1. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
robsheely2 Jul 10, 2011 1:04 PM (in response to Paul_Kuhn)I found the following info on a site (translated from Korean). I haven't tried it yet, but I'm planning to.
If you install Flash Builder Plugin 4.5.1 on Eclipse Indigo, it rolls back your bundles to prior versions. Naturally, you will experience clashes. For example Eclipse Marketplace Client. To prevent this, you have to do the following:
1. Run Eclipse Indigo once and exit.2. Backup bundle info file to a safe place.%ECLIPSE_HOME%\configuration\org.eclipse.equinox.simpleconfigurator\bundles.info
3. Install Flash Builder Plugin by running the Adobe Flash Builder 4.5 Plug-in Utility.4. When it's done, restore the original bundle info file from step 2your backup => %ECLIPSE_HOME%\configuration\org.eclipse.equinox.simpleconfigurator\bundles.info5. Open the bundle info file in a text editor.%ECLIPSE_HOME%\configuration\org.eclipse.equinox.simpleconfigurator\bundles.info6. Add the following to the end of the bundle info file (replacing all incidences of C:/dev/Adobe%20Flash%20Builder%204.5 with the correct path to your Flash Builder install, if necessary):
com.adobe.flash.codemodel.core,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flash.codemodel.core_4.5.1.313231/,4,false com.adobe.flash.codemodel.osgi,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flash.codemodel.osgi_4.5.1.313231/,4,false com.adobe.flash.profiler,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flash.profiler_4.5.1.313231/,4,false com.adobe.flash.profiler.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flash.profiler.nl1_4.5.1.313231/,4,false com.adobe.flashbuilder.launching.multiplatform.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.launching.multiplatform.ui_4.5.1.313231/,4,false com.adobe.flashbuilder.launching.multiplatform.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.launching.multiplatform.ui.nl1_4.5.1.313231/,4,false com.adobe.flashbuilder.multiplatform.android.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.multiplatform.android.ui_4.5.1.313231/,4,false com.adobe.flashbuilder.multiplatform.android.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.multiplatform.android.ui.nl1_4.5.1.313231/,4,false com.adobe.flashbuilder.multiplatform.ios.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.multiplatform.ios.ui_4.5.1.313231/,4,false com.adobe.flashbuilder.multiplatform.ios.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.multiplatform.ios.ui.nl1_4.5.1.313231/,4,false com.adobe.flashbuilder.project.multiplatform.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.project.multiplatform.ui_4.5.1.313231/,4,false com.adobe.flashbuilder.project.multiplatform.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flashbuilder.project.multiplatform.ui.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.DCDService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.DCDService_4.5.1.313231/,4,false com.adobe.flexbuilder.DCDService.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.DCDService.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.ajaxbridge,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.ajaxbridge_4.5.1.313231/,4,false com.adobe.flexbuilder.ajaxbridge.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.ajaxbridge.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.as.editor,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.as.editor_4.5.1.313231/,4,false com.adobe.flexbuilder.as.editor.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.as.editor.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.axis2,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.axis2_4.5.1.313231/,4,false com.adobe.flexbuilder.axis2.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.axis2.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.codemodel,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.codemodel_4.5.1.313231/,4,false com.adobe.flexbuilder.codemodel.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.codemodel.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.crimson,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.crimson_4.5.1.313231/,4,false com.adobe.flexbuilder.crimson.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.crimson.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.css.editor,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.css.editor_4.5.1.313231/,4,false com.adobe.flexbuilder.css.editor.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.css.editor.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.dcrad,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.dcrad_4.5.1.313231/,4,false com.adobe.flexbuilder.dcrad.derived,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.dcrad.derived_4.5.1.313231/,4,false com.adobe.flexbuilder.dcrad.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.dcrad.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.debug,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.debug_4.5.1.313231/,4,false com.adobe.flexbuilder.debug.e33,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.debug.e33_4.5.1.313231/,4,false com.adobe.flexbuilder.debug.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.debug.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.debug.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.debug.ui_4.5.1.313231/,4,false com.adobe.flexbuilder.debug.ui.actions,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.debug.ui.actions_4.5.1.313231/,4,false com.adobe.flexbuilder.debug.ui.e36,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.debug.ui.e36_4.5.1.313231/,4,false com.adobe.flexbuilder.debug.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.debug.ui.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.designview,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.designview_4.5.1.313231/,4,false com.adobe.flexbuilder.designview.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.designview.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.editorcore,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.editorcore_4.5.1.313231/,4,false com.adobe.flexbuilder.editorcore.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.editorcore.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.editors.derived,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.editors.derived_4.5.1.313231/,4,false com.adobe.flexbuilder.editors.derived.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.editors.derived.