21 Replies Latest reply on Jun 30, 2011 1:37 AM by Peter Spier
    CS 5 exports two pages at a time instead of one.
    The Primate Level 1
      I copied the following script from the Internet into notepad, saved it, and renamed it "spreads.jsx". I put it into my scripts file. It didn't do anything. app.interactivePDFExportPreferences.exportReaderSpreads = !app.interactivePDFExportPreferences.exportReaderSpreads
      I removed the facing pages check. My pages still exported two pages to a page. I then created a new document without the facing pages checked. I copied the 21 of my original file into the new file. It still exported two pages on one.
      >The only way to get non-facing pages to stick together is to disable page shuffling and drag them together in the Pages Panel, and that
      won't happen accidentally.
      I turned off shuffling, and that didn't help either. It was unclear what to drag in the Pages Panel.
      I'm now past my deadline for the newsletter and can use anybody's help so that I get an output in .pdf for single pages, so people can print out the file and have a single page on a single sheet.
      Lou
      First, here is my screen shot of the resulting .pdf file from exporting my 21 page document
      Second, here is the screen shot of my pages panel.
      Next, the export dialogue:
      Here is the scripts dialogue box.
        • 1. Re: CS 5 exports two pages at a time instead of one.
          Stix Hart Level 5
          If you have created a new docuiment without facing pages ticked your pages panel should look something like this:
          Anyhoo I'm sure you should be able to fix your original document with a script.  Try downloading this one here.  That is a zipped folder.  Save it somewhere, extract it and copy the .jsx file to your scripts panel folder.  Once you have it there and your document open double click on it.  You should get a dialog box like this:
          If you don't get exactly that, with it telling you they are OFF, click on it again and you will that time.  Export away and let us know what happens.  If it then doesn't work export the document to idml, open again in Indesign and repeat, along with making sure the script is telling you that spreads are OFF before you export.
          Also, that screenshot is telling us that you have missing fonts, go to Type > Find Font to fix them up.
          • 2. Re: CS 5 exports two pages at a time instead of one.
            The Primate Level 1
            It worked! Um, kind of. The three videos in the file won't play now. Do you have any advice?
            The reason why the fonts are not there is because I am on a different computer trying to fix the problem.I am going to the other one to see if I can get different results.
            • 3. Re: CS 5 exports two pages at a time instead of one.
              Stix Hart Level 5
              If you're on a different computer my first suspicion is that that computer doesn't have the latest Adobe Reader, try your other one where (I'm assuming) the videos worked before.
              • 4. Re: CS 5 exports two pages at a time instead of one.
                The Primate Level 1
                Here is what I've done. I took my original file and renamed it. Then I
                inserted the given script, ran it, and got the message I was told I would.
                When I exported my file, Video 1 and 3 disappeared altogether; there's white
                space in their position instead. Video 2 has moved up the page and is
                covering other photos, and left a blank space where it had been. Video 2 plays  in
                Reader. This is the same thing that happened on the other computer where I
                was testing the solution.
                I'm excited that my newsletter, for the first time in 27 years, is  going
                to have animation, kind of like that Harry Potter newspaper. What can I do
                to make this happen?
                Lou
                • 5. Re: CS 5 exports two pages at a time instead of one.
                  Stix Hart Level 5
                  OK I think you can mark this question as answered and start another thread for the video problem.  Unless when you exported as spreads it all worked OK?
                  First thing to do with the video problem is look at this post here and make sure that you are following those guidelines.
                  • 6. Re: CS 5 exports two pages at a time instead of one.
                    The Primate Level 1
                    Yes, when CS 5 exported and I had the two page spread problem, the videos were right where I put them and worked beautifully. The only thing that is different now is that I have the script that was sent to me. Get this. When I deleted the script, the file exported with single pages as I wanted. The video positions are where they should be, they just don't play still. It is an improvement and I seem to be extremely close now. What can be done to make them play?
                    I am very appreciative that you are helping me.
                    Lou
                    • 7. Re: CS 5 exports two pages at a time instead of one.
