2 Replies Latest reply on Jun 23, 2011 6:42 AM by UbuntuPenguin
    Itemeditor with combobox throws TypeError
    RonaldKamp Level 1
      I'm a junior developer at Ordina Belgium. I'm currently working on a project in flex. I need to have a datagrid, where the values are shown as strings. When the user selects a certain row, the row changes and shows some comboboxes. when the user selects a certain value in the combobox, the value is saved correctly, but when I try to exit the itemeditor, the following error is thrown:
      TypeError: Error #1034: Type Coercion failed: cannot convert "Classic Line" to com.bgc.dto.Product.
      Here is my code:
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%" creationComplete="init()"
         xmlns:view="com.bgc.view.*" >
           <mx:Script>
                     <![CDATA[
                             private var presenter:OrderActionListsPresenter;
      [Bindable]
      private var categoriesNames:ArrayCollection;
      [Bindable]
      private var packStructures:ArrayCollection = new ArrayCollection();
      [Bindable]
      public static var actions:ArrayCollection = new ArrayCollection();
      [Bindable]
      public var productsPerCategory:ArrayCollection;
      [Bindable]
      public static var selectedProducts:ArrayCollection = new ArrayCollection();
      [Bindable]
      public var orderActionsPerMapping:ArrayCollection;
      private function init():void{
      this.presenter = new OrderActionListsPresenter(this);
      presenter.getStartupData();
      packStructures.addItem("DP");
      packStructures.addItem("E2E");
      this.orderActionsPerMapping = new ArrayCollection();
      var orderActionEmpty:OrderAction = new OrderAction();
      orderActionsPerMapping.addItem(orderActionEmpty);
      public function checkOrderAction(data:*):void{
      var order:OrderAction = data as OrderAction;
      if(order.action != null && order.affectedProduct != null){
      var newOrderAction:OrderAction = new OrderAction();
      orderActionsPerMapping.addItem(newOrderAction);
      protected function cboProductCat_changeHandler(event:ListEvent):void
      var selectedItem:String = (event.target as ComboBox).selectedItem as String;
      if(selectedItem != "<Click to select category>"){
      presenter.getProductsForCategory(selectedItem);
      protected function cboProduct_changeHandler(event:ListEvent):void
      OrderActionListManager.selectedProducts.removeAll();
      var fromProd:Product = cboFromProduct.selectedItem as Product;
      var toProd:Product = cboToProduct.selectedItem as Product;
      if(fromProd != null &&  fromProd.prodName != "None") OrderActionListManager.selectedProducts.addItem(fromProd);
      if(toProd != null && toProd.prodName != "None") OrderActionListManager.selectedProducts.addItem(toProd);
      (OrderActionListManager.selectedProducts.length == 2) ? grdMappings.enabled = true : grdMappings.enabled = false;
      public function getProductLabel(item:Object,column:DataGridColumn):String
      if((item as OrderAction).affectedProduct != null){
      return (item[column.dataField] as Product).prodName;
      return "";
                </mx:Script>
      <mx:DataGrid id="grdMappings" width="500" editable="true" dataProvider="{orderActionsPerMapping}" enabled="false" >
           <mx:columns>
                <mx:DataGridColumn id="clmOrderAction" width="250" headerText="Action" dataField="action">
                     <mx:itemEditor>
                          <mx:Component>
                               <mx:ComboBox dataProvider="{OrderActionListManager.actions}" change="cboActions_changeHandler(event)">
                                    <mx:Script>
                                         <![CDATA[
                                              import com.bgc.dto.OrderAction;
                                              import mx.events.ListEvent;
                                              protected function cboActions_changeHandler(event:ListEvent):void
      order.action = (event.target as ComboBox).selectedItem as String;
      outerDocument.checkOrderAction(order);
                                    </mx:Script>
                               </mx:ComboBox>
                          </mx:Component>
                     </mx:itemEditor>
      </mx:DataGridColumn>
      <mx:DataGridColumn id="clmAffectedProduct" width="250" headerText="Affected product" dataField="affectedProduct" labelFunction="getProductLabel">
           <mx:itemEditor>
                <mx:Component>
                     <mx:ComboBox dataProvider="{OrderActionListManager.selectedProducts}" change="cboProduct_changeHandler(event)" labelField="prodName">
                          <mx:Script>
                               <![CDATA[
      import com.bgc.dto.Product;
      order.affectedProduct = (event.target as ComboBox).selectedItem as Product;
           </mx:Script>
              </mx:ComboBox>
                </mx:Component>
           </mx:itemEditor>
      Does anyone know how to fix this?
      Thanks in advance for your answers .
      Kind regards,
      Ronald Kamp,
      Junior Java developer at Ordina Belgium
        • 1. Re: Itemeditor with combobox throws TypeError
          UbuntuPenguin Level 4
          That means that somewhere you are trying to stuff "Classic Line" into a variable or function that is declared to be a product.  Is "Classic Line" the string you put into the text editor when it choked ?
          • 2. Re: Itemeditor with combobox throws TypeError
            RonaldKamp Level 1
            Classic Line is the one that I selected in the drop down list. Somehow, I think that it doesn't interpret the itemeditor the way it is supposed to.
            I removed the item editor with the combobox. This way, it would show my product name. when I click this, it shows a text editor and when I try to exit this one, it throws the same error. So somehow, I think it opens an item editor twice, one with a combobox and one with the text editor.
            If you know a way to prevent this, please let me know.
            Kind regards ,
            Ronald Kamp