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.exportimport,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.exportimport_4.5.1.313231/,4,false com.adobe.flexbuilder.exportimport.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.exportimport.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.flashbridge,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.flashbridge_4.5.1.313231/,4,false com.adobe.flexbuilder.flashbridge.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.flashbridge.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.flex,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.flex_4.5.1.313231/,4,false com.adobe.flexbuilder.flexunit,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.flexunit_4.5.1.313231/,4,false com.adobe.flexbuilder.flexunit.derived,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.flexunit.derived_4.5.1.313231/,4,false com.adobe.flexbuilder.flexunit.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.flexunit.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.help,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.help_4.5.1.313231/,4,false com.adobe.flexbuilder.help.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.help.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.importartwork,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.importartwork_4.5.1.313231/,4,false com.adobe.flexbuilder.importartwork.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.importartwork.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.json,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.json_4.5.1.313231/,4,false com.adobe.flexbuilder.launching.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.launching.ui_4.5.1.313231/,4,false com.adobe.flexbuilder.launching.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.launching.ui.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.monitors.network,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.monitors.network_4.5.1.313231/,4,false com.adobe.flexbuilder.monitors.network.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.monitors.network.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.multisdk,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.multisdk_4.5.1.313231/,4,false com.adobe.flexbuilder.mxml.editor,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.mxml.editor_4.5.1.313231/,4,false com.adobe.flexbuilder.mxml.editor.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.mxml.editor.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.mxmlmodel,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.mxmlmodel_4.5.1.313231/,4,false com.adobe.flexbuilder.project,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.project_4.5.1.313231/,4,false com.adobe.flexbuilder.project.e35,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.project.e35_4.5.1.313231/,4,false com.adobe.flexbuilder.project.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.project.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.project.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.project.ui_4.5.1.313231/,4,false com.adobe.flexbuilder.project.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.project.ui.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.services.BlazeDSService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.BlazeDSService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.CFService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.CFService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.CFService.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.CFService.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.services.HTTPService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.HTTPService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.HTTPService.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.HTTPService.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.services.J2EEService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.J2EEService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.J2EEService.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.J2EEService.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.services.LCDSService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.LCDSService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.PHPService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.PHPService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.PHPService.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.PHPService.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.services.StaticContentService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.StaticContentService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.StaticContentService.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.StaticContentService.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.services.WEBService,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.WEBService_4.5.1.313231/,4,false com.adobe.flexbuilder.services.WEBService.derived,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.WEBService.derived_4.5.1.313231/,4,false com.adobe.flexbuilder.services.WEBService.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.services.WEBService.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.standalone,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.standalone_4.5.1.313231/,4,false com.adobe.flexbuilder.standalone.e36,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.standalone.e36_4.5.1.313231/,4,false com.adobe.flexbuilder.standalone.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.standalone.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.tengine,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.tengine_4.5.1.313231/,4,false com.adobe.flexbuilder.tengine.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.tengine.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.ui,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.ui_4.5.1.313231/,4,false com.adobe.flexbuilder.ui.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.ui.nl1_4.5.1.313231/,4,false com.adobe.flexbuilder.utils.osnative,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.utils.osnative_4.5.1.313231/,4,false com.adobe.flexbuilder.utils.osnative.win,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexbuilder.utils.osnative.win_4.5.1.313231/,4,false com.adobe.flexide.amt,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.amt_4.5.1.313231/,4,false com.adobe.flexide.as.core,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.as.core_4.5.1.313231/,4,false com.adobe.flexide.as.core.