" />
                          <pre id="Object" />
                          <dep id="com.jac.mouse:BrowserInfo" />
                          <dep id="flash.events:MouseEvent" />
                          <dep id="AS3" />
                          <dep id="flash.external:ExternalInterface" />
                          <dep id="flash.display:InteractiveObject" />
                          <dep id="Math" />
                          <dep id="XML" />
                          <dep id="flash.utils:getTimer" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.events:DynamicEvent)" mod="1306872053859" size="837" optimizedsize="495">
                          <def id="mx.events:DynamicEvent" />
                          <pre id="flash.events:Event" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.enum:TextServiceNames)" mod="1292244216000" size="589" optimizedsize="310">
                          <def id="com.my.app.enum:TextServiceNames" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_assets_ErrorIndicator_png_2106318728_139432308.as" mod="1306853820000" size="550" optimizedsize="314">
                          <def id="_class_embed_css_assets_ErrorIndicator_png_2106318728_139432308" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.utils:LoaderUtil)" mod="1306872047124" size="5991" optimizedsize="3443">
                          <def id="mx.utils:LoaderUtil" />
                          <pre id="Object" />
                          <dep id="Math" />
                          <dep id="Error" />
                          <dep id="mx.core:ApplicationDomainTarget" />
                          <dep id="AS3" />
                          <dep id="flash.system:Capabilities" />
                          <dep id="flash.display:DisplayObject" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.interfaces:IUserDelegate)" mod="1291735515000" size="808" optimizedsize="273">
                          <def id="com.my.app.delegate.interfaces:IUserDelegate" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/as3-signals.swc(org.osflash.signals:Signal)" mod="1291821251491" size="3849" optimizedsize="2329">
                          <def id="org.osflash.signals:Signal" />
                          <pre id="org.osflash.signals:IDispatcher" />
                          <pre id="Object" />
                          <pre id="org.osflash.signals:ISignalOwner" />
                          <dep id="flash.utils:getQualifiedClassName" />
                          <dep id="flash.errors:IllegalOperationError" />
                          <dep id="AS3" />
                          <dep id="Class" />
                          <dep id="org.osflash.signals:Slot" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/rpc_rb.swc$locale/en_US/rpc.properties" mod="1306853942000" size="4200" optimizedsize="4124">
                          <def id="en_US$rpc_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/as3-signals.swc(org.osflash.signals:IDispatcher)" mod="1291821251357" size="542" optimizedsize="176">
                          <def id="org.osflash.signals:IDispatcher" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:Journalist)" mod="1294221810000" size="512" optimizedsize="208">
                          <def id="com.my.app.vo:Journalist" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:CustomerSnippet)" mod="1294221811000" size="612" optimizedsize="276">
                          <def id="com.my.app.vo:CustomerSnippet" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:DashboardSnippet)" mod="1295255883000" size="640" optimizedsize="260">
                          <def id="com.my.app.vo:DashboardSnippet" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.action:SaveUserAsyncAction)" mod="1297076410000" size="1596" optimizedsize="770">
                          <def id="com.my.app.action:SaveUserAsyncAction" />
                          <pre id="com.my.app.action:FeedbackAsyncAction" />
                          <dep id="com.my.app.vo:User" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:Dashboard)" mod="1297671711000" size="626" optimizedsize="294">
                          <def id="com.my.app.vo:Dashboard" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:EventMap)" mod="1269791984000" size="2662" optimizedsize="1620">
                          <def id="org.robotlegs.base:EventMap" />
                          <pre id="org.robotlegs.core:IEventMap" />
                          <pre id="Object" />
                          <dep id="flash.events:Event" />
                          <dep id="flash.events:IEventDispatcher" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.events:Request)" mod="1306872053874" size="815" optimizedsize="481">
                          <def id="mx.events:Request" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_CloseButtonDown_2141261167.as" mod="1306854026000" size="611" optimizedsize="366">
                          <def id="_class_embed_css_Assets_swf_1422583548_CloseButtonDown_2141261167" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ICategoryRemoteObject)" mod="1292434523000" size="660" optimizedsize="247">
                          <def id="com.my.app.remoting.interfaces:ICategoryRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IDashboardPodRemoteObject)" mod="1295255883000" size="1357" optimizedsize="408">
                          <def id="com.my.app.remoting.interfaces:IDashboardPodRemoteObject" />
                          <pre id="Object" />
                          <dep id="com.my.app.vo:DashboardPod" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:RSSPodRemoteObject)" mod="1294221809000" size="1641" optimizedsize="937">
                          <def id="com.my.app.remoting:RSSPodRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IRSSPodRemoteObject" />
                          <dep id="AS3" />
                          <dep id="com.my.app.vo:RSSPod" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.managers:SystemManagerGlobals)" mod="1306872044499" size="745" optimizedsize="429">
