1 Reply Latest reply on Nov 6, 2006 6:17 PM by Newsgroup_User
    problem bei transition
    Level 7
      We have a problem with transition effects
      When some transition is started , the screen begins to rapaint and in this
      moment I change to another application through ALT-TAB the transition loops
      unendlessly and the look of director-Application window is very "unclean"
      (buggy repaint). When I change again to Director app, its window repaints
      correctly and everything works fine. How can I avoid this situation?
      Thanx in advance
        • 1. Re: problem bei transition
          Level 7
          Have you disabled the animate in background projector option?
          If you have to run in background some lingo script, perhaps calling a
          function in the free version of buddyAPI xtra can determine when the
          projector is in background, jumping to a non transition frame to avoid
          the artifact.
          You can determine of the current frame has a transition ( the
          frameTransition?) perhaps jumping to the following frame if at a
