3 Replies Latest reply on Jun 29, 2011 1:48 AM by teho59
    "Warning": Noctua NH-C14 and Asus P8Z68 Deluxe
    teho59 Level 1
      A little warning. The cooler is so big that you cant use both fans on it with the memory mentioned below in all slots. You must remove the lower fan and cant get full effect of the cooler. Idle I am still at 36C so it is good. Have not stresset it yet, have to install my programs first.
      If the memory had been lower it might have worked out or my not using all memory slots. I use all therefore it became to tight.
      - Terje
      -- Memory
          Corsair Vengeance™ DDR3 1600MHz 16GB CL9
          Kit w/4x 4GB XMS3 modules, CL9-9-9-24, 1.5V, Vengeance Heatspreader, 240 pin
      -- Mainboard
          ASUS P8Z68 Deluxe, Socket-1155
          ATX, Z68, DDR3, 3xPCIe(2.0)x16, CFX&SLI, SATA 6Gb/s, FW, USB3.0, BT, EFI
      -- CPU-cooler
          Noctua NH-C14 CPU Cooler
          Socket 775/1155/1156/1366, AM2/AM2+/AM3, 1200 RPM, 110,3 m³/h, 19,6 dBA
      -- CPU is i7-2600k
