• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Problem inserting a record. Please help
Participant ,
Mar 24, 2009 Mar 24, 2009
I can't get my insert statement to work properly. I keep looking it over and it is written correctly, but it doesn't fire properly and doesn't throw and error. it just doesn't do anything.
I am attaching my code for the 2 pages. page 1 is my form, this form is to do both update an existing record, and insert a new record. Right now, on this page, it handles the existing record and edit fine, even updates it properly on the action page. But the new record is not posting. The 2nd page I am posting is my action query. I don't think the problem is there, I think it is in my form.
Can anyone please help me get this to work properly?
Thank you.
TOPICS
Advanced techniques
Views
870
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant , Mar 25, 2009 Mar 25, 2009
I found it, I dumped a couple of different variables, and with the changes I made, I got form.RecordID to pass. Had to step away and think for a little while.
Thank you for the help.
Votes
Translate
Translate
Enthusiast ,
The insert code will never be executed.
On your form page you have a cfparam that declares the url.RecordId with a default of zero.
So the form field will always exist, thus in the action page you are trying to update a record with id of zero.
Ken
Votes
Translate
Translate
Report
Report
Participant ,
Ok, I took that out, now my action page is saying the my recordID is not defined, but it is.
This is what I am using now:
<cfset admin = "False">
<cfparam name="variables.ID" type="integer" default="#url.RecordID#">
<cfparam name="variables.Fname" default="">
<cfparam name="variables.Lname" default="">
<cfparam name="variables.userName" default="">
<cfparam name="variables.password" default="">
<cfparam name="variables.email" default="">
<cfparam name="variables.admin" default="">
<cfif url.RecordID GT 0>
<cfquery name="useRec" datasource="#APPLICATION.dataSource#">
SELECT user.Fname, user.Lname, user.userName, user.password, user.email, user.admin, user.ID
FROM user
WHERE user.ID =<cfqueryparam value="#URL.RecordID#" cfsqltype="cf_sql_integer">
</cfquery>
<cfif useRec.RecordCount EQ 1>
<cfset variables.RecordID = useRec.ID>
<cfset variables.Fname = useRec.Fname>
<cfset variables.Lname = useRec.Lname>
<cfset variables.userName = useRec.userName>
<cfset variables.password = useRec.password>
<cfset variables.email = useRec.email>
<cfset variables.admin = useRec.admin>
</cfif>
</cfif>
<head>
<body>
<cfoutput>
<cfform action="action.cfm" method="post" name="useRec" id="useRec" enctype="multipart/form-data">
<input type="hidden" name="variables.ID" value="#url.RecordID#">
<input type="text" name="Fname" value="#variables.Fname#" maxLength="150">
<!--- more inputs and submit buttons here --->
</cfform></cfoutput>
</body>
this is my action page now:
<cfif not IsDefined("FORM.admin")>
<cfset IsAdmin= 0>
<cfelse>
<cfset IsAdmin= 1>
</cfif>
<cfif url.RecordID eq 0>
<cfquery datasource="#APPLICATION.dataSource#" dbtype="ODBC">
INSERT INTO user
(Fname, Lname, userName, password, email, admin)
VALUES (<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.Fname#">,
<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.Lname#">,
<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.userName#">,
<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.password#">,
<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.email#">,
<cfqueryparam value="#IsAdmin#" CFSQLType="CF_SQL_INTEGER">)
</cfquery>
<cflocation url="indexUser.cfm">
<cfelse>
UPDATE user
SET user.Fname=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.Fname#">,
user.Lname=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.Lname#">,
user.userName=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.userName#">,
user.password=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.password#">,
user.email=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.email#">,
user.admin =<cfqueryparam value="#IsAdmin#" CFSQLType="CF_SQL_INTEGER">
WHERE ID =<cfqueryparam value="#form.RecordID#" cfsqlType="CF_SQL_INTEGER">
</cfquery>
<cflocation url="indexUser.cfm?RecordID=#Form.RecordID#" addtoken="no">
</cfif>
I had it working... but then I made some other changes and it made things work better, until this issue. here is my error:
Element RECORDID is undefined in URL.
The error occurred on line 17 action.cfm.
What am I doing wrong. This is driving me crazy, Not like it is my first form I wrote, I am missing something and can't figure it out.
Votes
Translate
Translate
Report
Report
Advocate ,
Are you actually passing the recordid from the initial page?..
Votes
Translate
Translate
Report
Report
Participant ,
yes, this is my first page form button that sends you to my edit page:
<cfform action="Action.cfm" name="myform" method="post">
<cfinput type="hidden" name="RecordID" value="#ID#">
<!--- this is a submit button only --->
</cfform>
Votes
Translate
Translate
Report
Report
Advocate ,
Does your URL contain the "RECORDID" string anywhere after "?" (or) "&" symbols?..
Votes
Translate
Translate
Report
Report
Participant ,
no, I was passing it through form variables, but if I use <cfif isDefined ("form.RecordID")> it still says that isn't defined.
Votes
Translate
Translate
Report
Report
LEGEND ,
what happens when you cfdump your form? Is there a recordid?
Votes
Translate
Translate
Report
Report
Participant ,
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Votes
Translate
Translate
Report
Report
Resources
Documentation
