1. Re: Crop Straighten and then Save
MTSTUNER Jun 23, 2011 1:23 PM (in response to bonalymac999)You could probably record a save as step at the end of your action or look at
the Image Processor under File>Scripts>Image Processor.
MTSTUNER
2. Re: Crop Straighten and then Save
Paul Riggott Jun 23, 2011 3:04 PM (in response to bonalymac999)This may be of use...
3. Re: Crop Straighten and then Save
bonalymac999 Jun 24, 2011 12:58 AM (in response to Paul Riggott)I'm going to need to read a bit about this.
I've read that post, and it seems as if theres a guy with exactly the same issue.
I've never actually written a script before, so I'll need to read the manuals/books this weekend and give it and the image processor a try, to see if either suggestion will work in practice.
I've created some test files, and I'll give it a try.
I'll report progress in a few days.
Thanks so far.
Colin
4. Re: Crop Straighten and then Save
bonalymac999 Jun 24, 2011 1:40 PM (in response to bonalymac999)Paul that script was EXACTLY what I wanted . It di what I needed perfectly.
I even managed to tweak it a bit to give the renaming a format that was preferrable to me.
As a result, I never even neede to look at the other suggestion.
Thanks both of you very much for your help.
Now it looks as if I made a mistake as earlier I marked both answers helpful, it now seesm I cannot change this to "Answer". Is that correct?