                          <def id="mx.managers:SystemManagerGlobals" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_MYAppProWatcherSetupUtil.as" mod="1309190214996" size="636" optimizedsize="340">
                          <def id="_MYAppProWatcherSetupUtil" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="MYAppPro" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/as3-signals.swc(org.osflash.signals:ISignalOwner)" mod="1291821251432" size="568" optimizedsize="207">
                          <def id="org.osflash.signals:ISignalOwner" />
                          <pre id="org.osflash.signals:ISignal" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.modules:ModuleManager)" mod="1306872055343" size="10361" optimizedsize="5392">
                          <def id="mx.modules:ModuleManager" />
                          <pre id="mx.modules:IModuleInfo" />
                          <pre id="Object" />
                          <dep id="Error" />
                          <dep id="mx.modules:ModuleManagerGlobals" />
                          <dep id="flash.system:SecurityDomain" />
                          <dep id="AS3" />
                          <dep id="mx.events:ModuleEvent" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IUIComponent)" mod="1306872041202" size="4393" optimizedsize="1152">
                          <def id="mx.core:IUIComponent" />
                          <pre id="Object" />
                          <dep id="mx.managers:ISystemManager" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:IViewMap)" mod="1269791984000" size="1419" optimizedsize="413">
                          <def id="org.robotlegs.core:IViewMap" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IMediaSummaryPodRemoteObject)" mod="1294413145000" size="1681" optimizedsize="484">
                          <def id="com.my.app.remoting.interfaces:IMediaSummaryPodRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.jac.mouse:BrowserInfo)" mod="1297076410000" size="1438" optimizedsize="775">
                          <def id="com.jac.mouse:BrowserInfo" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:ApplicationDomainTarget)" mod="1306872041124" size="669" optimizedsize="396">
                          <def id="mx.core:ApplicationDomainTarget" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/module/header/IHeaderModule.as" mod="1308837416000" size="2910" optimizedsize="756">
                          <def id="com.my.app.module.header:IHeaderModule" />
                          <pre id="Object" />
                          <dep id="com.my.app.vo:DashboardSnippet" />
                          <dep id="AS3" />
                          <dep id="com.my.app.vo:QuerySnippet" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ISourceRemoteObject)" mod="1292434523000" size="670" optimizedsize="257">
                          <def id="com.my.app.remoting.interfaces:ISourceRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:IMediatorMap)" mod="1269791984000" size="2038" optimizedsize="555">
                          <def id="org.robotlegs.core:IMediatorMap" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionresults:InjectValueResult)" mod="1272837850000" size="757" optimizedsize="345">
                          <def id="org.swiftsuspenders.injectionresults:InjectValueResult" />
                          <pre id="org.swiftsuspenders.injectionresults:InjectionResult" />
                          <dep id="AS3" />
                          <dep id="org.swiftsuspenders:Injector" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IRepeaterClient)" mod="1306872039140" size="1116" optimizedsize="321">
                          <def id="mx.core:IRepeaterClient" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:MediaType)" mod="1294221810000" size="506" optimizedsize="206">
                          <def id="com.my.app.vo:MediaType" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders:Injector)" mod="1273448533000" size="7919" optimizedsize="4888">
                          <def id="org.swiftsuspenders:Injector" />
                          <pre id="Object" />
                          <dep id="org.swiftsuspenders.injectionpoints:InjectionPoint" />
                          <dep id="org.swiftsuspenders.injectionpoints:PropertyInjectionPoint" />
                          <dep id="org.swiftsuspenders.injectionpoints:NoParamsConstructorInjectionPoint" />
                          <dep id="org.swiftsuspenders.injectionresults:InjectClassResult" />
                          <dep id="org.swiftsuspenders.injectionresults:InjectSingletonResult" />
                          <dep id="org.swiftsuspenders.injectionresults:InjectOtherRuleResult" />
                          <dep id="org.swiftsuspenders.injectionpoints:PostConstructInjectionPoint" />
                          <dep id="org.swiftsuspenders:getConstructor" />
                          <dep id="org.swiftsuspenders:InjectionConfig" />
                          <dep id="org.swiftsuspenders:InjectorError" />
                          <dep id="org.swiftsuspenders.injectionresults:InjectValueResult" />
                          <dep id="AS3" />
                          <dep id="org.swiftsuspenders.injectionpoints:MethodInjectionPoint" />
                          <dep id="flash.utils:getDefinitionByName" />
                          <dep id="XML" />
                          <dep id="org.swiftsuspenders.injectionpoints:ConstructorInjectionPoint" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:IInjector)" mod="1273448729000" size="1708" optimizedsize="515">
                          <def id="org.robotlegs.core:IInjector" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragMove_1279756309.as" mod="1306854026000" size="638" optimizedsize="375">
                          <def id="_class_embed_css_Assets_swf_1422583548_mx_skins_cursor_DragMove_1279756309" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IUserRemoteObject)" mod="1297671711000" size="1627" optimizedsize="484">