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.as.core.nl1_4.5.1.313231/,4,false com.adobe.flexide.communityhelp,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.communityhelp_4.5.1.313231/,4,false com.adobe.flexide.communityhelp.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.communityhelp.nl1_4.5.1.313231/,4,false com.adobe.flexide.css.core,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.css.core_4.5.1.313231/,4,false com.adobe.flexide.css.core.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.css.core.nl1_4.5.1.313231/,4,false com.adobe.flexide.designitems,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.designitems_4.5.1.313231/,4,false com.adobe.flexide.editorcore,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.editorcore_4.5.1.313231/,4,false com.adobe.flexide.editorcore.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.editorcore.nl1_4.5.1.313231/,4,false com.adobe.flexide.editors.derived.e35,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.editors.derived.e35_4.5.1.313231/,4,false com.adobe.flexide.embeddedplayer,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.embeddedplayer_4.5.1.313231/,4,false com.adobe.flexide.exportimport,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.exportimport_4.5.1.313231/,4,false com.adobe.flexide.exportimport.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.exportimport.nl1_4.5.1.313231/,4,false com.adobe.flexide.externaleditors,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.externaleditors_4.5.1.313231/,4,false com.adobe.flexide.externaleditors.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.externaleditors.nl1_4.5.1.313231/,4,false com.adobe.flexide.fcproject,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.fcproject_4.5.1.313231/,4,false com.adobe.flexide.fcproject.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.fcproject.nl1_4.5.1.313231/,4,false com.adobe.flexide.fonts,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.fonts_4.5.1.313231/,4,false com.adobe.flexide.launching,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.launching_4.5.1.313231/,4,false com.adobe.flexide.launching.multiplatform,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.launching.multiplatform_4.5.1.313231/,4,false com.adobe.flexide.launching.multiplatform.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.launching.multiplatform.nl1_4.5.1.313231/,4,false com.adobe.flexide.launching.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.launching.nl1_4.5.1.313231/,4,false com.adobe.flexide.multiplatform.android,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.multiplatform.android_4.5.1.313231/,4,false com.adobe.flexide.multiplatform.android.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.multiplatform.android.nl1_4.5.1.313231/,4,false com.adobe.flexide.multiplatform.ios,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.multiplatform.ios_4.5.1.313231/,4,false com.adobe.flexide.multiplatform.ios.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.multiplatform.ios.nl1_4.5.1.313231/,4,false com.adobe.flexide.multisdk.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.multisdk.nl1_4.5.1.313231/,4,false com.adobe.flexide.mxml.core,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.mxml.core_4.5.1.313231/,4,false com.adobe.flexide.mxml.core.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.mxml.core.nl1_4.5.1.313231/,4,false com.adobe.flexide.nativelibs,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.nativelibs_4.5.1.313231/,4,false com.adobe.flexide.playerview,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.playerview_4.5.1.313231/,4,false com.adobe.flexide.project.multiplatform,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.project.multiplatform_4.5.1.313231/,4,false com.adobe.flexide.project.multiplatform.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.project.multiplatform.nl1_4.5.1.313231/,4,false com.adobe.flexide.refactoring.core,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.refactoring.core_4.5.1.313231/,4,false com.adobe.flexide.refactoring.core.nl1,4.5.1.313231,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.flexide.refactoring.core.nl1_4.5.1.313231/,4,false com.adobe.model.core,4.5.304901.v20110217,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.model.core_4.5.304901.v20110217.jar,4,false com.adobe.rds.core,4.5.304901.v20110217,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.rds.core_4.5.304901.v20110217.jar,4,false com.adobe.rds.dataview,4.5.304901.v20110217,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.adobe.rds.dataview_4.5.304901.v20110217.jar,4,false com.qnx.flashbuilder.multiplatform.qnx.ui,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.flashbuilder.multiplatform.qnx.ui_1.0.1.201104252316.jar,4,false com.qnx.flashbuilder.multiplatform.qnx.ui.nl1,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.flashbuilder.multiplatform.qnx.ui.nl1_1.0.1.201104252316.jar,4,false com.qnx.flexide.multiplatform.qnx,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.flexide.multiplatform.qnx_1.0.1.201104252316.jar,4,false com.qnx.flexide.multiplatform.qnx.nl1,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.flexide.multiplatform.qnx.nl1_1.0.1.201104252316.jar,4,false com.qnx.tools.bbt.core,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.tools.bbt.core_1.0.1.201104252316.jar,4,false com.qnx.tools.bbt.core.nl1,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.tools.bbt.core.nl1_1.0.1.201104252316.jar,4,false com.qnx.tools.bbt.ui,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.tools.bbt.ui_1.0.1.201104252316.jar,4,false com.qnx.tools.bbt.ui.nl1,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.tools.bbt.ui.nl1_1.0.1.201104252316.jar,4,false com.qnx.tools.flashbuilder4.help,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.tools.flashbuilder4.help_1.0.1.201104252316/,4,false com.qnx.tools.flashbuilder45,1.0.1.201104252316,file:/C:/dev/Adobe%20Flash%20Builder%204.5/eclipse/plugins/com.qnx.tools.flashbuilder45_1.0.1.201104252316.jar,4,false
2. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
etfd Jul 22, 2011 1:21 AM (in response to robsheely2)Yep. Just tried it and it works. Previously my Eclipse Marketplace was messed up. All good now.
3. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
dougarthur Jul 23, 2011 8:17 PM (in response to robsheely2)I had to modify your instructions slightly.
I had to add a step between 3 & 4.
3.5) Open eclipse and close it after it succesfully launches. (Because this is when Flash Builder modifies bundles.info)
And I also had to basically do a diff, I couldn't just take the settings pasted in the post here. Anything that was in Adobe's modified bundle.info that did not have an entry in the packaged eclipse bundle.info is what I had to copy over. I did not copy lines that had previous version or .nl* versions. Only distinct plugins/features did I copy over.
Hope this helps someone else.
4. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
Erno.Aapa Sep 1, 2011 10:33 PM (in response to dougarthur)Thanks! Diffing files to find all missing lines works!
Mac os x 10.6.8
Eclipse Indigo 3.7 32bit
Paul_Kuhn lines didn't work. Got "Creating Adobe Flash Player trust file..." error.
But diffing files as dougarthur say works and I didn't copy nl* files.
Basically what I did was:
- backup orginal bundles.info before flash builder install
- install flash builder and run it once
- copy lines what adobe have added (skip nl* lines) from bundles.info to backup bundles.info
- replace bundles.info with new bundles.info
Installation take ONLY half day to get it work! Come on Adobe!
5. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
GGB667atGMAILdotCOM Oct 14, 2011 7:51 AM (in response to Paul_Kuhn)This process worked for me.
I backed up the bundles.info file.
Installed flash builder by running the plugin installer.
Ran eclipse indigo.
Moved only the large blocks of adobe specific stuff at the top from the new bundles.info file to the backup file (skip nl* lines & everything else) - things it downgraded, looked like.
Replaced the bundles.info file with the backup file.
Re-ran eclipse.
Did help check for updates, and updated everything I could.
Shut down, restarted, and then my eclipse state appeared to function properly.
Greg Bishop
Server Engineer
ggb667_at_gmail.com
6. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
jamiecramb Oct 15, 2011 9:09 AM (in response to Paul_Kuhn)Thanks, this worked for me as well with the SpringSource Tool Suite 2.7.2!
Has anyone seen any problems from using this workaround in terms of the Flash Builder 4.5.1 plugin not working correctly or has it been reasonably stable?
Cheers,
Jamie
7. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
EDGAR.RIVERA Nov 16, 2011 6:19 AM (in response to Paul_Kuhn) -
8. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
dougarthur Nov 16, 2011 11:21 AM (in response to EDGAR.RIVERA)Flash Builder doesn't support 64-bit at this time.
9. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
macylubz Mar 8, 2012 3:52 PM (in response to Paul_Kuhn)i did everything, but my eclipse crashed when i tried to create a flex project
10. Re: Flash Builder 4.5 and Eclipse Indigo (3.7)?
thr.stone Jan 16, 2013 12:52 AM (in response to EDGAR.RIVERA)I have the same error.
can't fixed.
