0 Replies Latest reply on Jun 26, 2011 10:35 AM by a_flex_user
    Error:Unable to open src/test.mxml
    a_flex_user
      Hello,
      I want to excute the mxmlc task from build.xml using subant.  What I found is that when I excute the task from the folder in which the build.xml is found(and which contains the mxmlc task), then it works fine. But when I try to use subant from build.xml in other folder, it says Error: unable to open src/test.mxml for example. The folder paths are as follows:
      projects/proj1
      projects/proj2
      proj1/build.xml   (contains mxmlc task. When run from here it compiles.)
      proj1/src/test.mxml
      proj2/build.xml(when run from here using subant, give the error mentioned).
      Thanks.