                          <def id="com.my.app.remoting.interfaces:IUserRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ICachableRemoteObject" />
                          <pre id="Object" />
                          <dep id="com.my.app.vo:CustomerSnippet" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IMediaOutletRemoteObject)" mod="1292429701000" size="708" optimizedsize="268">
                          <def id="com.my.app.remoting.interfaces:IMediaOutletRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/context/MYAppProContext.as" mod="1308837418000" size="4345" optimizedsize="3468">
                          <def id="com.my.app.context:MYAppProContext" />
                          <pre id="org.robotlegs.mvcs:Context" />
                          <dep id="com.my.app.domain.auth:Auth" />
                          <dep id="com.my.app.remoting.interfaces:IMediaSummaryPodRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:IJournalistRemoteObject" />
                          <dep id="com.my.app.remoting:QueryPodRemoteObject" />
                          <dep id="com.my.app.remoting:MediaSummaryPodRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:ICustomerFileRemoteObject" />
                          <dep id="com.my.app.view:MainView" />
                          <dep id="com.my.app.remoting:CompetitorRemoteObject" />
                          <dep id="com.my.app.remoting:DashboardRemoteObject" />
                          <dep id="com.my.app.delegate.interfaces:IDashboardDelegate" />
                          <dep id="com.my.app.delegate.remoting:QueryPodDelegate" />
                          <dep id="com.my.app.remoting:SourceRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:IRSSPodRemoteObject" />
                          <dep id="com.my.app.remoting:MediaOutletRemoteObject" />
                          <dep id="com.my.app.remoting:UserRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:IMediaOutletRemoteObject" />
                          <dep id="com.my.app.remoting:RSSPodRemoteObject" />
                          <dep id="com.my.app.remoting:MediaTypeRemoteObject" />
                          <dep id="com.my.app.config:AppConfig" />
                          <dep id="com.my.app.remoting.interfaces:ISourceRemoteObject" />
                          <dep id="com.my.app.remoting:TextRemoteObject" />
                          <dep id="com.my.app.remoting:CustomerFileRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:IMediaTypeRemoteObject" />
                          <dep id="com.my.app.remoting:DashboardPodRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:ITextPodRemoteObject" />
                          <dep id="com.my.app.remoting:JournalistRemoteObject" />
                          <dep id="AS3" />
                          <dep id="com.my.app.delegate.interfaces:IQueryDelegate" />
                          <dep id="com.my.app.delegate.remoting:DashboardDelegate" />
                          <dep id="com.my.app.remoting:TextPodRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:ICompetitorRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:IQueryRemoteObject" />
                          <dep id="com.my.app.remoting.interfaces:ITextRemoteObject" />
                          <dep id="com.my.app.remoting:QueryRemoteObject" />
                          <dep id="com.my.app.remoting:CustomerRemoteObject" />
                          <dep id="com.my.app.delegate.interfaces:IQueryPodDelegate" />
                          <dep id="com.my.app.remoting.interfaces:IQueryPodRemoteObject" />
                          <dep id="com.my.app.remoting:CategoryRemoteObject" />
                          <dep id="com.my.app.mediator:MainViewMediator" />
                          <dep id="Error" />
                          <dep id="com.my.app.remoting.interfaces:ICustomerRemoteObject" />
                          <dep id="com.my.app.delegate.remoting:QueryDelegate" />
                          <dep id="com.my.app.remoting.interfaces:ICategoryRemoteObject" />
                          <dep id="com.my.app.delegate.remoting:UserDelegate" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.interfaces:IDashboardDelegate)" mod="1308837430000" size="2497" optimizedsize="622">
                          <def id="com.my.app.delegate.interfaces:IDashboardDelegate" />
                          <pre id="Object" />
                          <dep id="com.my.app.vo:Dashboard" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:IEventMap)" mod="1269791984000" size="846" optimizedsize="335">
                          <def id="org.robotlegs.core:IEventMap" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/module/queryBuilder/IQueryBuilderModule.as" mod="1297160555000" size="4734" optimizedsize="933">
                          <def id="com.my.app.module.queryBuilder:IQueryBuilderModule" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_MYAppPro_mx_managers_SystemManager.as" mod="1309190215868" size="5358" optimizedsize="4058">
                          <def id="_MYAppPro_mx_managers_SystemManager" />
                          <pre id="mx.core:IFlexModuleFactory" />
                          <pre id="mx.managers:SystemManager" />
                          <pre id="flashx.textLayout.compose:ISWFContext" />
                          <dep id="mx.core:RSLData" />
                          <dep id="AS3" />
                          <dep id="mx.core:Singleton" />
                          <dep id="mx.core:IFlexModule" />
                          <dep id="mx.events:RSLEvent" />
                          <dep id="flash.display:LoaderInfo" />
                          <dep id="mx.core:CrossDomainRSLItem" />
                          <dep id="mx.preloaders:SparkDownloadProgressBar" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.domain.auth:IAuth)" mod="1295365150000" size="1574" optimizedsize="477">
                          <def id="com.my.app.domain.auth:IAuth" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.resources:ResourceManager)" mod="1306872057359" size="991" optimizedsize="657">
                          <def id="mx.resources:ResourceManager" />