                      The script changes from spreads to single pages the first time it runs, and the settings stay that way until the script is run again.
                      As stix pointed out, you did NOT have a non-facing document. I think it would be helpful to run this script again to reset the export to it's default condition (in case there is some connection), then make a new single page file and uncheck facing pages in the setup dialog for that file. Add your videos to the new test file and export.
                      If they work there, make a copy of the newsletter, then in the copy go to File > Document Setup... and uncheck the facing pages box. Note that all pages will now be using the right-hand side of the two-page master spread that was assigned, so if you had asymmetrical master elements this is going to disturb them, but for testing purposes that should not be an issue. Export without running the script to see if the videos work and if you get single pages.
                      The other thing to try is make another copy of the file, then run the script from  http://www.printisrael.com/indesign/scripts/freeware/SeparatePages.jsx which will break apart all the facing page spreads into single pages without changing their "facing" attributes. This also should export as single pages.
                      • 8. Re: CS 5 exports two pages at a time instead of one.
                        The Primate Level 1
                        I did what you said: 1) Created a new two page file 2) Facing pages was not
                        checked 3) I put two videos in the bottom right corner of page 1   4)  I
                        put a third video near the right middle of page two. 5) I deleted the  script
                        Here is what happened.
                        1) I have always gotten this error message on export: "One or more
                        interactive files are clipped in ways that PDF files cannot reproduce. Those
                        elements will be adjusted in the exported PDF." I've been just saying okay to
                        that. Is that important to the issue here?
                        2) The two videos moved to the upper left and partially off the page in
                        Reader. They both play.
                        3) There is a red outline of the third video almost in the middle of page 1
                        (It should be on page 2.) There is nothing there to click on.
                        4) Page 2 is blank.
                        Why are the position of the videos moving? All three are f4v files that I
                        converted from mpg in the Adobe Media program.
                        What do you suggest? Also, how is it you came by all this knowledge of how
                        InDesign works? I have taken over 80 of those small lessons on Lynda, and
                        there  is nothing even close to this.
                        Lou
                        In a message dated 6/27/2011 6:08:17 A.M. US Mountain Standard Time,
                        forums@adobe.com writes:
                        pages.
                        script from
                        single  pages.
                        • 9. Re: CS 5 exports two pages at a time instead of one.
                          The Primate Level 1
                          One more thing. I just ran the script that you sent me. All three videos
                          now play, two on page one and one on page two. However, all have been
                          displaced  from their original positions, which would ruin the document design.
                          I went back and exported my original file. Video 1 is just a red outline of
                          blank space in the correct position. Video 2 has been displaced and
                          covers two photos, and plays. Video 3 is just blank space, not even a red
                          outline.
                          Lou
                          pages.
                          script from
                          single  pages.
                          • 10. Re: CS 5 exports two pages at a time instead of one.
                            Lou,
                            In order to properly diagnose your problem it is ESSENTIAL that ID is
                            behaving in a known and predictable way. This means that if you ran the
                            first script, the one that Stix recommended, and ran it only once and then
                            deleted it, you MUST reinstall the script, and run it again to reset the
                            export behavior to spreads so we know what's going on. You should see a new
                            dialog telling you that exporting spreads is active when the script runs.
                            Until you do that, we really can't tell where the problems with things
                            moving might be coming from.
                            I design for print, and I've been working with InDesign since it was first
                            released, switching my production work from Quark Xpress to InDesign when ID
                            2.0 was released about 10 years ago. Before going freelance as a designer I
                            worked a few years in print shops learning from other people's mistakes (and
                            learning how to fix most of them), and did some newspaper and magazine
                            production. Quite a bit of what I know about InDesign I've actually learned
                            here. For the first few years I read every post, and if I didn't already
                            know the answer I tried to figure it out. Even now, though, I usually learn
                            something new at least once a week.
                            As I just mentioned, I design for print, so the interactive stuff is a bit
                            murky for me, too, but if we can get you to a known state and see if things
                            are where they belong, someone who does interactives all the time may be
                            able to help more. I don't know about the warning you get, but I suspect it
                            is significant.
