0 Replies Latest reply on Jun 24, 2011 7:23 AM by Serih
    WebService with wizard & adding a SOAPheader to the message:Help
    Serih
      I have used data services for connecting to a web service, which auto-populated the service and value objects.
      Needing to use a SOAP header within the SOAP message to authenticate - I don't know how to do this.
      Using Flash Builder 4.5, and the wizard populating the code - it appears to append the SOAP message to the operations of the web service
      in :AsyncToken
      Where to I tell the SOAP message to include the SOAP header?
      The examples I found on the forums state to define as follows - however when I do this in the main application mxml code -
      it doesn't find the addHeader() method, since the web service in not defined in the main application mxml.
      So HOW & WHERE I add a defined SOAP header?
      import valueobject.LoginRequest;
      private var header1.SOAPHeader;
      private var header2:SOAPHeader
      public function headers(): void
      //Create QName & SOAP header Objects:
      var qname:QName=new QName(http://blah blah, header1);
      header1=new SOAPHeader(qname, {string:servicereturnedsessionID});
      //header2=new SOAPHeader(qname, {string:servicereturnedsessionID});
      //Add header1 (SOAP Header) to all the web service request method definition should include the mx.rpx.SOAPHeader and/or mx.rpc.WebService
      webservice.addHeader(header1);
      //Where in the auto-populated code for the service connection should this code, doesn't find the addHeader(header1) as the service is defined in a superclass
      //and it doesn't work in the preInitialization() of the subclass
      //Add header2 (SOAP header) to the web service operation
      services.webservice:operations:addHeader(header2);
      Any suggestions/ideas/thoughts?  Been working on for 3 days! and now have tunnel vision ;(
      Thank you,
      Serih