                          <pre id="Object" />
                          <dep id="mx.resources:IResourceManager" />
                          <dep id="AS3" />
                          <dep id="mx.resources:ResourceManagerImpl" />
                          <dep id="Error" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.remoting:QueryDelegate)" mod="1308837430000" size="2578" optimizedsize="1326">
                          <def id="com.my.app.delegate.remoting:QueryDelegate" />
                          <pre id="com.my.app.delegate.interfaces:IQueryDelegate" />
                          <pre id="com.my.app.delegate.remoting:CachableDelegate" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/loader/FeedbackModuleLoader.as" mod="1291735514000" size="932" optimizedsize="605">
                          <def id="com.my.app.loader:FeedbackModuleLoader" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:Singleton)" mod="1306872041421" size="987" optimizedsize="552">
                          <def id="mx.core:Singleton" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Error" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:MediaSummaryItem)" mod="1294413145000" size="651" optimizedsize="256">
                          <def id="com.my.app.vo:MediaSummaryItem" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/textLayout.swc(flashx.textLayout.compose:ISWFContext)" mod="1295643053953" size="679" optimizedsize="234">
                          <def id="flashx.textLayout.compose:ISWFContext" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/module/dashboard/IDashboardModule.as" mod="1309186717000" size="5017" optimizedsize="1131">
                          <def id="com.my.app.module.dashboard:IDashboardModule" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/asyncPasswordEnter/AsyncPasswordEnterMarkup.mxml" mod="1308837414000" size="6335" optimizedsize="3399">
                          <def id="com.my.app.component.asyncPasswordEnter:AsyncPasswordEnterMarkup" />
                          <pre id="spark.components:Group" />
                          <dep id="com.my.app.component.feedbackDisplay:FeedbackDisplay" />
                          <dep id="spark.components:TextInput" />
                          <dep id="spark.components:Button" />
                          <dep id="com.my.app.skins:PopupSkin" />
                          <dep id="spark.components:SkinnableContainer" />
                          <dep id="spark.components:Label" />
                          <dep id="spark.layouts:VerticalLayout" />
                          <dep id="AS3" />
                          <dep id="com.my.app.skins:SilverButtonSkin" />
                          <dep id="spark.components:HGroup" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/locale/en_US/airframework_rb.swc$locale/en_US/containers.properties" mod="1306853974000" size="451" optimizedsize="422">
                          <def id="en_US$containers_properties" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:Customer)" mod="1308837429000" size="5751" optimizedsize="3076">
                          <def id="com.my.app.vo:Customer" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:MediaSummaryPodRemoteObject)" mod="1294413145000" size="2107" optimizedsize="1161">
                          <def id="com.my.app.remoting:MediaSummaryPodRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:IMediaSummaryPodRemoteObject" />
                          <dep id="AS3" />
                          <dep id="com.my.app.vo:MediaSummaryPod" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:QueryResultElement)" mod="1308837429000" size="1267" optimizedsize="700">
                          <def id="com.my.app.vo:QueryResultElement" />
                          <pre id="Object" />
                          <dep id="mx.utils:UIDUtil" />
                          <dep id="Date" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.delegate.interfaces:IQueryDelegate)" mod="1295440484000" size="2051" optimizedsize="512">
                          <def id="com.my.app.delegate.interfaces:IQueryDelegate" />
                          <pre id="com.my.app.delegate.interfaces:ICachableDelegate" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionpoints:PropertyInjectionPoint)" mod="1273448700000" size="1592" optimizedsize="939">
                          <def id="org.swiftsuspenders.injectionpoints:PropertyInjectionPoint" />
                          <pre id="org.swiftsuspenders.injectionpoints:InjectionPoint" />
                          <dep id="AS3" />
                          <dep id="XML" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders.injectionresults:InjectSingletonResult)" mod="1272837850000" size="1090" optimizedsize="539">
                          <def id="org.swiftsuspenders.injectionresults:InjectSingletonResult" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:FlexSprite)" mod="1306872041327" size="826" optimizedsize="548">
                          <def id="mx.core:FlexSprite" />
                          <pre id="flash.display:Sprite" />
                          <dep id="AS3" />
                          <dep id="Error" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:ICompetitorRemoteObject)" mod="1295365150000" size="676" optimizedsize="252">
                          <def id="com.my.app.remoting.interfaces:ICompetitorRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/asyncPasswordEnter/AsyncPasswordEnter.as" mod="1295365137000" size="2837" optimizedsize="1627">
                          <def id="com.my.app.component.asyncPasswordEnter:AsyncPasswordEnter" />
                          <pre id="com.my.app.component.asyncPasswordEnter:AsyncPasswordEnterMarkup" />
                          <dep id="flash.ui:Keyboard" />
                          <dep id="spark.components:Application" />
                          <dep id="AS3" />
                          <dep id="flash.events:KeyboardEvent" />