                            • 11. Re: CS 5 exports two pages at a time instead of one.
                              The Primate Level 1
                              Someone, maybe you, suggested I start a new thread about the video. I
                              posted it to the forum under:
                              "I solved the export single page issue and now my videos won't work." Here
                              is the text:
                              I have  windows 7 for 64 bit.
                              I ran  a script on my InDesign CS 5 document to solve the problem with two
                              pages  appearing on one .pdf file.  When I  clicked on it, here is what I
                              get “Spreads are now ON in Interactive PDF  Preferences.”
                              I get  two pages stuck together in my interactive .pdf file. I don’t want
                              that because  it prints to pages on a single sheet and I want each page to
                              print separately.  However, my three .f4v videos appear the way I want and run
                              perfectly, even  though I got the error message, “One or more interactive
                              elements are clipped in  ways that PDF files cannot reproduce. Those elements
                              will be adjusted in the  exported PDF. “
                              When I  click on the script again, it says, “Spreads are now OFF in
                              The  pages are the way I want. Now my videos don’t behave. Video 1 vanished
                              into a  red border with blank inside. Video 2 has moved half way up the
                              page, covering  two photos, but it plays. Video 3 has just white space in its
                              position.
                              Next,  I tried another script. When I ran it I got the message, “Shuffling
                              pages will  remove some page transitions. To avoid this message in the
                              future, uncheck allow  Document Pages to Shuffle in the Pages panel. Select OK to
                              continue.” I hit okay  several times and the message kept appearing again
                              and again. I finally clicked  “Don’t show again” and it went away. I got the
                              same error message as before. The  videos are all screwed up, like before.
                              I  toggled that script and exported again, and got the same error message.
                              This  time, as before, the videos were messed up, but this time one of the
                              videos was  off the page, but played.
                              Is  there any way I can keep one page to one in the .pdf AND have my videos
                              work?
                              Lou
                              In a message dated 6/27/2011 7:39:51 A.M. US Mountain Standard Time,
                              Lou,
                              new
                              ID
                              I
                              (and
                              learned
                              learn
                              things
                              it
                              is  significant.
                              • 12. Re: CS 5 exports two pages at a time instead of one.
                                Did you run the first script again to put the export options back to two-page spreads BEFORE running the scond script? That's important since evidently it's the first script changing the preferences that is initially causing the problem with the video. The scond script does not toggle anything, only the first one, which is why I suggested running on a copy. We're trying to establish if breaking the spreads apart inside ID will export the videos correctly, but we can't do that unless the preference is toggled to the "on" postion for exporting spreads.
                                Do you actually have page transitions to worry about? You didn't mention them before...
                                Have you ever actually tried a new document that didn't have facing pages? The last time you said you did the screen shot showed you still had facing pages.
                                • 13. Re: CS 5 exports two pages at a time instead of one.
                                  The Primate Level 1
                                  I tried all the combinations of both scripts. At present all graphics print black.
                                  I am experimenting on a copy.
                                  I have done everything with spreads on and off. If I have the spreads on, the video works. But then I can't publish my newsletter because there are two pages that print on one sheet.
                                  I don't know what that is. I never heard of it before. Can you explain?
                                  I unchecked the box with facing pages on all tries I have done.
                                  Lou
                                  Lou
                                  • 14. Re: CS 5 exports two pages at a time instead of one.
                                    Stix Hart Level 5
                                    Lou
                                    OK let's focus on this.  You say you've done this but it hasn't worked, as I've said before your screenshot above shows facing pages.  Show us the Setup dialog box and the pages panel after you've unticked facing pages.
                                    • 15. Re: CS 5 exports two pages at a time instead of one.
                                      I would like you to try a brand new file if you don't mind. There's really no way to tell waht sort of damage is done to what you have.
                                      First, File > New... and set up the correct page count and dimensions, then uncheck the Pacing Pages box. Verify by looking in the Pages Panel that there are no two-page spreads showing in the panel.
