6 Replies Latest reply on Jun 27, 2011 8:07 AM by Flex harUI
    problem with transform.matrix
    alias19
      hello everyone,
      my problem is that i have created a custom shape class which inherit UIComponent. now if i transform the shape object i am unable to get the new width and height value.
      e.g:
      var shape:Shape = new Shape();
      shape.type = Shape.TRIANGLE.
      shape.width = 100;
      shape.height = 100;
      var mat:Matrix = new Matrix();
      mat.scale(1.5, 1.5);
      shape.transform.matrix = mat;
      trace("scaleX: "+shape.scaleX+", width: "+shape.width+"\nscaleY:"+shape.scaleY+", height: "+shape.height);
      ///// scale value tracing 1 instead of 1.5, and 100 instead of 150 for height and width.
      the problem also persists if i use canvas instead of shape. it will be realy helpfull if someone will point me out what i am doing wrong
      thanx.
        • 1. Re: problem with transform.matrix
          alias19 Level 1
          on basis of above problem i have written a basic app in flex in which i have used a Sprite and a UIComponent, Sprite is working well but UIComponent is having a problem.
          code:
          <mx:Application xmlns:mx="
          http://www.adobe.com/2006/mxml" layout="absolute" minWidth="955" minHeight="600"
              creationComplete="init()">
          <mx:Script>
            <![CDATA[
             import mx.core.UIComponent;
             private var spt:UIComponent;
             private var spt2:Sprite;
             private function init():void{
              spt = new UIComponent();
              with(spt.graphics){
               beginFill(0xffffff);
               drawRect(0, 0, 100, 100);
              addChild(spt);
              spt2 = new Sprite();
              with(spt2.graphics){
              rawChildren.addChild(spt2);
              spt2.x = 500;
             private function onChange():void{
              mat.scale(scale.value, scale.value);
              spt.transform.matrix = mat;
              debug.text = "scaleX: "+spt.scaleX+", width: "+spt.width+"\nscaleY: "+spt.scaleY+", height: "+spt.height;
              var mat2:Matrix = new Matrix();
              mat2.tx = 500;
              mat2.scale(scale.value, scale.value);
              spt2.transform.matrix = mat2;
              debug.text = debug.text+"\nscaleX: "+spt2.scaleX+", width: "+spt2.width+"\nscaleY: "+spt2.scaleY+", height: "+spt2.height;
          </mx:Script>
          <!--<mx:Canvas width="100" height="100" x="10" y="10" backgroundColor="#FFFFFF"
                id="can"/>-->
          <mx:Text x="10" y="502" id="debug"/>
          <mx:HSlider x="411" y="508" minimum="0.2" maximum="4" snapInterval="0.1" liveDragging="true"
              change="onChange()" id="scale"/>
          </mx:Application>
          pls help me
          • 2. Re: problem with transform.matrix
            Flex harUI Adobe Employee
            In Flex 3, UIComponent doesn't support rotation.
            • 3. Re: problem with transform.matrix
              alias19 Level 1
              the rotation is working well. it is scale which is not working, Actually scale is also working it is the value which is not updating.
              • 4. Re: problem with transform.matrix
                PresidentCamacho Level 1
                Instead of:
                Try:
                var mat : Matrix = shape.transform.matrix.clone();
                Setting the width/height of the original sprite may have changed the transform matrix itself.
                • 5. Re: problem with transform.matrix
                  alias19 Level 1
                  I have also tried it, not working.
                  but can anyone tell will the width and height of a sprite changes if the sprite is rotated using transform.matrix?
                  i have found the way to get width and height of UIComponent when transform by its transform.matrix by using its mx_internal properties
                  e.g:
                  var wd:Number = shape.mx_internal::$width;
                  var ht:Number = shape.mx_internal::$height;
                  but the width and height changes as it rotate. same for sprite also.
                  so, can i get the real width & height instead of it's bounding width and height?
                  • 6. Re: problem with transform.matrix
                    What I meant by not supporting rotation is that the properties won't report
                    what you expect and layout won't honor rotated things.  Things will appear
                    rotated.
                    If you rotate a 100x100 UIComponent by 45 degrees, it's x and y should
                    change, but it is width and height will show 100x100.  Transform.pixelBounds
                    should show its true bounding box though.