                          <dep id="com.my.app.manager:ModalPopupManager" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/src/com/my/app/component/feedbackDisplay/FeedbackDisplay.as" mod="1291735514000" size="2265" optimizedsize="1279">
                          <def id="com.my.app.component.feedbackDisplay:FeedbackDisplay" />
                          <pre id="spark.components:VGroup" />
                          <dep id="AS3" />
                          <dep id="flash.utils:Timer" />
                          <dep id="flash.events:TimerEvent" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.modules:ModuleManagerGlobals)" mod="1306872055374" size="417" optimizedsize="211">
                          <def id="mx.modules:ModuleManagerGlobals" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="_com_my_app_skins_RoundedCornerTextInputSkinWatcherSetupUtil.as" mod="1309189520085" size="1384" optimizedsize="923">
                          <def id="_com_my_app_skins_RoundedCornerTextInputSkinWatcherSetupUtil" />
                          <pre id="Object" />
                          <dep id="mx.binding:FunctionReturnWatcher" />
                          <dep id="AS3" />
                          <dep id="com.my.app.skins:RoundedCornerTextInputSkin" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.managers:SystemChildrenList)" mod="1306872044530" size="2903" optimizedsize="1609">
                          <def id="mx.managers:SystemChildrenList" />
                          <pre id="mx.core:IChildList" />
                          <pre id="Object" />
                          <dep id="QName" />
                          <dep id="AS3" />
                          <dep id="mx.managers:SystemManager" />
                          <dep id="flash.geom:Point" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.preloaders:Preloader)" mod="1306872047421" size="6835" optimizedsize="4285">
                          <def id="mx.preloaders:Preloader" />
                          <dep id="mx.core:ResourceModuleRSLItem" />
                          <dep id="flash.events:IOErrorEvent" />
                          <dep id="Error" />
                          <dep id="mx.core:RSLItem" />
                          <dep id="mx.preloaders:IPreloaderDisplay" />
                          <dep id="AS3" />
                          <dep id="mx.core:RSLListLoader" />
                          <dep id="mx.events:FlexEvent" />
                          <dep id="flash.display:MovieClip" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.core:IMediator)" mod="1269791984000" size="989" optimizedsize="303">
                          <def id="org.robotlegs.core:IMediator" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.robotlegs.base:CommandMap)" mod="1271434072000" size="3724" optimizedsize="2287">
                          <def id="org.robotlegs.base:CommandMap" />
                          <pre id="org.robotlegs.core:ICommandMap" />
                          <pre id="Object" />
                          <dep id="org.robotlegs.core:IInjector" />
                          <dep id="AS3" />
                          <dep id="org.robotlegs.core:IReflector" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppPro/libs/robotlegs-framework-modules.swc(org.swiftsuspenders:InjectorError)" mod="1272837850000" size="471" optimizedsize="207">
                          <def id="org.swiftsuspenders:InjectorError" />
                          <pre id="Error" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting:CustomerRemoteObject)" mod="1292418440000" size="1519" optimizedsize="884">
                          <def id="com.my.app.remoting:CustomerRemoteObject" />
                          <pre id="com.my.app.remoting.interfaces:ICustomerRemoteObject" />
                          <dep id="AS3" />
                          <dep id="com.my.app.vo:Customer" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.remoting.interfaces:IDashboardRemoteObject)" mod="1308837429000" size="2117" optimizedsize="567">
                          <def id="com.my.app.remoting.interfaces:IDashboardRemoteObject" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.core:IChildList)" mod="1306872040405" size="1371" optimizedsize="497">
                          <def id="mx.core:IChildList" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.preloaders:SparkDownloadProgressBar)" mod="1306872047452" size="12760" optimizedsize="6814">
                          <def id="mx.preloaders:SparkDownloadProgressBar" />
                          <pre id="mx.preloaders:IPreloaderDisplay" />
                          <dep id="mx.graphics:RectangularDropShadow" />
                          <dep id="Math" />
                          <dep id="flash.display:Graphics" />
                          <dep id="flash.text:TextFormat" />
                          <dep id="AS3" />
                          <dep id="flash.geom:ColorTransform" />
                          <dep id="flash.text:TextFieldAutoSize" />
                          <dep id="flash.net:URLRequest" />
                          <dep id="flash.display:Loader" />
                          <dep id="Error" />
                          <dep id="flash.text:TextField" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.preloaders:IPreloaderDisplay)" mod="1306872047468" size="1996" optimizedsize="508">
                          <def id="mx.preloaders:IPreloaderDisplay" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="flash.display:Sprite" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.config:IAppConfig)" mod="1295458204000" size="1948" optimizedsize="418">
                          <def id="com.my.app.config:IAppConfig" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.vo:CustomerFile)" mod="1294750696000" size="754" optimizedsize="390">
                          <def id="com.my.app.vo:CustomerFile" />
                          <dep id="Date" />
                          <dep id="AS3" />
                          <dep id="flash.net:FileReference" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder 4/sdks/4.5.1/frameworks/libs/framework.swc(mx.managers:ISystemManagerChildManager)" mod="1306872045140" size="1092" optimizedsize="349">
