4 Replies Latest reply on Jun 25, 2011 6:53 AM by RBC
    Data Binding vs. Square Bracket Operator
    RBC
      I am new to flex and I am getting the dreaded message "Description Resource Path Location Type
      Data binding will not be able to detect changes when using square bracket operator.  For Array, please use ArrayCollection.getItemAt() instead.."  I would take this advice if I only knew how.  I tried...
      Here is the offending textArea code:
      <s:TextArea id="client_last_name" x="105" y="30" width="205" height="28"
      text="@{getThisCustomerResult.lastResult[0].client_last_name}"/>0
      And this is the function from which I drawing the data down:
      protected function getThisCustomer(itemID:Number):void
      getThisCustomerResult.token = getToolBeltData.getThisCustomer(itemID);
      If its important, the data is being pulled via ColdFusion CFC  using data/services from Flash Builder.
      Thank you.
        • 1. Re: Data Binding vs. Square Bracket Operator
          Flex harUI Adobe Employee
          Assuming lastResult is an ArrayCollection, it would be:
          text="@{ArrayCollect(getThisCustomerResult.lastResult).getItemAt(0).client_l
          ast_name}"
          • 2. Re: Data Binding vs. Square Bracket Operator
            RBC Level 1
            Thank you for the help...unfortunately, I get this error:
            1180: Call to a possibly undefined method ArrayCollect
            So I guess it isn't an array collection, but judging by the original error message about the square brackets, it seems like Flex wants it to be.  Is there something I do to convert it to an array collection?  Sorry if I am dense...
            • 3. Re: Data Binding vs. Square Bracket Operator
              You probably just have to
                  import mx.collections.ArrayCollection;
              In a script block.  You'll get a runtime error if the result isn't an
              ArrayCollection
              • 4. Re: Data Binding vs. Square Bracket Operator
                RBC Level 1
                Thanks a million for the help.  That was the issue.
                I want to note for someone reading this in the future that there was a slight typo (I think that's the problem) in the initial helpful answer--Instead of
                text="@{ArrayCollect(getThisCustomerResult.lastResult).getItemAt(0).cl ient_l
                ast_name}"
                I think you have to write out ArrayCollect so that it is ArrayCollection or it won't work and you'll get an error.    So it should be:
                text="@{ArrayCollection(getThisCustomerResult.lastResult).getItemAt(0).cl ient_l
                ast_name}"
                Once again, sincere thanks for helping me.
