7 Replies Latest reply on Jun 25, 2011 6:39 AM by kglad
    fpdf
    Ron Colmen Level 2
      I'm trying to generate a pdf using fpdf. What are the possibilities that might be avoiding generating this PDF. The swf and the php works fine I tested it in another server. Is there any areas that I need to do any adjustments in my server? Any help is highly appriciated.
        • 1. Re: fpdf
          i've used fpdf to generate a pdf using images and text from flash without problem.
          are you able to hardcode data (like simple text) and save a pdf using fpdf?  if not, show the php code you tried.
          • 2. Re: fpdf
            Ron Colmen Level 2
            require('fpdf.php');
            $imageA = explode(",,",$proItemS);
            if($imageA[0]!="") {
                $pdf=new FPDF("P","mm","A4");
                $pdf->AliasNbPages();
                $pdf->SetFont('Helvetica','',9);
                $pdf->SetMargins(0,0,0);
                for($i=0;$i<count($imageA);$i++){
                    $pdf->AddPage();
                    $widthHeightA = $pdf->Image($imageA[$i]."_top.jpg",0,0);
                    $pdf->Image($imageA[$i]."_bottom.jpg",0,$widthHeightA[1]);
                $pdfdoc = $pdf->Output("", "S");
            $to = "me@web.com";
            $sender = "Dtext";
            $subject = "TryX";
            $headers .= "Cc: $new\r\n";
            $message = "<HTML>
            //dContent
            \</HTML>";
            $eol = PHP_EOL;
            $separator = md5(time());
                $filename = "d_Form.pdf";
                $attachment = chunk_split(base64_encode($pdfdoc));
            $headers  = "From: ".$sender.$eol;
            $headers .= "MIME-Version: 1.0".$eol;
            $headers .= "Content-Type: multipart/mixed; boundary=\"".$separator."\"".$eol.$eol;
            $headers .= "Content-Transfer-Encoding: 7bit".$eol;
            $headers .= "This is a MIME encoded message.".$eol.$eol;
            $headers .= "--".$separator.$eol;
            $headers .= "Content-Type: text/html; charset=\"iso-8859-1\"".$eol;
            $headers .= "Content-Transfer-Encoding: 8bit".$eol.$eol;
            $headers .= $message.$eol.$eol;
                $headers .= "Content-Type: application/octet-stream; name=\"".$filename."\"".$eol;
                $headers .= "Content-Transfer-Encoding: base64".$eol;
                $headers .= "Content-Disposition: attachment".$eol.$eol;
                $headers .= $attachment.$eol.$eol;
                $headers .= "--".$separator."--";
            mail("me@web.com", $subject, "", $headers);
            echo 'Successful!';
            • 3. Re: fpdf
              the first problem i see is $proItemS is undefined.
              • 4. Re: fpdf
                Ron Colmen Level 2
                Oo
                Thanks Kglad!!
                • 5. Re: fpdf
                  you're welcome.
                  was that all that you needed to fix?
                  • 6. Re: fpdf
                    Ron Colmen Level 2
                    I thought that was it... but it seems that's not the only issue. I still can not get this to work.
                    • 7. Re: fpdf
                      copy and paste your corrected code.