                          <def id="mx.managers:ISystemManagerChildManager" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/cl/Documents/flex-workspace/my_mainapp/MYAppLogic/bin/MYAppLogic.swc(com.my.app.enum:NavigationViews)" mod="1295266614000" size="562" optimizedsize="286">
                          <def id="com.my.app.enum:NavigationViews" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                      </scripts>
                      <external-defs>
                        <ext id="mx.core:UIComponent" />
                        <ext id="spark.skins.spark:CheckBoxSkin" />
                        <ext id="mx.styles:CSSStyleDeclaration" />
                        <ext id="spark.skins.spark.mediaClasses.normal:VolumeBarSkin" />
                        <ext id="mx.skins.spark:SliderThumbSkin" />
                        <ext id="XMLList" />
                        <ext id="mx.skins.spark:DateChooserPrevMonthSkin" />
                        <ext id="AS3" />
                        <ext id="flash.events:IOErrorEvent" />
                        <ext id="spark.primitives:Rect" />
                        <ext id="spark.skins.spark:HSliderSkin" />
                        <ext id="String" />
                        <ext id="mx.modules:ModuleLoader" />
                        <ext id="mx.skins.spark:PopUpButtonSkin" />
                        <ext id="flash.net:SharedObject" />
                        <ext id="mx.styles:IStyleManager2" />
                        <ext id="mx.skins.spark:ComboBoxSkin" />
                        <ext id="mx.skins.halo:BrokenImageBorderSkin" />
                        <ext id="flash.geom:ColorTransform" />
                        <ext id="mx.skins.spark:MenuCheck" />
                        <ext id="flash.display:DisplayObject" />
                        <ext id="mx.messaging.messages:AcknowledgeMessageExt" />
                        <ext id="spark.skins.spark:NumericStepperSkin" />
                        <ext id="spark.components:TextInput" />
                        <ext id="mx.styles:CSSSelector" />
                        <ext id="mx.skins.halo:BusyCursor" />
                        <ext id="mx.skins.halo:DataGridHeaderSeparator" />
                        <ext id="mx.skins.spark:ScrollBarTrackSkin" />
                        <ext id="mx.skins.spark:ProgressIndeterminateSkin" />
                        <ext id="flash.display:StageScaleMode" />
                        <ext id="mx.core:UIComponentDescriptor" />
                        <ext id="mx.skins.spark:ProgressBarSkin" />
                        <ext id="mx.skins.spark:DateChooserTodayIndicatorSkin" />
                        <ext id="mx.charts.chartClasses:ChartLabel" />
                        <ext id="flash.filters:DropShadowFilter" />
                        <ext id="spark.skins.spark:VScrollBarSkin" />
                        <ext id="mx.rpc:IResponder" />
                        <ext id="flash.utils:setTimeout" />
                        <ext id="mx.skins.spark:TabSkin" />
                        <ext id="flash.display:InteractiveObject" />
                        <ext id="mx.binding:PropertyWatcher" />
                        <ext id="spark.skins.spark:ListSkin" />
                        <ext id="flash.events:IEventDispatcher" />
                        <ext id="mx.skins.spark:MenuItemSkin" />
                        <ext id="QName" />
                        <ext id="flash.utils:Dictionary" />
                        <ext id="spark.skins.spark:VideoPlayerSkin" />
                        <ext id="spark.skins.spark:TabBarSkin" />
                        <ext id="flash.external:ExternalInterface" />
                        <ext id="mx.utils:ObjectProxy" />
                        <ext id="mx.skins.spark:StepperDecrButtonSkin" />
                        <ext id="flash.events:SecurityErrorEvent" />
                        <ext id="spark.skins.spark:TextAreaSkin" />
                        <ext id="mx.skins.halo:PopUpMenuIcon" />
                        <ext id="mx.rpc:Responder" />
                        <ext id="flash.display:MovieClip" />
                        <ext id="mx.states:AddItems" />
                        <ext id="spark.skins.spark:VSliderSkin" />
                        <ext id="spark.skins.spark:SpinnerSkin" />
                        <ext id="flash.events:TimerEvent" />
                        <ext id="mx.messaging.messages:RemotingMessage" />
                        <ext id="flash.display:Stage" />
                        <ext id="spark.skins.spark:PanelSkin" />
                        <ext id="mx.core:TextFieldFactory" />
                        <ext id="spark.components.supportClasses:Skin" />
                        <ext id="mx.managers:IBrowserManager" />
                        <ext id="mx.collections:ArrayCollection" />
                        <ext id="mx.rpc:Fault" />
                        <ext id="mx.skins.halo:DataGridColumnResizeSkin" />
                        <ext id="spark.skins.spark:FormHeadingSkin" />
                        <ext id="XML" />
                        <ext id="mx.skins.spark:CheckBoxSkin" />
                        <ext id="mx.containers:HBox" />
                        <ext id="mx.messaging.channels:AMFChannel" />
                        <ext id="spark.skins.spark:RadioButtonSkin" />
                        <ext id="spark.skins.spark:HScrollBarSkin" />
                        <ext id="flash.net:URLLoaderDataFormat" />
                        <ext id="flash.events:ProgressEvent" />
                        <ext id="mx.skins.spark:MenuArrow" />
                        <ext id="mx.styles:CSSCondition" />
                        <ext id="mx.skins.spark:TextInputBorderSkin" />
                        <ext id="__AS3__.vec:Vector" />
                        <ext id="mx.skins.spark:DateChooserNextYearSkin" />
                        <ext id="flash.utils:Timer" />
                        <ext id="mx.skins.spark:ColorPickerSkin" />
