1. Re: Photoshop Error: End-of-File
John T Smith Jun 23, 2011 9:03 AM (in response to TimothyWhalin)>All the settings are still the original
Which, of course, means that all the device drivers are as of the date the setup image was made at the factory... which is usually 2-to-6 months old, depending on when the vendor last did an update to their process
So... go to the direct site for each hardware component and check for newer device drivers... especially the graphics adapter (usually ATI or nVidia)
If you still think this is a CS5.5 problem, make a report
Bug Report and Feature Request https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
2. Re: Photoshop Error: End-of-File
TimothyWhalin Jun 23, 2011 9:09 AM (in response to John T Smith)Thank you for the recommendation, John.
I guess what I'm wondering is why I got this error in this first place? When I saved the file in Photoshop, it obviously corrupted the file and can no longer read it. So this seems like a software issue, not a problem with the drivers on my computer. I've been using Photoshop for 11 years and haven't come across this problem. And the file I was working on was only 7mb compared to the 4gb+ files I've worked on before.
3. Re: Photoshop Error: End-of-File
Bill Hunt Jun 23, 2011 10:52 AM (in response to TimothyWhalin)Timothy,
Was this file Saved from PS 7, or CS5? Did it fail to Open in PS 7, or CS5?
Is this a PSD file, or some other format?
Also, are you working with any external, or networked HDD's?
Last, are you experiencing any other corruption on your system? I wonder if you are developing I/O issues.
One thing that will often get things back on track is to Open the file in another program, like the free IrfanView, do a Save, and then things are often fixed. Usually, one gets more problems with file header data, and "End of File," leads me to ask the questions above.
4. Re: Photoshop Error: End-of-File
TimothyWhalin Jun 23, 2011 10:58 AM (in response to Bill Hunt)Hi Bill,
I created, saved, and was trying to open it using CS5. Its a PSD file. It was saved on a networked server. Is that to be of a concern?
No other problems with the system.
I'll see if I can open it using that other program, though I've already redone the entire file from yesterday, so not sure there's any point. More of just a concern for the future.
5. Re: Photoshop Error: End-of-File
Bill Hunt Jun 23, 2011 11:09 AM (in response to TimothyWhalin)I would test that network server, just to make sure that it's connection (and possibly the HDD's format, though it should be NTSF) is adequate, and that no network processes could lead to truncation of the file.
How large is the file?
Though I use an NAS for archival storage, find that working internally, than remotely, causes zero issues.
Good luck, and thanks for the info,
6. Re: Photoshop Error: End-of-File
Jeff Schewe Jun 23, 2011 1:00 PM (in response to TimothyWhalin)TimothyWhalin wrote:
Yes, Adobe doesn't support saving over a network because there as so many potential problems. It's suggested to always save on the local hard drive and then do a Finder copy to the network storage. Same thing for opening, copy it locally and then open.
There's just way to many potential problems with networks (which you've found out).
7. Re: Photoshop Error: End-of-File
TLL... Jun 23, 2011 1:47 PM (in response to Jeff Schewe)I dunno, we regularly batch run 100s of images off the network and save back to it. With large volumes of huge files its become nessisary with TBs of geospatial stuff. Never had a problem with it for years. But - just a couple weeks ago I trashed a 1G + psd in PS CS5.5 during a local save. Another first in a long, long time. I think I might have shut PS down too soon? Pixel trolls? I'd look @ the usual suspects (prefs, scratch disk, saving local I suppose).
Oh, and if you any of your blog posters have better professional image editing 'app' I love to hear about it...
8. Re: Photoshop Error: End-of-File
lizzieartist Jun 24, 2011 10:36 AM (in response to TimothyWhalin)POSSIBLE SOLUTION
I just ran into this same error with Photoshop and Bridge when I tried to open pictures that have been on my computer for months and have previously opened with no problem. I could view the pictures in Windows Photo Gallery, but couldn't edit the camera raw files. I found a simple solution (at least as far as getting the pictures to read again), so see if it works for you:
If you have MS Paint or some other picture editing program, see if you can open the pictures in those. Then check if the program wil save in the .TIFF or .TIF format, and if it does, save it, but be sure not to save over the old file just in case someting goes wrong or you find a better solution. Now, hopefully, you should be able to open and edit it as before. I was even able to edit the photo in Camera Raw, even though I'm pretty sure .TIFF is not a raw format. But it is a lossless format, so I guess it kept all the data or something.
Hope this helps!
9. Re: Photoshop Error: End-of-File
Chris Cox Jun 24, 2011 10:44 AM (in response to lizzieartist)Sometimes opening the file in another application will work - because the other application may ignore parts of the file that Photoshop was trying to read (and encountered the error in).
But it won't always work -- results depend on where the file is corrupt.
The underlying problem is still that the files are corrupted in some way. And that means that you have disk or network problems.
10. Re: Photoshop Error: End-of-File
TimothyWhalin Jun 24, 2011 10:46 AM (in response to lizzieartist)RE: Possible Solution
I need to open the PSD which I don't think will open in MS Paint, and if it did, it would remove all the layers which are critical to the PSD. Thanks for the idea, though! I appreciate it.
11. Re: Photoshop Error: End-of-File
TimothyWhalin Jun 24, 2011 10:48 AM (in response to Chris Cox)Thanks Chris. Nice to receive a reply from an Adobe employee.
So the issue is with my HD or network? What can I have the IT people check on for the network?
12. Re: Photoshop Error: End-of-File
Bill Hunt Jun 24, 2011 10:49 AM (in response to TimothyWhalin)For such a test, I would look at the free IrfanView. Now, it has been awhile, since I used it, but believe that all newer versions handle Layered PSD files, without messing up, or Flattenning the Layers. If the file does Open, just do a Save_As (I would not overwrite your original file, just in case - remember, we are testing here).
13. Re: Photoshop Error: End-of-File
Chris Cox Jun 24, 2011 2:08 PM (in response to TimothyWhalin)Unfortunately with network issues: it could be just about anything.
A disk problem on the server, bad RAM on the server, a bug in the server software, a bug in the client driver talking to the server, etc.
First check the file and make sure it doesn't just have the wrong extension on it (user error).
If it really is a PSD and can't be read - then the file was corrupted somehow, and you should try to track down the cause and get it fixed.
In the meantime, trying other applications that can read PSD might let you recover some of the layer data.
You might want to try the PSD parse/recovery tool at http://telegraphics.com.au/sw/ .
14. Re: Photoshop Error: End-of-File
TimothyWhalin Jun 24, 2011 2:36 PM (in response to Chris Cox)Great, thanks for your help, Chris! I appreciate it.
15. Re: Photoshop Error: End-of-File
Bill Hunt Jun 24, 2011 3:52 PM (in response to Chris Cox)Chris,
Thank you. That utility is a new one to me. Fortunately, I have never needed to "fix" a PSD, but one never knows.
Appreciated,
