4 Replies Latest reply on Jun 23, 2011 12:00 PM by mactosh3
    Video won`t fit window
    mactosh3
      Hi, newbie here.
      I am editing some footage shot on HDV cam, captured onto my MBP. Capture settings i chose as seen in the picture capturesettings. My problem is that the video turns out as a small square in the center, both when editing and exported to .mov and .flv (se second pic)
      CAn anyone please give me a hint on where I shold look to fix this. I want the video of course to fill the entire window.
      Thanks for any help
        • 1. Re: Video won`t fit window
          You captured your footage as DV and not as HDV.
          Change your settings to HDV.
          Can you give the properties of a captured clip?
          • 2. Re: Video won`t fit window
            mactosh3 Level 1
            Hi
            I tried to capture it as HDV but didnt get that to work. As I capture it says DVout on my camera.
            Here are the properties of the captured clip
            File Path: /Brukere/Terje/Dokumenter/AddictologiAkademiet/Video/WebClipAddictologiAkademiet/WebClip. mov
            Type: QuickTime Movie
            File Size: 2,7 GB
            Image Size: 720 x 576
            Pixel Depth: 24
            Frame Rate: 25,00
            Source Audio Format: 48000 Hz - 16 bit - Stereo
            Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
            Total Duration: 00:12:35:09
            Average Data Rate: 3,6 MB / second
            Pixel Aspect Ratio: 1,4587
            QuickTime Details:
            Movie contains 1 video track(s), 1 audio track(s) and 1 timecode track(s).
            Video:
            There are 18886 frames with a duration of 1/25th.
            Video track 1:
            Duration is 0:12:35:09
            Average frame rate is 25,01 fps
            Video track 1 contains 1 type(s) of video data:
            Video data block #1:
            Frame Size = 720 x 576
            Compressor = DV - PAL (16:9)
            Quality = Normal (3,00)
            Temporal = Normal (3,00)
            Audio:
            Audio track 1 contains 1 type(s) of audio data:
            Audio data block #1:
            Format = 16 bit - Stereo
            Rate = 48000 Hz
            Compressor =  16-bit Little Endian
            Timecode:
            Timecode track 1 contains 1 type(s) of data:
            Timecode data block #1:
            Start Time = 00;40;51;16
            Reel name = ExtraDag
            • 3. Re: Video won`t fit window
              Yes its DV so you will need a DV pal widescreen preset to get the video to fit.
              When capturing HDV make sure the camera is set to HDV and not to DV or Downconverting.
              Might want to read this document.
              http://kb2.adobe.com/cps/828/cpsid_82848.html
              • 4. Re: Video won`t fit window
                mactosh3 Level 1
                Thanks for your help Ann.
                Ill stick to setting the right dv widescreen settings.
                Great help.
                Terjemk
