1 Reply Latest reply on Aug 4, 2006 2:52 AM by Newsgroup_User
    Can't get code to work!
    discodotti
      Hi guys
      i just can't figure out why this bit of code I kindly given yesterday won't work, maybe I'm doing something very stoopid
      the swf that I am trying to load in (press.swf) is still coming in right at the top of my main home movie, the x and y co ordinates (100 and 200) don't seem to be applied. Also, does anyone know what the 100 value is for on the code that is attcached to the button?
      Thanks everyone :-)
      // Code on button:
      on (release) {
      unloadMovieNum(1);
      loadMovieNum("Press.swf", 2);
      _parent.preloadI=setInterval(_parent.preloadF,100);
      // the below should be attached to a frame that contains the above button
      function preloadF(){
      bl=_level2.getBytesLoaded();
      bt=_level2.getBytesTotal();
      if(bl>0&&bl>=bt){
      clearInterval(preloadI);
      _level2._x=100;
      _level2._y=200;
        • 1. Re: Can't get code to work!
          Level 7
          It may be a scoping issue. You are using _parent to assign the interval, but
          assuming your release handler is on a button instance that may not be right.
          Put a simple trace into the preloadF function to make sure it is being
          called by the interval:
          trace ("!! interval called !!");
          if(bl>0&&bl>=bt){
          _level2._x=100;
          _level2._y=200;
          If you see no trace, then change your handler to :
          on (release) {
          unloadMovieNum(1);
          preloadI=setInterval(preloadF,100);
          The 100 value here is the time in milliseconds between the interval being
          called - i.e. every tenth of a second in this case.
          Remove '_spamkiller_' to mail
