2 Replies Latest reply on Jun 27, 2011 4:12 AM by raffialexanian
    Title Window animation
    raffialexanian Level 1
      Dear all coders, this thing has been driving me nuts for many many hours now, so any help is appreciatted.
      Am trying to animate a popup titlewindow when it appears, I have a code that works when the titlewindow code is inside the main application, but when it is a seperate component, I cant get it to work, and I almost tried everything, well am sure not everything cause I still didn't figure out the answer:
      Code that works:
      <s:Application name="Spark_Panel_showEffect_test"
         xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/halo">
      <s:layout>
      <s:VerticalLayout />
      </s:layout>
      <fx:Declarations>
      <s:Parallel id="showEff">
      <s:Rotate3D angleYFrom="-90" angleYTo="0" />
      <s:Fade alphaFrom="0.0" alphaTo="1.0" />
      </s:Parallel>
      <s:Parallel id="hideEff">
      <s:Rotate3D angleYFrom="0" angleYTo="-90" />
      <s:Fade alphaFrom="1.0" alphaTo="0.0" />
      </s:Parallel>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      private function visibilityPanel():void
      panel.visible = true;
      </fx:Script>
      <s:Button id="btn"
        label="Visibility"
        click="visibilityPanel();" />
      <s:Panel id="panel" visible="false"
      title="Panel title"
      showEffect="{showEff}"
      hideEffect="{hideEff}">
      </s:Panel>
      </s:Application>
      Code of main app that does not work:
      <s:layout>
      </s:layout>
      <fx:Declarations>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.managers.PopUpManager;
      var pop = new panelTest ;
      PopUpManager.addPopUp(pop, this, false);
      </fx:Script>
      <s:Button id="btn"
        label="Visibility"
      </s:Application>
      TitleWindow Component:
      <s:TitleWindow xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300"
      <fx:Declarations>
      </s:Parallel>
      </s:Parallel>
      </fx:Declarations>
      </s:TitleWindow>
      Please please help on this; the title pops up, but does not animate,