                                      Open the original file, switch to the Black Arrow (Selection tool) and page by page, Edit > Select All, then Edit > Copy. Paste onto the corresponding page in the new document and adjust the position if necessary.
                                      Export the new file to Interactive PDF without running any scripts.
                                      • 16. Re: CS 5 exports two pages at a time instead of one.
                                        The Primate Level 1
                                        As far as those scripts, there were two of them, should BOTH be in my
                                        documents scripts folder? It just occurred to me that I have been only putting
                                        in one at a time, deleting it, then running the other one to see if I could
                                        fix  things.
                                        Lou
                                        In a message dated 6/26/2011 6:13:58 P.M. US Mountain Standard Time,
                                        http://forums.adobe.com/servlet/JiveServlet/showImage/73669/1.png
                                        http://indesignsecrets.com/downloads/togglespreads.zip.  That is a zipped  folder.  Save it somewhere, extract it and
                                        this:
                                        http://forums.adobe.com/servlet/JiveServlet/showImage/73682/2.png
                                        If  you don't get exactly that, with it telling you they are OFF click on
                                        If it then doens't work export the document to idml, open again in
                                        • 17. Re: CS 5 exports two pages at a time instead of one.
                                          Stix Hart Level 5
                                          The Primate wrote:
                                          fix  things.
                                          Lou
                                          Makes no difference at all if both, one or neither are in the folder, it's only when you run them that they do something.
                                          Take a look at and respond to posts 14 & 15, separately.
                                          • 18. Re: CS 5 exports two pages at a time instead of one.
                                            The Primate Level 1
                                            Okay. I guess what I meant is do I run them both. I have tried that  after
                                            your last letter and a two page spread keeps appearing in my pages panel.
                                            Despite my success in doing that previously in my gyrations at the keyboard,
                                            I  can't get the spread off. I keep unchecking the facing pages box, running
                                            the  scripts...I'm in a really frustrating loop here.
                                            Lou
                                            • 19. Re: CS 5 exports two pages at a time instead of one.
                                              The Primate Level 1
                                              I started a brand new 21 page file. I copied five pages using the pages
                                              panel. I then exported the interactive pdf file and the videos were messed up.
                                              When I went to print in Reader, the print preview had my graphics as all
                                              black.  I deleted that file.
                                              I again made a 21 page file, but this time I copied five of the pages
                                              directly from the InDesign pages, not using the pages panel. I pasted them in
                                              the new file. Same result.
                                              I didn't load or run scripts in these two procedures. They both had single
                                              pages showing in the pages panel, although the file from which I  was
                                              copying had two page spreads showing in the pages panel.
                                              Is there something else I can try?
                                              Lou
                                              In a message dated 6/29/2011 4:04:40 A.M. US Mountain Standard Time,
                                              • 20. Re: CS 5 exports two pages at a time instead of one.
                                                The Primate Level 1
                                                I also exported the new file as an InDesign markup file (IDML). Then
                                                reloaded it. That didn't help either.
                                                Lou
                                                • 21. Re: CS 5 exports two pages at a time instead of one.
                                                  Lou
                                                  I'm still not sure what state the export of spreads setting is in. You should stop running those scripts for the moment while we figure out where things are.
                                                  Make a facing pages file of at least three pages, or open one that you have already. DO NOT RUN ANY SCRIPT. Export to interactive PDF. Are you getting single pages, or a two-page spread in the PDF? If you are getting a two page spread, do nothing more. If you are getting all single pages, run the script that toggles single pages/spreads ( the first script you got, the one that puts up the dialog) ONE TIME ONLY. Close InDesign.
                                                  Read the directions in this link and replace your preferences: Replace Your Preferences
                                                  Try the second file you made above with the copied elements. If it still does not work, re-link the videos to fresh copies and try again.
                                                  If it still does not work, I think someone will need to see your files to diagnose what's going on. Normally I would volunteer to do this myself, but I don't do this kind of file in my regular workflow, and I have a major project in production this week and no time to experiment. Perhaps someone else can step in.