                        <ext id="spark.skins.spark:ImageSkin" />
                        <ext id="mx.rpc:AsyncToken" />
                        <ext id="Math" />
                        <ext id="mx.events:BrowserChangeEvent" />
                        <ext id="mx.skins.spark:DataGridSortArrow" />
                        <ext id="spark.skins.spark:TitleWindowSkin" />
                        <ext id="mx.skins.spark:EditableComboBoxSkin" />
                        <ext id="flash.events:Event" />
                        <ext id="spark.skins.spark:DataGridSkin" />
                        <ext id="mx.skins.spark:MenuRadio" />
                        <ext id="spark.skins.spark:ButtonSkin" />
                        <ext id="flash.utils:describeType" />
                        <ext id="mx.skins.spark:BorderSkin" />
                        <ext id="flash.display:LoaderInfo" />
                        <ext id="spark.skins.spark:SkinnableDataContainerSkin" />
                        <ext id="ArgumentError" />
                        <ext id="mx.skins.spark:ProgressBarTrackSkin" />
                        <ext id="mx.graphics:SolidColor" />
                        <ext id="mx.skins.spark:DateChooserSelectionIndicatorSkin" />
                        <ext id="mx.skins.spark:StepperIncrButtonSkin" />
                        <ext id="Date" />
                        <ext id="mx.core:BitmapAsset" />
                        <ext id="spark.components.supportClasses:ListItemDragProxy" />
                        <ext id="mx.effects:EffectManager" />
                        <ext id="flash.display:StageQuality" />
                        <ext id="mx.skins.halo:DataGridColumnDropIndicator" />
                        <ext id="mx.skins.halo:DefaultDragImage" />
                        <ext id="mx.messaging.messages:AsyncMessageExt" />
                        <ext id="spark.components:Button" />
                        <ext id="flash.display:Loader" />
                        <ext id="flash.system:LoaderContext" />
                        <ext id="mx.managers:CursorManager" />
                        <ext id="mx.binding:FunctionReturnWatcher" />
                        <ext id="spark.skins.spark:ButtonBarSkin" />
                        <ext id="spark.skins.spark:ToggleButtonSkin" />
                        <ext id="flash.geom:Matrix" />
                        <ext id="flash.display:StageAlign" />
                        <ext id="flash.errors:IllegalOperationError" />
                        <ext id="mx.binding:BindingManager" />
                        <ext id="flash.text.engine:FontDescription" />
                        <ext id="spark.skins.spark.mediaClasses.normal:ScrubBarSkin" />
                        <ext id="mx.messaging.messages:CommandMessageExt" />
                        <ext id="flash.ui:Keyboard" />
                        <ext id="mx.skins.spark:SliderTrackSkin" />
                        <ext id="mx.states:State" />
                        <ext id="mx.skins.spark:MenuArrowDisabled" />
                        <ext id="spark.skins.spark:ComboBoxSkin" />
                        <ext id="mx.messaging.messages:CommandMessage" />
                        <ext id="spark.skins:SparkSkin" />
                        <ext id="spark.components:HGroup" />
                        <ext id="mx.skins.spark:DefaultButtonSkin" />
                        <ext id="Error" />
                        <ext id="spark.components:SkinnableContainer" />
                        <ext id="mx.skins.spark:ContainerBorderSkin" />
                        <ext id="spark.skins.spark:ErrorSkin" />
                        <ext id="spark.skins.spark:FocusSkin" />
                        <ext id="mx.skins.spark:PanelBorderSkin" />
                        <ext id="mx.skins.spark:ButtonBarFirstButtonSkin" />
                        <ext id="mx.binding:Binding" />
                        <ext id="flash.net:URLLoader" />
                        <ext id="spark.skins.spark.mediaClasses.normal:MuteButtonSkin" />
                        <ext id="mx.styles:StyleManagerImpl" />
                        <ext id="SecurityError" />
                        <ext id="mx.skins.spark:ButtonBarMiddleButtonSkin" />
                        <ext id="mx.messaging.messages:IMessage" />
                        <ext id="mx.skins.spark:ButtonBarLastButtonSkin" />
                        <ext id="flash.display:Graphics" />
                        <ext id="Number" />
                        <ext id="flash.geom:Point" />
                        <ext id="mx.skins.spark:AccordionHeaderSkin" />
                        <ext id="flash.events:MouseEvent" />
                        <ext id="mx.skins.spark:LinkButtonSkin" />
                        <ext id="flash.utils:getQualifiedClassName" />
                        <ext id="flash.utils:getDefinitionByName" />
                        <ext id="flash.text:TextFieldAutoSize" />
                        <ext id="flash.utils:getTimer" />
                        <ext id="mx.states:SetProperty" />
                        <ext id="mx.skins.halo:PopUpIcon" />
                        <ext id="flash.utils:ByteArray" />
                        <ext id="mx.skins.halo:LinkSeparator" />
                        <ext id="mx.skins.spark:DateChooserRollOverIndicatorSkin" />
                        <ext id="mx.skins.spark:DateChooserPrevYearSkin" />
                        <ext id="flash.text:FontStyle" />
                        <ext id="Class" />
                        <ext id="mx.managers:BrowserManager" />
                        <ext id="mx.skins.spark:DataGridHeaderBackgroundSkin" />
                        <ext id="mx.skins.spark:RadioButtonSkin" />
                        <ext id="flash.net:URLRequest" />
                        <ext id="flash.display:Shape" />
                        <ext id="mx.skins.spark:ProgressMaskSkin" />
                        <ext id="mx.skins.spark:ScrollBarDownButtonSkin" />
                        <ext id="spark.skins.spark:ListDropIndicator" />
                        <ext id="mx.rpc.remoting:RemoteObject" />
