2 Replies Latest reply on Jul 12, 2011 3:49 AM by Francisc
    IconItemRenderer decorator
    Francisc Level 3
      Hello,
      Is it possible to specify size for the decorator?
      If not, how do you set multiple sources from ActionScript?
      Thank you.
        • 1. Re: IconItemRenderer decorator
          Shongrunden Adobe Employee
          The decorator is designed to be an embedded asset.  If you want to provide different assets for different DPIs then consider using MultiDPIBitmapSource, for example:
          <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                  title="Multi DPI Decorator">
              <s:List width="100%" height="100%">
                  <s:itemRenderer>
                      <fx:Component>
                          <s:IconItemRenderer labelField="label">
                              <s:decorator>
                                  <s:MultiDPIBitmapSource
                                      source160dpi="@Embed('../settingsIcon0.png')"
                                      source240dpi="@Embed('../settingsIcon1.png')"
                                      source320dpi="@Embed('../settingsIcon2.png')"/>
                              </s:decorator>
                          </s:IconItemRenderer>
                      </fx:Component>
                  </s:itemRenderer>
                  <s:dataProvider>
                      <s:ArrayList>
                          <s:DataItem label="0" />
                          <s:DataItem label="1" />
                          <s:DataItem label="2" />
                      </s:ArrayList>
                  </s:dataProvider>
              </s:List>
          </s:View>
          • 2. Re: IconItemRenderer decorator
            Francisc Level 3
            Thank you.
            I needed either to be able to set size or do what you did in AS, but I figured it out.
            Basically, you set source of the decorator to an instance of the MultiDPIBitmapSource.
            Should have given it more time before asking.