                        <ext id="flash.system:Capabilities" />
                        <ext id="spark.skins.spark:ScrollerSkin" />
                        <ext id="flash.events:EventDispatcher" />
                        <ext id="spark.skins.spark:SkinnablePopUpContainerSkin" />
                        <ext id="mx.skins.spark:MenuCheckDisabled" />
                        <ext id="flash.system:SecurityDomain" />
                        <ext id="flash.text:TextField" />
                        <ext id="spark.skins.spark:BorderContainerSkin" />
                        <ext id="mx.skins.spark:SliderTrackHighlightSkin" />
                        <ext id="mx.utils:ObjectUtil" />
                        <ext id="spark.skins.spark:SkinnableContainerSkin" />
                        <ext id="flash.text:Font" />
                        <ext id="flash.geom:Transform" />
                        <ext id="mx.binding:IBindingClient" />
                        <ext id="flash.system:Security" />
                        <ext id="flash.events:KeyboardEvent" />
                        <ext id="mx.skins.spark:ScrollBarThumbSkin" />
                        <ext id="RegExp" />
                        <ext id="flash.system:ApplicationDomain" />
                        <ext id="spark.skins.spark:TextInputSkin" />
                        <ext id="mx.messaging.messages:ErrorMessage" />
                        <ext id="spark.components:VGroup" />
                        <ext id="mx.rpc.events:FaultEvent" />
                        <ext id="mx.core:FontAsset" />
                        <ext id="mx.events:PropertyChangeEvent" />
                        <ext id="flash.events:FocusEvent" />
                        <ext id="spark.skins.spark:ApplicationSkin" />
                        <ext id="mx.graphics:LinearGradient" />
                        <ext id="spark.components:Label" />
                        <ext id="mx.core:UITextField" />
                        <ext id="flash.net:registerClassAlias" />
                        <ext id="flash.printing:PrintJobOptions" />
                        <ext id="mx.messaging:ChannelSet" />
                        <ext id="flash.accessibility:AccessibilityProperties" />
                        <ext id="mx.skins.halo:HaloFocusRect" />
                        <ext id="mx.graphics:SolidColorStroke" />
                        <ext id="mx.messaging.messages:AsyncMessage" />
                        <ext id="spark.components:RichEditableText" />
                        <ext id="mx.core:FlexGlobals" />
                        <ext id="flash.utils:Proxy" />
                        <ext id="mx.core:IStateClient2" />
                        <ext id="mx.collections:ArrayList" />
                        <ext id="mx.managers.systemClasses:ChildManager" />
                        <ext id="mx.core:DeferredInstanceFromFunction" />
                        <ext id="mx.skins.halo:HaloBorder" />
                        <ext id="flash.net:FileReference" />
                        <ext id="mx.graphics:GradientEntry" />
                        <ext id="spark.skins.spark:FormItemSkin" />
                        <ext id="spark.components:Application" />
                        <ext id="mx.messaging.messages:MessagePerformanceInfo" />
                        <ext id="spark.skins.spark:DropDownListSkin" />
                        <ext id="flash.ui:ContextMenuItem" />
                        <ext id="flash.printing:PrintJob" />
                        <ext id="mx.messaging.messages:AcknowledgeMessage" />
                        <ext id="flash.net:getClassByAlias" />
                        <ext id="flash.display:BitmapData" />
                        <ext id="mx.utils:UIDUtil" />
                        <ext id="flash.geom:Rectangle" />
                        <ext id="mx.skins.spark:MenuSeparatorSkin" />
                        <ext id="mx.skins.spark:MenuRadioDisabled" />
                        <ext id="flash.events:ErrorEvent" />
                        <ext id="mx.utils:URLUtil" />
                        <ext id="trace" />
                        <ext id="mx.skins.spark:ButtonSkin" />
                        <ext id="flash.display:IBitmapDrawable" />
                        <ext id="mx.skins.spark:ScrollBarUpButtonSkin" />
                        <ext id="mx.rpc.events:ResultEvent" />
                        <ext id="mx.skins.halo:ListDropIndicator" />
                        <ext id="Object" />
                        <ext id="mx.core:SpriteAsset" />
                        <ext id="flash.display:DisplayObjectContainer" />
                        <ext id="spark.components:Group" />
                        <ext id="mx.binding:IWatcherSetupUtil2" />
                        <ext id="spark.layouts:VerticalLayout" />
                        <ext id="flash.text:TextFormat" />
                        <ext id="flash.display:Sprite" />
                        <ext id="spark.skins.spark:DefaultButtonSkin" />
                        <ext id="mx.messaging.config:ConfigMap" />
                        <ext id="mx.skins.spark:DataGridHeaderSeparatorSkin" />
                        <ext id="spark.skins.spark:FormSkin" />
                        <ext id="mx.skins.spark:DateChooserNextMonthSkin" />
                        <ext id="flash.printing:PrintJobOrientation" />
                        <ext id="mx.skins.halo:ToolTipBorder" />
                      </external-defs>
                    </report>
                    • 8. Re: Flex 4.1 to 4.5.1 "Could not find compiled resource bundle 'controls' for locale 'en_US'."
                      Dan Thomas Level 1
                      So this is now fixed by setting the framework linkage in Flash Builder to "merged into code" rather than "use sdk default".
                      However our ant script still does not apply whatever change this makes, is there an equivillent mxmlc argument we can use to achieve this? Also could someone please point to the relevant documentation that explains the behaviour of this so we can try to understand why changing this works?
